path: root/board/davinci
2012-02-27dm6467Tevm: Use a common configuration file for davinci_dm6467evm and ↵prabhakar.csengg@gmail.com
davinci_dm6467Tevm In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h. The substantial difference between the davinci_dm6467evm and the davinci_dm6467Tevm configuration is a single bit in the hardware revision that is passed to the Linux kernel and davinci_dm6467evm has REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a REFCLK_FREQ = 33000000. This patch removes include/configs/davinci_dm6467Tevm.h. Instead the include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined in boards.cfg. Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-02-27da850evm: read mac address from I2C EEPROM on AM18x EVMHadli, Manjunath
add support to read mac address for AM18x EVM manufactured from Spectrum digital which have mac address stored in I2C EEPROM manufactured by WINBOND. This patch reads mac address from I2C EEPROM and sets the environment variable if not set, If mac address is already present in environment compare it with the mac address in EEPROM and warn on mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where to look for the mac address. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-27da850evm: add support to read mac address from SPI flashHadli, Manjunath
add support to read mac address for da850/L138 evm manufactured by Logic PD which store mac address in SPI flash manufactured by ST Microelectronics. This patch adds support to read mac address from SPI flash and set the mac address if it hasn't been set in environment, If it has been set in the environment it compares the value one with SPI flash and warns on mismatch. Introduced a config option CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2011-12-24arm, da850evm: Add an SPL for SPI bootChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
2011-12-06da850evm: pass board revision info to kernelManjunath Hadli
there are two boards based on da850 SOC - OMAP-L138 and AM18x. In order to differentiate between these two boards, revision id is passed to kernel via second byte of ATAG_REVISION. Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com> Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
2011-12-06arm, davinci: move misc function in arch treeHeiko Schocher
move the board/davinci/common/misc.c file to arch/arm/cpu/arm926ejs/davinci/misc.c, so all davinci boards can use this functions. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Christian Riesch <christian.riesch@omicron.at>
2011-12-06arm, board/davinci/common/misc.c: Codingstyle cleanupHeiko Schocher
2011-12-06arm, hawkboard: Use the pinmux configurations defined in the arch treeChristian Riesch
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors that contain pinmux configurations for emac, uarts, memory controllers... In an earlier patch such pinmux configurations were added to the arch tree. This patch makes the hawkboard use these definitions instead of defining its own. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, da850evm: Use the pinmux configurations defined in the arch treeChristian Riesch
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors that contain pinmux configurations for emac, uarts, memory controllers... In an earlier patch such pinmux configurations were added to the arch tree. This patch makes the da850evm use these definitions instead of defining its own. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, da850evm: Do pinmux configuration for EMAC together with other pinmuxesChristian Riesch
Pinmux configuration for the EMAC was done in a separate call of davinci_configure_pin_mux(). This patch moves all the pinmux configuration that is done for this board to a common place. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, hawkboard: Remove obsolete struct pinmux_config i2c_pinsChristian Riesch
The configuration in struct pinmux_config i2c_pins does not configure the pins for i2c but for uart. Since this function is already configured by struct pinmux_config uart2_pins the i2c_pins struct is obsolete. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2011-12-06arm, davinci: Move pinmux functions from board to arch treeChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Nick Thompson <nick.thompson@ge.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Nick Thompson <nick.thompson@ge.com>
2011-11-29hawkboard: Replace HAWKBOARD_KICK{0, 1}_UNLOCK definesChristian Riesch
This patch replaces the HAWKBOARD_KICK{0,1}_UNLOCK defines by DV_SYSCFG_KICK{0,1}_UNLOCK. The kick register values are not hawkboard specific but may be used for all davinci boards. In commit f3c149d6c6e5ba8dd72baa86fe527837e4fb0e9a new defines for these values wer introduced. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-29davinci_sonata: define CONFIG_MACH_TYPE for davinci_sonata boardChristian Riesch
This patch fixes the build breakage for the davinci_sonata board. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sergey Kubushyn <ksi@koi8.net> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-29davinci_schmoogie: define CONFIG_MACH_TYPE for davinci_schmoogie boardChristian Riesch
This patch fixes the build breakage for the davinci_schmoogie board. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sergey Kubushyn <ksi@koi8.net> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-08dm646x: pass board revision info to kernelManjunath Hadli
add a function in board file to pass board revision info to kernel. Revision number 0 and 1 are passed in case of DM6467 and DM6467T respectively. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: added I2C supportStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: added video supportStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Cc: Anatolij Gustschin <agust@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: add gpios for LCD backlight controlBastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: add gpio for keeping power on in board_late_initBastian Ruppert
The pin called HALTEN drives a transistor to operate the supply voltage. After HALTEN is high, the user can release the power switch button and the device will stay powered on. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: sbabic@denx.de CC: dzu@denx.de Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: Add early init to get early output from consoleStefano Babic
Use board_early_init_f so that the full boot log output can be displayed. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: Add NAND supportStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> CC: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for ↵Bastian Ruppert
console Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: dzu@denx.de CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03Davinci: ea20: set console on UART0Bastian Ruppert
Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILDHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27da850evm: Move LPSC configuration to board_early_init_f()Christian Riesch
Since commit f1d2b313c9eb6808d30c16a9eb5251240452a56c the serial port of the da850evm is accessed before the UART2 peripheral of the SoC is powered on in the function board_init() in board/davinci/da8xxevm/da850evm.c. When u-boot is used in conjunction with the UBL (user boot loader, see doc/README.davinci) on this board, the UART2 peripheral is already turned on by UBL at the time u-boot is started. Hence, the wrong initialization sequence is not noticed by most users. However, if UBL is not used, u-boot must power on the peripheral before using it. This patch adds a board_early_init_f() function for the LPSC configuration to the da850evm board configuration. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27da830: add support for NAND boot modeManjunath Hadli
Add support for enabling NAND boot mode in configuration file and add correspanding pinmux support, nand initialize function in board file. The size required for environment variables not more than 10KB the CONFIG_ENV_SIZE is set to 10KB from (512 << 10). Acked-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-22build: add missing $(AR)->$(cmd_link_o_target) updateMike Frysinger
Seems people fixed their files to use libfoo.o, but didn't actually update the creation targets to use $(cmd_link_o_target). Update the rest of the Makefile's found with grep. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-09-10ARM: hawkboard: fix compilation of nand_splWolfgang Denk
Fix build problem: nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c: In function 'board_init_f': nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c:132: warning: implicit declaration of function 'nand_boot' nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c:133: warning: 'noreturn' function does return Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-09-07da8xxevm: Fix warning: unused variable 'val'Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
2011-09-04da850: modifications for Logic PD Rev.3 AM18xx EVMNagabhushana Netagunte
AHCLKR/UART1_RTS/GP0[11] pin needs to be configured for NOR to work on Rev.3 EVM. When GP0[11] is low, the SD0 interface will not work, but NOR flash will. Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04da850: add support to wake up DSP during board initNagabhushana Netagunte
add support for DSP wake-up by default on DA850/OMAP-L138 during board initialization. Enable hwconfig environment and added extra env setting through CONFIG_EXTRA_ENV_SETTINGS. To prevent DSP from being woken up,set the environment variable as, set hwconfig "dsp:wake=no" Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04da850: add NOR boot mode supportNagabhushana Netagunte
Add pin-mux support for NOR in board file and correspanding macros to use NOR boot mode in configuration file. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-08Add Ethernet hardware MAC address framework to usbnetSimon Glass
Built-in Ethernet adapters support setting the mac address by means of a ethaddr environment variable for each interface (ethaddr, eth1addr, eth2addr). This adds similar support to the USB network side, using the names usbethaddr, usbeth1addr, etc. They are kept separate since we don't want a USB device taking the MAC address of a built-in device or vice versa. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-03DaVinci: rename gpio_defs.h to gpio.hLaurence Withers
In preparation for a generic GPIO driver for the DA8xx processors, rename <asm/arch/gpio_defs.h> to <asm/arch/gpio.h> and fix up all files which include it. Signed-off-by: Laurence Withers <lwithers@guralp.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-05-11da850evm: fix NAND WSTROBE and TA timingsBen Gardiner
The current NAND timings, introduced in commit a3f88293ddd13facd734769c1664d35ab4ed681f da850evm: setup the NAND flash timings , incorrectly set WSTROBE and TA to 0. A more recent inspection of the values set by the Linux kernel indicates that these should be set to 1. Set the WSTROBE and TA field of the EMIFA cycle-count timings configuration to 1 to match the values set by linux. Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> CC: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> CC: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-11ea20: fix libea20.o not foundBen Gardiner
This patch fixes ea20 after commit 6d8962e814c15807dd6ac5757904be2a02d187b8 where $(obj)lib$(BOARD).a was changed to $(obj)lib$(BOARD).o in almost all the Makefiles except ea20, probably due to merge path of the changes in 2010.12. Signed-off-by: Ben Gardiner<bengardiner@nanometrics.ca> CC: Sebastien Carlier <sebastien.carlier@gmail.com> Acked-by : Stefano Babic <sbabic@denx.de>
2011-02-02DaVinci DM6467: Enhance board SupportSandeep Paulraj
Support for DM6467 was incomplete and the build failed as well. Patches were sent to the list but have not been added. This enhances the DM6467 support. Some more patches will need to be sent to bring it in line with what is available in internal TI trees Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02DM365: Fix Build ErrorSandeep Paulraj
After the merger of the next branch, the DM365 was broken. A function used only by DA8xx based SOCs was being incorrectly called. So fix it. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02DaVinci DM365: Adding MMC/SD support for DM365 EVMSandeep Paulraj
The patch adds support for MMC/SD in the DM365 EVM Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02DaVinci DM355: Adding MMC/SD support for DM355 EVMSandeep Paulraj
The patch adds support for MMC/SD in the DM355 EVM Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30Davinci: add support for the ea20 boardStefano Babic
This board uses the OMAP-L138 SOM stacked on a custom baseboard. It supports SPI Flash, Ethernet with RMII. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30Davinci 8xx: Move common functions to share codeStefano Babic
As more Davinci 8xx board can be added, move common code to be shared between boards. * rebased ontop of Sugosh's patches * moving the HAWKBOARD_KICK{0,1}_UNLOCK defines to arch/arm/include/asm/arch-davinci/davinci_misc.h from to arch/arm/include/asm/arch-davinci/da8xx_common.h * don't define dram functions in PRELOADER * move sync_env_enetaddr into existing EMAC ifdef * use misc.c in hawkboard nand_spl Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30da850: Add RMII support for EMACSudhakar Rajashekhara
This patch is a port of the work by Sudhakar Rajeshekhara in commit ab3effbcad8851cc65dc5241a01c064d2030a3b2 of git://arago-project.org/git/people/sandeep/u-boot-davinci.git. The da850 UI board has on it an RMII PHY which can be used if the MDC line to the MII PHY on the baseboard is disabled and the RMII PHY is enabled by configuring the values of some GPIO pins on the IO expander of the UI board. This patch implements disabling that line via GPIO2[6], configuring the UI board's IO expander and setting only the pinmux settings that are needed for RMII operation. Tested on da850evm by adding a define for CONFIG_DRIVER_TI_EMAC_USE_RMII. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> CC: Sandeep Paulraj <s-paulraj@ti.com> CC: Ben Warren <biggerbadderben@gmail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30Add board support for hawkboardSughosh Ganu
The patch adds basic board support for TI's OMAP-L138 based Hawkboard. This board is pretty similar to the da850 EVM. Support for nand and network access is added in this version. The following bootup procedure is used. At reset, the Rom Boot Loader(RBL), initialises the ddr and the nand controllers and copies the second stage bootloader(nand_spl) to RAM. The secondary bootloader then copies u-boot from a predefined location in the nand flash to the RAM, and passes control to the u-boot image. Three config options are supported * hawkboard_config - Used to create the u-boot.bin. Tftp the u-boot.bin image to the RAM from u-boot, and flash to the nand flash at address 0xe0000. * hawkboard_nand_config - Used to generate the secondary bootloader(nand_spl) image. This creates an elf file u-boot-spl under nand_spl/. Create an AIS signed image using this file, and flash it to the nand flash at address 0x20000. The ais file should fit in one block. * hawkboard_uart_config - This is same as the first image, but with the TEXT_BASE as expected by the RBL(0xc1080000). Create the AIS Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-28Move and rename common headers from underSughosh Ganu
board/davinci. Move the davinci common headers to the architecture specific include file path. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-19DA850 EVM: passing maximum clock rate information to kernelSekhar Nori
The TI DA850/OMAP-L138/AM18x EVM can be populated with devices having different maximum allowed CPU clock rating. The maximum clock the chip can support can only be determined from the label on the package (not software readable). Introduce a method to pass the maximum allowed clock rate information to kernel using ATAG_REVISION. The kernel uses this information to determine the maximum cpu clock rate reachable using cpufreq. Note that U-Boot itself does not set the CPU clock rate. The CPU clock is setup by a primary bootloader ("UBL"). The rate setup by UBL could be different from the maximum clock rate supported by the device. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
