path: root/board/toradex/colibri_vf61/nandimage.cfg
2013-11-21colibri_vf: rename colibri_vf61 to colibri_vfMarcel Ziswiler
Now as the colibri_vf61 configuration supports memory size as well as module type auto detection actually rename it to colibri_vf to be universally used for Colibri VF50 as well as VF61.
2013-10-24colibri_vf61: initial integrationMarcel Ziswiler
Add initial Colibri VF61 support based off Timesys' implementation for Freescale's Vybrid Tower System TWR-VF65GS10: - New machine ID. - Default UART_A on SCI0. - ESDHC2 only. - 8-bit NAND. - No quad SPI. - FEC1 only. - Enabled command line editing. - PLL5 based RMII clocking (e.g. no external crystal). - UART_A, UART_B and UART_C I/O muxing. - Increase the available space for the U-Boot binary to half a megabyte by booting from gfxRAM rather than sysRAM0. - Integrate factory configuration block handling for hardware version, MAC address and serial number to be passed to Linux. - The U-Boot environment is stored in NAND flash. - Fix long standing boot hang issue introduced by Freescale's Vybrid 1.1 silicon. - Proper 256 MB Nanya DDR3 RAM timings. Tested on early Colibri VF61 prototypes V1.0b and V1.0c using SD card (mandatory for initial loading) as well as NAND boot.
