path: root/board/davedenx
2011-11-11qong: Use generic function for configuring GPR registerFabio Estevam
Use generic function for configuring GPR register. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-03qong: remove unneeded IOMUX settingsFabio Estevam
On qong board some of the USBH2 pins are set via GPR register, so don need to setup the IOMUX for each pin individually. Other than that, these pins should not be configured as primary function because the primary function selects SSI functionality. Let GPR register do the work and remove the unneeded IOMUX setup. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-03qong: Use mx31_set_gpr to setup USBH2 pinsFabio Estevam
Instead of writing directly to the GPR register, use mx31_set_gpr to setup USBH2 pins. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-10-27imx: fix coding styleFabio Estevam
Fix checkpatch warning and errors in several i.MX related files. While at it also address a checkpatch warning at arch/arm/cpu/armv7/mx5/soc.c regarding the usage of extern in a C file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-10-27MX3: qong: use new pmic driverStefano Babic
Switch to new pmic generic driver. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-27mx31: provide readable WEIM CS accessorHelmut Raiger
setup_weimcs() and some macros are added to support the setup for i.MX31 WEIM chip selects. As a compromise between verbosity and readability an ASCII-art'ish bit comment is used instead of bitfields. All i.MX31 boards have been patched to use this approach using a helper program to verify the changes. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-04MX31: QONG: make use of GPIO frameworkStefano Babic
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-06-21MX31: QONG: drop config.mkStefano Babic
Remove obsolete config.mk from QONG board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-04-27IMX: MX31: Cleanup include files and drop nasty #ifdef in driversStefano Babic
As exception among the i.MX processors, the i.MX31 has headers without general names (mx31-regs.h, mx31.h instead of imx-regs.h and clock.h). This requires several nasty #ifdef in the drivers to include the correct header. The patch cleans up the driver and renames the header files as for the other i.MX processors. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-04-27MX31: qong: add watchdogStefano Babic
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-17Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-10-13MX31: Add USB Host support to the QONG boardStefano Babic
2010-10-13MX31: Add support to update FPGA bitstreamStefano Babic
The patch adds the possibility to update the QONG FPGA (a Lattice XP2-5E) with u-boot using some GPIOs to drive the JTAG interface. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-11Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-09-29Use common function to set GPIOs for MX3 and MX5Stefano Babic
The patch adds support for setting gpios to the MX51 processor and change name to the corresponding functions for MX31. In this way, it is possible to get rid of nasty #ifdef switches related to the processor type. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-09-25fsl_diu_fb: further refactoring of FSL DIU codeAnatolij Gustschin
Move common code to the fsl_diu_fb.c file and remove obsolete code from board files (aria, mpc8610hpcd and pdm360ng). Move fsl_diu_fb.h file to the include directory. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-09-19ARM: implement relocation for ARM11Heiko Schocher
Change the implementation for ARM11 to relocate the code to an arbitrary address in RAM. Tested on the qong board. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-05-05MX31: Add support for PMIC to the QONG moduleStefano Babic
Add support for the PMIC (MC13783) controller and enables charging of the RTC battery. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-30MX31: Removed erroneous board name from QONGStefano Babic
QONG is a module that can be installed on several boards, not only on the QONG-EVB manufactured by Dave srl. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-30MX31: Support 128MB RAM on QONG moduleStefano Babic
The QONG module can be downsized and delivered with 128MB instead of 256MB. The patch adds run time support for the two different memory configurations. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-30MX31: Add support for NAND to QONG boardStefano Babic
The NAND device is connected to the FPGA of the QONG board and not to the NFC controller. For this reason, the FPGA must be set and initialized before accessing to the NAND itself. Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-12-085xxx, fdt: move fdt_fixup_memory() to cpu.c fileHeiko Schocher
u-boot updates, before starting Linux, the memory node in the DTS. As this is a "standard" feature, move this functionality to the cpu.c file for mpc5xxx and mpc512x processors. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-09-25mpc512x: Streamlined fixed_sdram() init sequence.Martha M Stan
Signed-off-by: Martha M Stan <mmarx@silicontkx.com> Minor cleanup: Re-ordered default_mddrc_config[] to have matching indices. This allows to use the same index "N" for source and target fields; before, we had code like this out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]); which always looked like a copy & paste error because 2 != 3. Also, use NULL when meaning a null pointer. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-14aria: enable NAND flash supportWolfgang Denk
2009-07-14MPC512x: factor out common codeWolfgang Denk
Now that we have 3 boards for the MPC512x it turns out that they all use the very same fixed_sdram() code. This patch factors out this common code into cpu/mpc512x/fixed_sdram.c and adds a new header file, include/asm-ppc/mpc512x.h, with some macros, inline functions and prototype definitions specific to MPC512x systems. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-06-12MPC512x: add support for ARIA boardWolfgang Denk
ARIA is a MPC5121E based COM Express module by Dave/DENX. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: John Rigby <jcrigby@gmail.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-02-22Coding Style cleanup; update CHANGELOGWolfgang Denk
2009-02-10qong: support for Dave/DENX QongEVB-LITE boardIlya Yanok
This patch adds support for Dave/DENX QongEVB-LITE i.MX31-based board. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
