path: root/arch/nds32
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-02-28nds32/board.c: add PCI prompt at boot upMacpaul Lin
add PCI prompt at boot up for probing PCI device Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-02-28nds32/ag101/watchdog.S: add linkage supportMacpaul Lin
Add linkage support to watchdog.S. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-02-28nds32: add linkage supportMacpaul Lin
Add linkage support. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-23nds32/ag101: clean up for SoC related codeMacpaul Lin
Remove unneccessary codes. 1. Clean up for cpu related code. 2. Clean up for timer related code. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-18nds32/lib: add ide generic supportMacpaul Lin
Add ide generic support. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-18nds32: enhance io.h for compatibility with periphalsMacpaul Lin
Enhance io.h for periphals origin design on x86 systems. For example, pci, ide, etc. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-10adp-ag101p: Add SoC and board support of ag101pMacpaul Lin
Add softcore SoC ag101p and the board adp-ag101p support. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-09nds32: fix data section of linker scriptMacpaul Lin
Make linker script handles .data.rel sections. Signed-off-by: Macpaul Lin <macpaul@andestech.com> Tested-by: Macpaul Lin <macpaul@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-11-01nds32: asm/io.h: add __iormb __iowmb and inline io supportMacpaul Lin
1. This patch add required __iormb and __iowmb to io.h. This also fix some misbehavior to periphal drivers. This io.h has been fixed with referencing arm/include/asm/io.h. 2. This patch replaced macro writeb and readb into inline function. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-01nds32: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentMacpaul Lin
Add ARCH_DMA_MINALIGN definition to asm/cache.h Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-01nds32: Use getenv_ulong() in place of getenv(), strtoulMacpaul Lin
This changes the board code to use the new getenv_ulong() function. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22nds32/lib: add generic funcs in NDS32 libMacpaul Lin
Add Makefile, board.c, interrupts.c and bootm.c functions to nds32 architecture. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22nds32/ag101: cpu and init funcs of SoC ag101Macpaul Lin
SoC ag101 is the first chip using NDS32 N1213 cpu core. Add header file of device offset support for SoC ag101. Add main function of SoC ag101 based on NDS32 n1213 core. Add lowlevel_init.S and other periphal related code. This version of lowlevel_init.S also replace hardcode value by MARCO defines from the GPL version andesboot for better code quality. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22nds32/core N1213: NDS32 N12 core family N1213Macpaul Lin
Add N1213 cpu core (N12 Core family) support for NDS32 arch. This patch includes start.S for the initialize procedure of N1213. Start procedure: start.S will start up the N1213 CPU core at first, then jump to SoC dependent "lowlevel_init.S" and "watchdog.S" to configure peripheral devices. Signed-off-by: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Greentime Hu <greentime@andestech.com>
2011-10-22nds32: add header files support for nds32Macpaul Lin
Add generic header files support for nds32 architecture. Cache, ptregs, data type and other definitions are included. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
