path: root/board/netphone
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-19Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-17Remove legacy NAND and disk on chip references from boards.Scott Wood
2009-06-04Redundant Environment: protect full sector sizeWolfgang Denk
Several boards used different ways to specify the size of the protected area when enabling flash write protection for the sectors holding the environment variables: some used CONFIG_ENV_SIZE and CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even a mix of both for the "normal" and the "redundant" areas. Normally, this makes no difference at all. However, things are different when you have to deal with boards that can come with different types of flash chips, which may have different sector sizes. Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the biggest sector size, which may include several sectors on boards using the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the case that only the first of these sectors get protected, while the following ones aren't. This is no real problem, but it can be confusing for the user - especially on boards that use CONFIG_ENV_SECT_SIZE to protect the "normal" areas, while using CONFIG_ENV_SIZE_REDUND for the "redundant" area. To avoid such inconsistencies, I changed all sucn boards that I found to consistently use CONFIG_ENV_SECT_SIZE for protection. This should not cause any functional changes to the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Paul Ruhland Cc: Pantelis Antoniou <panto@intracom.gr> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Dave Ellis <DGE@sixnetio.com> Acked-by: Stefan Roese <sr@denx.de>
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-11* Patch by Dan Poirot, 06 Jul 2004:wdenk
Fix sbc8260 environment variables * Cleanup redundand "console" environment variable
2004-06-07Patch by Pantelis Antoniou, 5 May 2004:wdenk
- Intracom board update. - Add Codec POST.
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2004-04-18Patches by Pantelis Antoniou, 16 Apr 2004:wdenk
- add support for a new version of an Intracom board and fix various other things on others. - add verify support to the crc32 command (define CONFIG_CRC32_VERIFY to enable it) - fix FEC driver for MPC8xx systems: 1. fix compilation problems for boards that use dynamic allocation of DPRAM 2. shut down FEC after network transfers - HUSH parser fixes: 1. A new test command was added. This is a simplified version of the one in the bourne shell. 2. A new exit command was added which terminates the current executing script. 3. Fixed handing of $? (exit code of last executed command)
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
