path: root/board/korat
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-27ppc4xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
This commit adapts 4xx boards for partial linking with --gc-sections. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: David Updegraff <dave@cray.com> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Larry Johnson <lrj@acm.org> Cc: Peter De Schrijver <p2@mind.be> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Daniel Poirot <dan.poirot@windriver.com> Acked-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Big header cleanup, mostly PPC440 relatedStefan Roese
This patch starts a bit PPC4xx header cleanup. First patch mostly touches PPC440 files. A later patch will touch the PPC405 files as well. This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Move gpio.h to ppc4xx-gpio.h since its ppc4xx specificStefan Roese
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-29Fix typos in Korat board console outputLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org> Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-24Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_master_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_master_init() function by introducing a weak default function for it. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-29ppc4xx: Add variable "korat_usbcf" for Korat boardLarry Johnson
The new environment variable "korat_usbcf" selects the USB port used by the Korat board's CompactFlash controller. Signed-off-by: Larry Johnson <lrj@acm.org> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Fix small korat merge problemStefan Roese
2008-07-10ppc4xx: Remove implementation of testdram() from Korat board supportLarry Johnson
2008-07-10ppc4xx: Update and add FDT to Korat board supportLarry Johnson
2008-03-27ppc4xx: Updates to Korat-specific codeLarry Johnson
This patch contains updates for changes for the Korat PPC440EPx board. These changes include: (1) Support for "permanent" and "upgradable" copies of U-Boot, as described in the new "doc/README.korat" file; (2) a new memory map for the registers in the board's CPLD; (3) a revised format for manufacturer's data in serial EEPROM; and (4) changes to track updates to U-Boot for the Sequoia board. Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-17Merge Sequoia beautification into Korat codeLarry Johnson
2008-01-04ppc4xx: Use CFG_4xx_GPIO_TABLE to configure Korat boardLawrence R. Johnson
2007-12-27Add support for Korat PPC440EPx boardLarry Johnson
These patches add support for the PPC440EPx-based "Korat" board to U-Boot. They are based primarily on support for the Sequoia board. Signed-off-by: Larry Johnson <lrj@acm.org>
