path: root/board/LEOX
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-22Remove deprecated 'autoscr' command/variablesPeter Tyser
The more standard 'source' command provides identical functionality to the autoscr command. Environment variable names/values on the MVBC_P, MVBML7, kmeter1, mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'. The 'autoscript' and 'autoscript_uname' environment variables are also removed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de>
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2006-11-30Code cleanup.Wolfgang Denk
