path: root/board/actux4
2011-06-23update/fix AcTux4 boardMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-18add AcTux-4 board supportMichael Schwingen
