path: root/Kconfig
2020-06-15config: qemu: increase SYS_MALLOC_F_LENHeinrich Schuchardt
Several configutation options require additional memory before relocation: * CONSOLE_RECORD * LOG * RSA The current default of 0x400 is too small to encompass them all. Increase the value of SYS_MALLOC_F_LEN to 0x2000 for ARCH_QEMU. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-05-15rename symbol: CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOODTrevor Woerner
Have this symbol follow the pattern of all other such symbols. This patch also removes a TODO from the code. Reviewed-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-05-01malloc: dlmalloc: add an ability for the malloc to be re-init/init multiple ↵Marek Bykowski
times Malloc gets initialized with a call to mem_malloc_init() with the address the allocation starts to and its size. Currently it is not possible to move the malloc from one memory area to another as the malloc would eventually fail. This patch adds in the ability to re-init the malloc with the updated start address and the size. One of the use cases of this feature is SPL U-Boot running from within the static memory and calling to malloc init from within board_init_f(): arch/arm/cpu/armv8/start.S:reset vector arch/arm/cpu/armv8/start.S:main() arch/arm/lib/crt0_64.S:board_init_f() board/<my_board>/common/spl.c:board_init_f() board/<my_board>/common/spl.c:mem_malloc_init((ulong)CONFIG_SYS_SPL_MALLOC_START, CONFIG_SYS_SPL_MALLOC_SIZE); Shortly after the DDR (main) memory is init and ready we call to malloc init again but this time with the start address in the DDR memory and a much greater size for moving the allocation off the static to the DDR memory: board/<my_board>/common/spl.c:mem_malloc_init((ulong)CONFIG_SPL_MALLOC_OFFSET, CONFIG_SPL_MALLOC_SIZE); Where CONFIG_SYS_SPL_MALLOC_START and CONFIG_SPL_MALLOC_OFFSET are the start addresses of the malloc in the static and DDR memories respectively and CONFIG_SYS_SPL_MALLOC_SIZE=SZ_16K and CONFIG_SPL_MALLOC_SIZE=SZ_2M are the sizes of the mallocs in these memories. Note, now we have a much greater memory, enlarging from 16K to 2M, available for allocation. There is an alternative approach already existing in U-Boot with the use of an early (simplified) malloc and the proper (dlamalloc) malloc however necessitating managing the two mallocs whereas this approach proposes using a single dlmalloc. Signed-off-by: Marek Bykowski <marek.bykowski@gmail.com>
2020-04-24actions: Move defconfig options to KconfigAmit Singh Tomar
This patch moves some of the config options from bubblegum_96_defconfig to respective Kconfig files. Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
2020-04-24common: image_sign_info helper functions in SPLHeinrich Schuchardt
Do not build image_sign_info helper functions in SPL if not needed. Fixes: b983cc2da0ba ("lib: rsa: decouple rsa from FIT image verification") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-16Kconfig: update reference to README.x86Patrick Delaunay
Update reference in Kconfig detected by scripts/documentation-file-ref-check README.x86 => doc/arch/x86.rst Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-07Merge tag 'xilinx-for-v2020.07' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next Xilinx changes for v2020.07 common: - Align ENV_FAT_INTERFACE - Fix MAC address source print log - Improve based autodetection code xilinx: - Enable netconsole Microblaze: - Setup default ENV_OFFSET/ENV_SECT_SIZE Zynq: - Multiple DT updates/fixes - Use DEVICE_TREE environment variable for DTB selection - Switch to single zynq configuration - Enable NOR flash via DM - Minor SPL print removal - Enable i2c mux driver ZynqMP: - Print multiboot register - Enable cache commands in mini mtest - Multiple DT updates/fixes - Fix firmware probing when driver is not enabled - Specify 3rd backup RAM boot mode in SPL - Add SPL support for zcu102 v1.1 and zcu111 revA - Redesign debug uart enabling and psu_init delay - Enable full u-boot run from EL3 - Enable u-boot.itb generation without ATF with U-Boot in EL3 Versal: - Enable distro default - Enable others SPI flashes - Enable systems without DDR Drivers: - Gem: - Flush memory after freeing - Handle mdio bus separately - Watchdog: - Get rid of unused global data pointer - Enable window watchdog timer - Serial: - Change reinitialization logic in zynq serial driver Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-03arch: Add explicit linker script for u-boot-elfMichal Simek
Commit f4dc714aaa2d ("arm64: Turn u-boot.bin back into an ELF file after relocate-rela") introduce REMAKE_ELF option to recreate u-boot.elf from u-boot -> u-boot.bin + DT -> u-boot.elf. The best is to ilustrate it from make V=1 output cat u-boot-nodtb.bin dts/dt.dtb > u-boot-dtb.bin cp u-boot-dtb.bin u-boot.bin aarch64-linux-gnu-objcopy -I binary -B aarch64 -O elf64-littleaarch64 u-boot.bin u-boot-elf.o aarch64-linux-gnu-ld.bfd u-boot-elf.o -o u-boot.elf --defsym="_start"=0x8000000 -Ttext=0x8000000 Last command has no explicit linker script passed that's why toolchain internal linker script is used. In Binutils 2.32 case it contains SIZEOF_HEADERS symbol which has changed behavior by commit https://sourceware.org/git/?p=binutils-gdb.git;a=commit;h=64029e93683a266c38d19789e780f3748bd6a188 which result in situation that program headers has changed from (xilinx_zynqmp_mini_defconfig) Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flags Align LOAD 0x0000000000010000 0x00000000fffc0000 0x00000000fffc0000 0x0000000000018918 0x0000000000018918 RW 0x10000 to Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flags Align LOAD 0x0000000000000000 0x00000000fffb0000 0x00000000fffb0000 0x0000000000028918 0x0000000000028918 RW 0x10000 Xilinx tools like XSDB or Bootgen are using program headers for loading ELF to the right location and by above binutils change ELF is loaded to incorrect location. The patch is explicitly use u-boot-elf.lds (just cat now) for u-boot.elf recreation which is called when REMAKE_ELF is setup. By purpose u-boot-elf.lds doesn't contain OUTPUT_FORMAT/OUTPUT_ARCH to be able to use by all archs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-By: Álvaro Fernández Rojas <noltari@gmail.com>
2020-03-18sunxi: Move common defconfig options to KconfigAndre Przywara
Some config symbols are found in *almost* every _defconfig file for Allwinner boards, because those options are actually a platform choice, and not a per-board decision. Some of these options are older, some have recently been added. Move those options to be set for all Allwinner boards in their respective Kconfig files. The rationales are as follows: - NR_DRAM_BANKS: All Allwinner SoC map DRAM at one contiguous region of address space only, starting at 1 GB. So it's always one bank. - SPL_{DOS,EFI}_PARTITION: The Allwinner SPL does only support raw MMC accesses, we don't care about filesystems or partitions in there, so there is no need to define those symbols at all. - USE_PREBOOT: We start USB early when a keyboard is configured, using the preboot env variable, so we need to set this variable. - SYS_RELOC_GD_ENV_ADDR: We don't specify any ENV_ADDR, so need this symbol to be set (according to 8d8ee47e03e). - SYS_USB_EVENT_POLL_VIA_INT_QUEUE: According to commit eab9433aa55428, specifying this reduces the latency of the USB keyboard handling, so this was formerly enabled in config headers for all Allwinner boards. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <mripard@kernel.org> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-03-16kconfig / kbuild: re-sync with Linux 4.18Tom Rini
Align Kconfig and Kbuild logic to Linux 4.18 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit e91610da7c8a ("kconfig: re-sync with Linux 4.17-rc4"). A very small number of changes upstream since our sync with v4.17-rc4 that exist in the v4.18 release have already been applied here and have been omitted from the list in this commit (and are readily available in our own git history). The imported Linux commits are: [From prior to v4.17-rc4] 39a33ff80a25 kbuild: remove cc-option-align db547ef19064 Kbuild: don't add obj tree in additional includes b999596b963a Kbuild: don't add ../../ to include path [From v4.17 to v4.18] b3aa58d2e85d fixdep: suppress consecutive / from file paths in dependency list files 74656b682902 kbuild: disable new dtc graph and unit-address warnings 74d931716151 genksyms: remove symbol prefix support e6ecfb45072c kbuild: do not display CHK for filechk 0b669a5076fd kconfig: refactor Qt package checks for building qconf b464ef583dc7 kconfig: refactor GTK+ package checks for building gconf 1c5af5cf9308 kconfig: refactor ncurses package checks for building mconf and nconf 694c49a7c01c kconfig: drop localization support 96f60dfa5819 trace: Use -mcount-record for dynamic ftrace bb222ceeb327 kconfig: remove string expansion in file_lookup() 96d8e48da55a kconfig: remove string expansion for mainmenu after yyparse() 5b31a9746756 kconfig: remove sym_expand_string_value() 137c0118a900 kconfig: make default prompt of mainmenu less specific e298f3b49def kconfig: add built-in function support 2fd5b09c201e kconfig: add 'shell' built-in function 9de071536c87 kconfig: begin PARAM state only when seeing a command keyword 9ced3bddec08 kconfig: support user-defined function and recursively expanded variable 1175c02506ff kconfig: support simply expanded variable ed2a22f277c6 kconfig: support append assignment operator 82bc8bd82e5c kconfig: expand lefthand side of assignment statement 1d6272e6fe43 kconfig: add 'info', 'warning-if', and 'error-if' built-in functions a702a6176e2f kconfig: add 'filename' and 'lineno' built-in variables 915f64901eb3 kconfig: error out if a recursive variable references itself 2bece88f89fa kconfig: test: add Kconfig macro language tests 21c54b774744 kconfig: show compiler version text in the top comment 59f7b5847b0c kbuild: $(CHECK) doesnt need NOSTDINC_FLAGS twice 145167650b96 kbuild: add endianness flag to CHEKCFLAGS 1f2f01b122d7 kbuild: add machine size to CHECKFLAGS d6a0c8a1326b kconfig: Add testconfig into make help output bb6d83dde191 kbuild: Move last word of nconfig help to the previous line 8593080c0fcf kconfig: fix localmodconfig ed7d40bc67b8 tracing: Fix SKIP_STACK_VALIDATION=1 build due to bad merge with -mrecord-mcount b2d00d7c61c8 kconfig: fix line numbers for if-entries in menu tree ecd53ac2f2c6 kconfig: handle P_SYMBOL in print_symbol() 73d1c580f92b kconfig: loop boundary condition fix 48f6e3cf5bc6 kbuild: do not drop -I without parameter bd412d81b7ea kbuild: .PHONY is not a variable, but PHONY is 6916162c7308 kbuild: remove duplicated comments about PHONY Cc: Masahiro Yamada <masahiroy@kernel.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2020-03-12lib: rsa: decouple rsa from FIT image verificationAKASHI Takahiro
Introduce new configuration, CONFIG_RSA_VERIFY which will decouple building RSA functions from FIT verification and allow for adding a RSA-based signature verification for other file formats, in particular PE file for UEFI secure boot. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-02-04Kconfigs: layerscape: use a convenient default value for SYS_MALLOC_F_LENBiwen Li
The default value of CONFIG_SYS_MALLOC_F_LEN (0x400) leaves U-Boot with not enough memory to load i2c driver before relocate, causing it to hang. Change the default value of CONFIG_SYS_MALLOC_F_LEN for below SoCs, - LS1012A - LS1021A - LS1043A - LS1046A Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-17mkimage: fit: add support to encrypt image with aesPhilippe Reynes
This commit add the support of encrypting image with aes in mkimage. To enable the ciphering, a node cipher with a reference to a key and IV (Initialization Vector) must be added to the its file. Then mkimage add the encrypted image to the FIT and add the key and IV to the u-boot device tree. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-01-14arm64: zynqmp: Add support for u-boot.itb generation with ATFMichal Simek
Follow i.MX, Sunxi, RISC-V and Rockchip to generate u-boot.itb which includes U-Boot proper, ATF and DTBs in FIT format. ZynqMP supports FIT for quite a long time but with using out of tree solution. The patch is filling this gap. Tested on zcu102, zcu104 and zcu100/Ultra96. zcu100/Ultra96 v2.2 ATF build by: make DEBUG=0 ZYNQMP_CONSOLE=cadence1 RESET_TO_BL31=1 PLAT=zynqmp bl31 Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-07spl: fit: allocate a temporary buffer to load the overlaysJean-Jacques Hiblot
If the node describing an overlay does not specify a load address, it will be loaded at the address previously used. Fixing it by allocating a temporary buffer that will be used as a default load address. By default, the size of the buffer is 64kB which should be plenty for most use cases. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-07spl: fit: Add support for applying DT overlayMichal Simek
doc/uImage.FIT/overlay-fdt-boot.txt is describing how to create FIT image with DT overlays in it. Add support for this feature to SPL. Here is the ZynqMP fragment where dtb points to full DT and dtbo is overlay which should be applied on the top of dtb. config { description = "ATF with full u-boot overlay"; firmware = "atf"; loadables = "uboot"; fdt = "dtb", "dtbo"; }; The whole feature depends on OF_LIBFDT_OVERLAY which is adding +4kB code and 0 for platforms which are not enabling this feature. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-15x86: Add an option to control the position of U-BootSimon Glass
The existing work-around for positioning U-Boot in the ROM when it actually runs from RAM still exists and there is not obvious way to change this. Add a proper Kconfig option to handle this case. This also adds a new bool property to indicate whether CONFIG_SYS_TEXT_BASE exists. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-06cmd: sysboot: Create a sysboot command dedicated filePatrice Chotard
Extract all sysboot command related code from pxe.c to new sysboot.c Update Kconfig to insure that DISTRO_DEFAULT select new CMD_SYSBOOT command. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-11-23Kconfig: Enable building of u-boot.itb on Rockchip platformKever Yang
For all the Rockchip SoCs with SPL_LOAD_FIT enable, we need to build u-boot.itb with U-Boot proper and ATF/OPTEE. All the Rockchip boards with SPL_LOAD_FIT now supports FIT generator to get ATF/OPTEE binary path from environment and pass the build even if no ATF/OPTEE binary exist, so we can enable this feature for the rockchip platform. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-07Kconfig add config ERR_PTR_OFFSETSimon Goldschmidt
Some U-Boot pointers have redundant information, so we can use a scheme where we can return either an error code or a pointer with the same return value. The default implementation just casts the pointer to a number, however, this may fail on platforms where the end of the address range is used for valid pointers (e.g. 0xffffff00 is a valid heap pointer in socfpga SPL). For such platforms, this value provides an upper range of those error pointer values - up to 'MAX_ERRNO' bytes below this value must be unused/invalid addresses. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-10-08Kconfig: Set default BUILD_TARGET for ARCH_MX6 with SPLStefan Roese
Use BUILD_TARGET to automatically build "u-boot-with-spl.imx" on MX6 targets with SPL. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Stefano Babic <sbabic@denx.de>
2019-08-26riscv: set default FIT generator script and build target for SPL buildsLukas Auer
Now that we have a generic FIT generator script for RISC-V, set it as the default. To also build the FIT image by default, set the default build target to "u-boot.itb" if CONFIG_SPL_LOAD_FIT is enabled. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Anup Patel <anup.patel@wdc.com>
2019-08-24Merge tag 'u-boot-rockchip-20190823' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - remove rk3288 fennec board - remove SPL raw image support for Rockchip SoCs - add common misc_init_r() for ethaddr from cpuid - enable USB HOST support for rk3328 - unify code for finding a valid gpt in part driver
2019-08-23Kconfigs: Various: Fix some SPL, TPL and ARM64 dependenciesAdam Ford
Several options are presenting themselves on a various boards where the options are clearly not used. (ie, arm64 options on arm9, or SPL/TPL options when SPL or TPL are not defined) This patch is not attempting to be a complete list of items, but more like low hanging fruit. This patch attempts to reduce some of the menuconfig noise by defining dependencies so they don't appear when not used. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-23rockchip: Move config SYS_MALLOC_LEN to KconfigKever Yang
Use Kconfig for option SYS_MALLOC_LEN and default to 0x2000000. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-11configs: Rename CONFIG_IMAGE_FORMAT_LEGACY to CONFIG_LEGACY_IMAGE_FORMATTom Rini
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of cmd/ switch to using CONFIG_IS_ENABLED() to test what is set. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-26Kconfig: Add u-boot.itb BUILD_TARGET for RockchipJagan Teki
Add u-boot.itb BUILD_TARGET for Rockchip platform when SPL_LOAD_FIT is being used. This can get rid of building itb explicitly with 'make u-boot.itb' so, from now all required images will build just by make. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Drop zipitz2 board (Tom) - Add DEPRECATED option (Tom) - Mark legacy or non-dm drivers as DEPRECATED (Jagan)
2019-06-14configs: Migrate CONFIG_SYS_LDSCRIPT to KconfigTom Rini
In order to migrate this symbol to Kconfig introduce a new symbol to guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then provide the exact final location o the script. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-13Kconfig: Add DEPRECATED optionTom Rini
Add a new option, CONFIG_DEPRECATED, for code that relies on deprecated functionality and has not been converted past the deadline for conversion. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-11imx: Use a convenient default value for SYS_MALLOC_F_LENFabio Estevam
Commit 3a7c45f6a772 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver") causes some i.MX boards that were converted to DM, such as warp7, to fail to boot. As explained by Lukas Auer: "With the patch, U-Boot probes the drivers for devices under simple-bus device tree nodes in the pre-relocation device model. The default value of CONFIG_SYS_MALLOC_F_LEN (0x400) leaves U-Boot with not enough memory to do this, causing it to hang." Fix this problem by providing a convenient default value for CONFIG_SYS_MALLOC_F_LEN. Reported-by: Pierre-Jean Texier <pjtexier@koncepto.io> Suggested-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Signed-off-by: Fabio Estevam <festevam@gmail.com> Tested-by: Pierre-Jean Texier <pjtexier@koncepto.io> Tested-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Peng Fan <peng.fan@nxp.com> Tested-by: Heiko Schocher <hs@denx.de>
2019-05-28Kconfig: Fix SPL_LOAD_FIT descriptionMarek Vasut
Both the SPL_LOAD_FIT and SPL_LOAD_FIT_FULL have the same description. Adjust the description to make it clear which one is which. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com>
2019-05-26Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
- Gen3 PCIe driver + enablement on Salvator-X platforms. - Gen3 recovery SPL used to reload ATF/OpTee/U-Boot instead of minimon. - SDHI HS400 fixes ported from latest BSP and datasheet.
2019-05-23stm32mp1: Move config SYS_MALLOC_LEN to KconfigPatrick Delaunay
This patch moves the the config SYS_MALLOC_LEN to Kconfig as it is already done for zynq arch in commit 01aa5b8f0503 ("Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynq") Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-21ARM: rmobile: Add recovery SPL for R-Car Gen3Marek Vasut
Build an SPL which can be started via SCIF download mode on R-Car Gen3 and allows loading and executing U-Boot uImage with the next stage code. This is also useful for starting e.g. ATF BL2, which inits the hardware and returns to the U-Boot SPL, which can then load e.g. U-Boot proper. The H3, M3-W, M3-N SoCs have plenty of SRAM for storing the U-Boot SPL while the payload, e.g. ATF BL2, executes, so there is no problem here. However, E3 and D3 have much less SRAM, hence the loader uses a trick where it copies itself beyond the area used by BL2 and executes from there. That area is 32kiB large and not enough to hold U-Boot SPL, BSS, stack and malloc area, so the later two are placed at +0x4000 offset from start of SRAM, another area not used by ATF BL2. To make things even more complicated, the SCIF loader cannot load to the upper 32kiB of the SRAM directly, hence the copying approach. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-18Kconfig: fix FIT offset prompt textIbai Erkiaga
The current prompt text for FIT external offset is identical to SYS_TEXT_BASE which might confuse the users. Provided more accurate description for the prompt text. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Reviewed-by: Marek Vasut <marex@denx.de>
2019-05-08Kconfig: Add default SPL_FIT_GENERATOR for rockchipJagan Teki
Add default SPL_FIT_GENERATOR py script for rockchip platforms if specific target enabled SPL_LOAD_FIT. So, this would help get rid of explicitly mentioning the default SPL FIT generator in defconfigs. however some targets, like puma_rk3399 still require their own FIT generator so in those cases the default will override with defconfig defined generator. Reviewed-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-04-09Makefile: Add Kconfig option CONFIG_SPL_IMAGE to select the SPL binaryStefan Roese
This patch adds the CONFIG_SPL_IMAGE option to select the SPL image that shall be used to generate the combined SPL + U-Boot image. The default value is the current value "spl/u-boot-spl.bin". This patch also sets CONFIG_SPL_IMAGE to "spl/boot.bin" for AT91 targets which use SPL NAND support (boot from NAND). For these build targets the combined image "u-boot-with-spl.bin" is now automatically generated and can be programmed into NAND as one single image (vs. SPL image and U-Boot as 2 separate images). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-03-21ARM: socfpga: Build sfp image only for Gen5 and Arria10 devicesDalon Westergreen
The sfp file is only valid for Gen5 (Cyclone5 & Arria5) and Arria10 devices. The file should only be built for these devices. Signed-off-by: Dalon Westergreen <dalon.westergreen@intel.com>
2019-02-11Kconfig: fix BUILD_TARGET for ARCH_MVEBUBaruch Siach
Commit dc146ca11187 ("Kconfig: Migrate CONFIG_BUILD_TARGET") made the mvebu default build target depend on CONFIG_SPL_BUILD. Unfortunately, there is no such Kconfig symbol. Use the CONFIG_SPL symbol instead to fix that. Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Stefan Roese <sr@denx.de>
2019-02-02Kconfig: set default BUILD_TARGET for kirkwoodChris Packham
Now that BUILD_TARGET is in Kconfig we can define a default for boards using the Kirkwood SoC. Signed-off-by: Chris Packham <judge.packham@gmail.com> Cc: Jagan Teki <jagan@amarulasolutions.com>
2019-02-02Kconfig: Migrate CONFIG_BUILD_TARGETJagan Teki
Migrate CONFIG_BUILD_TARGET into Kconfig. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-01-18Kconfig: fix spellingChris Packham
Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-01Merge tag 'u-boot-imx-20190101' of git://www.denx.de/git/u-boot-imxTom Rini
imx for 2019.01 - introduce support for i.MX8M - fix size limit for Vhybrid / pico boards - several board fixes - w1 driver for MX2x / MX5x
2019-01-01Introduce CONFIG_FIT_EXTERNAL_OFFSETPeng Fan
Introduce CONFIG_FIT_EXTERNAL_OFFSET to give user a choice to choose where to put the external data. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-12-13sandbox: Increase the pre-relocation memorySimon Glass
This is close to full now, so increase it to avoid problems with adding more devices. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-03Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-12-03 This release is fully packed with lots of glorious improvements in UEFI land again! - Make PE images more standards compliant - Improve sandbox support - Improve correctness - Fix RISC-V execution on virt model - Honor board defined top of ram (fixes a few boards) - Imply DM USB access when distro boot is available - Code cleanups
2018-12-03rsa: add support of padding pssPhilippe Reynes
We add the support of the padding pss for rsa signature. This new padding is often recommended instead of pkcs-1.5. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-02distro: Imply USB_STORAGE when USB is availableAlexander Graf
When you support distro boot and you support USB, you usually want to also support booting from USB storage. Reflect that in the Kconfig, so that we don't have to explicitly add USB storage support to every defconfig individually. Reported-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
