path: root/board/sbc8349
2011-11-03mpc83xx: Rename CONFIG_SYS_DDR_CONFIG and cleanup DDR csbnds codeJoe Hershberger
Rename CONFIG_SYS_DDR_CONFIG to include which CS it is configuring Cleanup the setting of the csnbds to respect the setting of CONFIG_SYS_DDR_SDRAM_BASE Use __ilog2 instead of writing the code to compute it Disable unused CS configs Ensure ddrlaw.bar is configured Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-27sbc8349: combine HRCW flash and u-boot image flashPaul Gortmaker
Up to this point in time, the sbc8349 board was storing the u-boot image in flash 2x. One for the HRCW value at the beginning of flash (0xff80_0000), and once close to the end of flash (0xfff8_0000) for the actual image that got executed. This moves the TEXT_BASE to be the beginning of flash, which makes the second copy of the image redundant, and frees up the flash from the end of the environment storage to the end of the flash device itself. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-18mpc83xx: convert all remaining boards over to 83XX_GENERIC_PCIKim Phillips
2009-06-1283xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xxPeter Tyser
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-29Make Freescale local bus registers available for both 83xx and 85xx.Haiying Wang
- Rename lbus83xx_t to fsl_lbus_t and move it to asm/fsl_lbc.h so that it can be shared by both 83xx and 85xx - Remove lbus83xx_t and replace it with fsl_lbus_t in all 83xx boards files which use lbus83xx_t. - Move FMR, FIR, FCR, FPAR, LTESR from mpc83xx.h to asm/fsl_lbc.h so that 85xx can share them. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-09-24mpc83xx: spd_sdram: fix ddr sdram base address assignment bugAnton Vorontsov
The spd_dram code shifts the base address, then masks 20 bits, but forgets to shift the base address back. Fix this by just masking the base address correctly. Found this bug while trying to relocate a DDR memory at the base != 0. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-08mpc83xx: rm remaining FLAT_TREE codeKim Phillips
..in board pci.c files Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: remove FLAT_TREE codeKim Phillips
need to rm it from pci code, too! Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: convert to using do_fixup_*()Kim Phillips
convert to using simpler mpc85xx style fdt update code; streamline by eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm the old school FLAT_TREE code from 83xx (since the sbc8349 was just converted over to using libfdt). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08sbc8349: migrate board to libfdtPaul Gortmaker
This adds libfdt support code for the Wind River sbc8349 board. Parallel of commit 3fde9e8b22cfbd7af489214758f9839a206576cb for the other Freescale 83xx boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-01-08sbc8349: Remove board specific ECC codePaul Gortmaker
ECC code is now shared for all 83xx boards, so remove board specific one. See commit daab8c67d2defef73dc26ab07f0c3afd1b05d019 for reference. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2007-08-16mpc83xx: implement board_add_ram_infoKim Phillips
add board_add_ram_info, to make memory diagnostic output more consistent. u-boot banner output now looks like: DRAM: 256 MB (DDR1, 64-bit, ECC on) and for boards with SDRAM on the local bus, a line such as this is added: SDRAM: 64 MB (local bus) also replaced some magic numbers with their equivalent define names. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-04Remove obsolete mpc83xx linker scriptsGrant Likely
2007-03-02mpc83xx: U-Boot support for Wind River SBC8349Paul Gortmaker
I've redone the SBC8349 support to match git-current, which incorporates all the MPC834x updates from Freescale since the 1.1.6 release, including the DDR changes. I've kept all the SBC8349 files as parallel as possible to the MPC8349EMDS ones for ease of maintenance and to allow for easy inspection of what was changed to support this board. Hence the SBC8349 U-Boot has FDT support and everything else that the MPC8349EMDS has. Fortunately the Freescale updates added support for boards using CS0, but I had to change spd_sdram.c to allow for board specific settings for the sdram_clk_cntl (it is/was hard coded to zero, and that remains the default if the board doesn't specify a value.) Hopefully this should be mergeable as-is and require no whitespace cleanups or similar, but if something doesn't measure up then let me know and I'll fix it. Thanks, Paul.
