Add initial Colibri VF61 support based off Timesys' implementation for
Freescale's Vybrid Tower System TWR-VF65GS10:
- New machine ID.
- Default UART_A on SCI0.
- ESDHC2 only.
- 8-bit NAND.
- No quad SPI.
- FEC1 only.
- Enabled command line editing.
- PLL5 based RMII clocking (e.g. no external crystal).
- UART_A, UART_B and UART_C I/O muxing.
- Increase the available space for the U-Boot binary to half a megabyte
by booting from gfxRAM rather than sysRAM0.
- Integrate factory configuration block handling for hardware version,
MAC address and serial number to be passed to Linux.
- The U-Boot environment is stored in NAND flash.
- Fix long standing boot hang issue introduced by Freescale's Vybrid
1.1 silicon.
- Proper 256 MB Nanya DDR3 RAM timings.
Tested on early Colibri VF61 prototypes V1.0b and V1.0c using SD card
(mandatory for initial loading) as well as NAND boot.
Add initial Colibri VF50 support based off Timesys' implementation for
- New machine ID.
- ESDHC2 only.
- 8-bit NAND.
- No quad SPI.
- FEC1 only.
Tested on early Colibri VF50 prototypes V1.0a using SD card (mandatory
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
This patch adds the minimal support for OMAP5. The platform and machine
specific headers and sources updated for OMAP5430.
OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP architecture.
It's a dual core SOC with GIC used for interrupt handling and SCU for cache
coherency.
Also moved some part of code from the basic platform support that can be made
common for OMAP4/5. Rest is kept out seperately. The same approach is followed
for clocks and emif support in the subsequent patches.
Signed-off-by: sricharan <r.sricharan@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This commit updates the mach-types based on the latest in Linus's head
Cc: Detlev Zundel <dzu@denx.de>
in linus's head
This commit updates the mach-types for ARM
This patch updates the mach-types.h based on the latest linux kernel
Signed-off-by: Thomas Weber <weber@corscience.de>
Fetched from http://www.arm.linux.org.uk/developer/machines/download.php
And built with
repo http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
commit 3defb2476166445982a90c12d33f8947e75476c4
Signed-off-by: Tom <Tom@bumblecow.com>
And built with
commit 257dab81413b31b8648becfe11586b3a41e5c29a
And built with
commit 85b3cce880a19e78286570d5fd004cc3cac06f57
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
This helps to clean up the include/ directory so that it only contains
non-architecture-specific headers and also matches Linux's directory
layout which many U-Boot developers are already familiar with.
