path: root/board/pxa255_idp
2011-12-06PXA: Rename pxa_dram_init to pxa2xx_dram_initMarek Vasut
2011-12-06PXA: Squash extern pxa_dram_init()Marek Vasut
2010-10-22PXA: pxa255_idp: Fix for relocMarek Vasut
2010-10-19PXA: pxa-regs.h cleanupMarek Vasut
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-10-23fix pxa255_idp boardMarcel Ziswiler
The pxa255_idp being an old unmaintained board showed several issues: 1. CONFIG_INIT_CRITICAL was still defined. 2. Neither CONFIG_MAC_PARTITION nor CONFIG_DOS_PARTITION was defined. 3. Symbol flash_addr was undeclared. 4. The boards lowlevel_init function was still called memsetup. 5. The TEXT_BASE was still 0xa3000000 rather than 0xa3080000. 6. Using -march=armv5 instead of -march=armv5te resulted in lots of 'target CPU does not support interworking' warnings on recent compilers. 7. The PXA's serial driver redefined FFUART, BTUART and STUART used as indexes rather than the register definitions from the pxa-regs header file. Renamed them to FFUART_INDEX, BTUART_INDEX and STUART_INDEX to avoid any ambiguities. 8. There were several redefinition warnings concerning ICMR, OSMR3, OSCR, OWER, OIER, RCSR and CCCR in the PXA's assembly start file. 9. The board configuration file was rather outdated. 10. The part header file defined the vendor, product and revision arrays as unsigned chars instead of just chars in the block_dev_desc_t structure. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2005-09-25Add Vibren (was Accelent) PXA255 IDP SupportWolfgang Denk
Patch by Cliff Brake, 04 Feb 2005
