path: root/board/cm4008
2011-11-16board/cm4008/flash.c: Fix GCC 4.6 warningsAnatolij Gustschin
Fix: flash.c: In function 'flash_erase': flash.c:209:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] flash.c: In function 'write_data': flash.c:373:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-10cm4008, cm41xx: fix build warningsWolfgang Denk
Fix these: cm4008.c: In function 'board_eth_init': cm4008.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' cm41xx.c: In function 'board_eth_init': cm41xx.c:79: warning: implicit declaration of function 'ks8695_eth_initialize' While we are at it, sort include list in netdev.h Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10KS8695: convert KS8695 eth driver to CONFIG_MULTI_ETHGreg Ungerer
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type driver. Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM4008: fix signedness of env bootargs string pointerGreg Ungerer
The pointer to the flash based bootargs should be a "char *", not unsigned. Fixes: cm4008.c: In function ‘env_flash_cmdline’: cm4008.c:67: warning: pointer targets in passing argument 2 of ‘setenv’ differ in signedness Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM4000: fix broken flash base for OpenGear boardsGreg Ungerer
Use _bss_start_ofs as the size of the boot loader code+data that we want to protect in the flash. This replaces use of the no longer defined _armboot_start. Fixes: flash.c: In function ‘flash_init’: flash.c:75: error: ‘_bss_start’ undeclared (first use in this function) flash.c:75: error: (Each undeclared identifier is reported only once flash.c:75: error: for each function it appears in.) flash.c:75: error: ‘_armboot_start’ undeclared (first use in this function) Signed-off-by: <greg.ungerer@opengear.com>
2011-07-16Timer: Fix misuse of ARM *timer_masked() functions outside arch/armGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2005-05-19Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the OpenGear CM4008 board
