path: root/board/bf537-stamp
2012-02-12Blackfin: bf537-stamp: drop board reset workaroundMike Frysinger
The bf537-stamp shouldn't need this SPI flash workaround. It was added by accident a long time ago through a convoluted series of steps which originated from a customer board (not the bf537-stamp). So drop it to keep people from incorrectly adding it to their own boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: post: generalize led/button tests with GPIOsMike Frysinger
Make it easy for any Blackfin board to enable led/push button tests. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: bf537-stamp: drop uart/flash post testsMike Frysinger
The flash code has been generalized for everyone, and the uart stub is simply useless. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: bf537-stamp: convert to gpio post hotkeyMike Frysinger
No need for our custom implementations now that common code supports the generic gpio layer. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-03Blackfin: boards: build zlib dir with -O2Mike Frysinger
Now that the zlib code has been relocated to a dedicated subdir, make sure we still build it with -O2 for boards that want speed over size. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: unify bootmode based LDR_FLAGS setupMike Frysinger
Unify this convention for all Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: drop CONFIG_SYS_TEXT_BASE from boardsMike Frysinger
We don't want/use this value for Blackfin boards, so punt it and have the common code error out when people try to use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bf537-stamp: post: update old MMR style macrosMike Frysinger
The old MMR defines are being scrubbed, so convert the driver to use the new standard helper macros. For the GPIO MMR usage, convert to the new GPIO framework. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-07-05Blackfin: bf537-stamp: use common spi boot workaround codeMike Frysinger
The common gpio code provides a function for handling the spi boot workaround logic, so switch over to that rather than bang on the gpio MMRs directly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: unify custom gpio commandsMike Frysinger
Now that we have a unified gpio layer, the misc partial gpio commands can be unified and made complete (support all possible gpios). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: bf537-stamp: drop old spi_flash driverMike Frysinger
The new common spi framework and spi flash subsystem provides all the same functionality as the old Blackfin-specific driver, so punt the old one as it has been sticking around long enough. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Change directory-specific CFLAGS to use full pathPeter Tyser
Previously, a specific file or directory could be compiled with custom CFLAGS by adding a Makefile variable such as: CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c> or CFLAGS_lib = <custom flags for lib directory> This method breaks down once multiple files or directories share the same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>. This change allows finer grained control which we need once we move lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this change all lib/ directories would share the same custom CFLAGS. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: kill off useless initdram() usageMike Frysinger
While the initdram() function makes sense on some arches, it doesn't for Blackfin systems as it's always implemented the same way. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-07mtd: nand: new base driver for memory mapped nand devicesMike Frysinger
The BF537-STAMP Blackfin board had a driver for working with NAND devices that are simply memory mapped. Since there is nothing Blackfin specific about this, generalize the driver a bit so that everyone can leverage it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-06-15Blackfin: enable -O2 in lib_generic/ for ADI/Bluetechnix boardsMike Frysinger
Building the compression code in lib_generic/ with -O2 rather than -Os gives a nice speed boost without too much code size increase. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-02Blackfin: bf537-stamp: split CF/IDE code out into dedicated cf-ide.cMike Frysinger
2009-03-24Blackfin: bf537-stamp: split post code out into dedicated post.cMike Frysinger
2009-03-24Blackfin: add support for S25FL128 partsMike Frysinger
2009-03-24Blackfin: overhaul SPI flash handling to speed things upMike Frysinger
2009-03-24Blackfin: add support for SST SPI flashesMike Frysinger
2009-03-24Blackfin: add hack for crappy m25p80Mike Frysinger
2009-03-24Blackfin: bf537-stamp: rewrite MAC-in-flash handlingMike Frysinger
Use the common net eth functions to setup the env/global data with the MAC address, and properly handle the case where CONFIG_SYS_NO_FLASH is defined. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-23Blackfin: kill off LDR jump blockMike Frysinger
The Boot ROM uses EVT1 as the entry point so set that rather than having to use a tiny jump block in the default EVT1 location. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-23Blackfin: bf537-stamp: move CONFIG_POST handling to COBJS-$(...)Mike Frysinger
2009-02-05Blackfin: move default boot SPI CS to common codeMike Frysinger
Move the default SPI CS that we boot from into common code so that it can be used in other SPI drivers and environment settings. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-02Blackfin: add port muxing for BF51x SPIMike Frysinger
2009-02-01Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2009-01-28Move is_valid_ether_addr() to include/net.hMike Frysinger
Import the is_valid_ether_addr() function from the Linux kernel. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28Blackfin: fixup misc warnings such as printf's and missing castsMike Frysinger
2009-01-28Blackfin: convert old boards to use COBJS-y Makefile styleMike Frysinger
2009-01-28Blackfin: set default boot SPI CS for BF538/BF539Mike Frysinger
The BF538/BF539 use CS2 for booting off of rather than CS1 like newer Blackfin parts. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: tighten up post memory coding styleMike Frysinger
No functional changes here; just cleanup code style a bit. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Blackfin: bf537-stamp nand: fix more style errors in previous commitMike Frysinger
2009-01-28Blackfin: drop dead/wrong debug code in initdram()Mike Frysinger
The DEBUG code in initdram() is quite old and was never really useful, so just drop it altogether. Common Blackfin debug code does a better job. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-07bf537-stamp/nand: fix board_nand_init prototypeMike Frysinger
The board_nand_init() function should return an int, not void. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix out-of-tree building with ldscriptsMike Frysinger
Many of the Blackfin board linker scripts are preprocessed, so make sure we output the linker script into the build tree rather than the source tree. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: fix linker scripts to work with --gc-sectionsMike Frysinger
Make sure all .text sections get pulled in and the entry point is properly referenced so they don't get discarded when linking with --gc-sections. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-07Blackfin: set proper LDRFLAGS for parallel booting LDRsMike Frysinger
In order to boot an LDR out of parallel flash, the ldr utility needs a few flags to tell it to generate the right header. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
