path: root/board/sbc8560
2011-11-11board/sbc8560/sbc8560.c: Fix GCC 4.6 build warningKumar Gala
Fix: sbc8560.c: In function 'ft_board_setup': sbc8560.c:351:12: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14mpc85xx boards: initdram() cleanup/bugfixBecky Bruce
Correct initdram to use phys_size_t to represent the size of dram; instead of changing this all over the place, and correcting all the other random errors I've noticed, create a common initdram that is used by all non-corenet 85xx parts. Most of the initdram() functions were identical, with 2 common differences: 1) DDR tlbs for the fixed_sdram case were set up in initdram() on some boards, and were part of the tlb_table on others. I have changed them all over to the initdram() method - we shouldn't be accessing dram before this point so they don't need to be done sooner, and this seems cleaner. 2) Parts that require the DDR11 erratum workaround had different implementations - I have adopted the version from the Freescale errata document. It also looks like some of the versions were buggy, and, depending on timing, could have resulted in the DDR controller being disabled. This seems bad. The xpedite boards had a common/fsl_8xxx_ddr.c; with this change only the 517 board uses this so I have moved the ddr code into that board's directory in xpedite517x.c Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_E500=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC85xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8548=1 However these are all captured in the config.h and thus redudant. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Break out common memory initialization functionPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-018xxx: Move dma_init() call to common codePeter Tyser
2009-07-018xxx: Rename dma_xfer() to dmacpy()Peter Tyser
Also update dmacpy()'s argument order to match memcpy's and use phys_addr_t/phy_size_t for address/size arguments Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2885xx: Fix compile breakage with sbc8540 and sbc8560Wolfgang Denk
This fixes an error which raises just a warning: sbc8560.c:250: warning: passing argument 2 of 'strmhz' makes integer from pointer without a cast Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-10-21Use strmhz() to format clock frequenciesWolfgang Denk
2008-10-18Pass dimm parameters to populate populate controller optionsHaiying Wang
Because some dimm parameters like n_ranks needs to be used with the board frequency to choose the board parameters like clk_adjust etc. in the board_specific_paramesters table of the board ddr file, we need to pass the dimm parameters to the board file. * move ddr dimm parameters header file from /cpu to /include directory. * add ddr dimm parameters to populate board specific options. * Fix fsl_ddr_board_options() for all the 8xxx boards which call this function. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-08-27FSL DDR: Convert SBC8560 to new DDR code.Kumar Gala
2008-07-14sbc8560: add in ft_board_setup()Paul Gortmaker
Add in for the sbc8560, the ft_board_setup() routine, based on what is in use for the Freescale MPC8560ADS board. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-07-14sbc8560: properly set cs0_bnds for 512MBPaul Gortmaker
The sbc8560 board ships with 512MB of memory installed, but the current cs0_bnds is hard coded for 256MB. Set the value based on CFG_SDRAM_SIZE. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-1785xx: Convert SBC8540/SBC8560/SBC8548 to new TLB setupKumar Gala
2008-01-1685xx: Use proper defines for PCI addressesKumar Gala
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE. While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only be used for configuring the PCI ATMU. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: convert SBC8540/SBC8560/SBC8548 over to use new LAW init codeKumar Gala
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_*_ADDR as the base of the registers instead of getting it via &immap. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t for guts offset on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_GUTS_ADDR as the base of the guts registers instead of getting it via &immap->im_gur. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
