2010-03-22Prepare v2010.03-rc2v2010.03-rc2Wolfgang Denk
Update CHANGELOG Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-22ep93xx timer: Fix resolution of get_ticks()Matthias Kaehlcke
ep93xx timer: Make get_ticks() return a value in CONFIG_SYS_HZ resolution, as announced by get_tbclk() Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
2010-03-22ep93xx timer: Fix possible overflow in usecs_to_ticks()Matthias Kaehlcke
ep93xx timer: Use 64-bit values in usecs_to_ticks() in order to avoid overflows in intermediate values Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
2010-03-21correct a syntax typo in at91_matrix.hAsen Dimov
Signed-off-by: Asen Dimov <dimov@ronetix.at>
2010-03-21env: fix endian ordering in crc tableJeff Angielski
The crc table was being built as little endian for big endian targets. This would cause fw_printenv to always fail with "Warning: Bad CRC, using default environment" messages. Signed-off-by: Jeff Angielski <jeff@theptrgroup.com> Acked-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2010-03-21mpc5121: cpu/mpc512x/diu.c: fix warningsAnatolij Gustschin
Fix warnings while compiling with CONFIG_VIDEO enabled: diu.c: In function 'video_hw_init': diu.c:158: warning: 'return' with no value, in function returning non-void diu.c:162: warning: format '%ld' expects type 'long int', but argument 6 has type 'int' diu.c:162: warning: format '%ld' expects type 'long int', but argument 7 has type 'int' Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-03-21console.c: fix problem with splashimageAnatolij Gustschin
If a board uses cfb_console driver and splash image and also defines CONFIG_SILENT_CONSOLE, the user is locked out even if "silent" is not set. It is not possible to get any output, neither on vga console device nor on serial console after redirecting the output to the serial console, since the GD_FLG_SILENT flag remains set. Fix the problem by redirecting the output from frame buffer to serial console if splashimage is used. Only suppress the output if "silent" environment variable was set and don't set the GD_FLG_SILENT flag arbitrarily. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-03-21mod change 755 => 644 for multiple filesThomas Weber
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;' Signed-off-by: Thomas Weber <swirl@gmx.li> Add some more: neither Makefile nor config.mk need execute permissions. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-21mxcmmc: fix warnings due to access 32 bit registers with 16 bit accessorsStefano Babic
Some registers of the mxcmmc driver were accessed using 16 bit accessor functions, because only the LSB is significant. This is not needed and generates warnings. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-21TFTP: allow for adjustable retransmission timoutWolfgang Denk
So far, TFTP negotiated a fixed retransmission timeout of 5 seconds. In some cases (busy networks, slow TFTP servers) this caused very slow transfers. A new environment variable "tftptimeout" allows to set this timeout. Lowering this value may make downloads succeed faster in networks with high packet loss rates or with unreliable TFTP servers. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-03-21Fix PCI_BASE_ADDRESS_5 handling in pci_hose_config_device()Wolfgang Denk
Signed-off-by: FUJITA Kazutoshi <fujita@soum.co.jp> Signed-off-by: <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-03-21cmd_mmc remove \nFrans Meulenbroeks
This patch removes the \n after the help message for mmcinfo. This resulted in an empty line being displayed after the mmcinfo line when the help command was given. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2010-03-16nios2: Added support to YANU UARTRenato Andreola
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-03-16nios2: use generic unaligned.hThomas Chou
2010-03-14Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2010-03-14asm-blackfin/unaligned.h: add for zlib codeMike Frysinger
The new zlib code wants asm/unaligned.h, so have the Blackfin version pull in the asm-generic/unaligned.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-14asm-generic/unaligned.h: dynamic default unaligned accessesMike Frysinger
This is based on the asm-arm/unaligned.h, but made generic so all arches that cannot do unaligned accesses can utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-13video: Fix console display when splashscreen is usedMatthias Weisser
If a splashscreen is used the console scrolling used the scroll size as needed when a logo was displayed. This patch sets the scroll size to the whole screen if a splashscreen is shown. Signed-off-by: Matthias Weisser <matthias.weisser@graf-syteco.de>
2010-03-12Prepare v2010.03-rc1v2010.03-rc1Wolfgang Denk
Coding style cleanup, update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12standalone eepro100_eeprom: fix build errorWolfgang Denk
Building examples/standalone/eepro100_eeprom triggers this error: In file included from include/common.h:629, from eepro100_eeprom.c:24: include/net.h: In function 'NetReadIP': include/net.h:430: warning: implicit declaration of function 'memcpy' eepro100_eeprom.c: At top level: eepro100_eeprom.c:81: error: conflicting types for 'memcpy' include/net.h:430: error: previous implicit declaration of 'memcpy' was here Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12Update .gitignore's: add some generated filesWolfgang Denk
2010-03-12mpc82xx: Remove SL8245 board and the now orpahned sk98lin network driver.Detlev Zundel
This code has compile problems and the company does not even exist any more. So we take the liberty to drop support for it. Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Wolfgang Denk <wd@denx.de> CC: Ben Warren <biggerbadderben@gmail.com>
2010-03-1285xx: Drop FIT support to allow u-boot image to fit in 512kKumar Gala
The 36-bit build exceeds the 512k size we have. Removing FIT type image support allows us to fit and we dont really use it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-03-12Cosmetic change - indentation correction.Michael Zaidman
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
2010-03-12cmd_mtdparts.c: prevent printbuffer overflowsAnatolij Gustschin
The length of configured MTDPARTS_DEFAULT string could be greater than console printbuffer size. Replace printf() by puts() to avoid potential buffer overflows. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-03-12Fix MPC8536DS documentationFrans Meulenbroeks
This patch corrects small mistake in the register list in doc/README.mpc8536ds. These registers are 32 bits and this one starts at ....c not ....e When using the ...c address I can boot from sd, when using the ...e address I cannot. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Acked-by: Hu Mingkai <B21284@freescale.com>
2010-03-12doc: add README for CONFIG_HWCONFIG optionHeiko Schocher
2010-03-12TQM8xx: enable device tree support on all TQM8xx based boards.Heiko Schocher
Also enable support for CONFIG_HWCONFIG because we use this for configuring if this hardware has a FEC or not. syntax: hwconfig=fec:on if hardware has an fec hwconfig=fec:off if hardware has no fec Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12TQM8xx: add device tree support for TQM8xx based boards.Heiko Schocher
Also use hwconfig to configure whether the board has a FEC or not. We then can adjust the DTS to tell Linux if there is a FEC present. syntax: hwconfig=fec:on if hardware has a FEC hwconfig=fec:off if hardware has no FEC Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-11Move CONFIG_UPDATE_TFTP code after CONFIG_PREBOOTWolfgang Denk
The auto-update feature (CONFIG_UPDATE_TFTP) requires that the env variable serverip be set for the TFTP access. If DHCP is to be used to get the serverip env variable, this doesn't work as DHCP happens after the auto-update attempt has run. A solution is to run DHCP in PREBOOT, but even this is too late. To solve this, we move update_tftp() below the PREBOOT stuff. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-11mkimage: dont force entry point with xipMike Frysinger
Some people boot images with the entry point in the middle of the blob (like Linux with the head code in discardable .init.text), and there is no no real requirement that the entry point be right after the mkimage header when doing XIP, so let people specify whatever they want. If they do need an entry right after the header, then they still can do that with normal -e behavior. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-03-11PPC: Record U-Boot's relocated address in RAM and show in bdinfo.Richard Retanubun
This patch uses gd->relocaddr variable to store uboot's relocated address in RAM and shows it in bdinfo command. This patch moves CONFIG_AMIGAONEG3SE style copying of the address in board_init_f to just before relocation is actually done. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Tested-by: Detlev Zundel <dzu@denx.de>
2010-03-11Fix memory leak in mmc_read()Wolfgang Denk
There is be a path through mmc_read in drivers/mmc/mmc.c where malloc'd memory is not freed before exiting mmc_read: it occurs if mmc_set_blocklen() returns a non-zero value. Reported-by: Quentin Armitage <Quentin@Armitage.org.uk> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-07AT91: Update otc570 board to new SoC accessDaniel Gorsulowski
* convert otc570 board to use c stucture SoC access * change gpio access to at91_gpio syntax Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2010-03-07updates the at91 main_clock calculationJens Scharsig
* updates the conditional main_clock calculation (if AT91_MAIN_CLOCK defined) to c structure SoC access * add need register flags Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-03-07arm: kirkwood: suen3: fixed build warningPrafulla Wadaskar
This patch fixes following build warning Invalid Kwbimage command Type - valid names are: BOOT_FROM, NAND_ECC_MODE, NAND_PAGE_SIZE, SATA_PIO_MODE, DDR_INIT_DELAY, DATA, , spi, nand, sata, pex, uart Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-03-07MX51: removed warnings for the mx51evkStefano Babic
The patch removes warnings at compile time and provides some cleanup code: - Removed comment on NAND (not yet supported) from lowlevel_init.S - Removed NFMS bit definition from imx-regs.h The bit is only related to MX.25/35 and can lead to confusion - Moved is_soc_rev() to soc specific code (removed from mx51evk.c) Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-07SPEAr : Supporting new mach ids for spear310 and spear320Vipin Kumar
Supporting new machine ids for SoCs spear310 and spear320 include/asm-arm/mach-types.h has to be updated before applying this patch for build to work Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
2010-03-07arm, suen3: fix compile error, if doing not a local buildHeiko Schocher
2010-03-07arm: add support for the suen3 board from keymileHeiko Schocher
Add support for the ARM part of the mgcoge2, named suen3. This board is based on the Marvell Kirkwood (88F6281) SoC. As there come more board variants, common config options are collected in include/configs/km_arm.h. Also, this board use common code for all keymile boards, which is stored in board/keymile/common/common.c Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Heiko Schocher <hs@denx.de>
2010-03-07Add support for KARO TX25 boardJohn Rigby
This is an i.MX25 base board with only NAND so it uses nand_spl to boot. Signed-off-by: John Rigby <jcrigby@gmail.com> Tune configuration, add support for (redundant) environment in NAND. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> CC: Fred Fan <fanyefeng@gmail.com> CC: Tom <Tom.Rix@windriver.com>
2010-03-07fec_mxc: add MX25 supportJohn Rigby
Use RMII for MX25 Add code to init gasket that enables RMII Signed-off-by: John Rigby <jcrigby@gmail.com> CC: Ben Warren <biggerbadderben@gmail.com>
2010-03-07fec_mxc: cleanup and factor out MX27 dependenciesJohn Rigby
general cleanup move clock init to cpu_eth_init in cpu/arm926ejs/mx27/generic.c make MX27 specific phy init conditional on CONFIG_MX27 replace call to imx_get_ahbclk with one to imx_get_fecclk and define imx_get_fecclk in include/asm-arm/arch-mx27/clock.h Signed-off-by: John Rigby <jcrigby@gmail.com> CC: Ben Warren <biggerbadderben@gmail.com> CC: Fred Fan <fanyefeng@gmail.com> CC: Tom <Tom.Rix@windriver.com>
2010-03-07Add support for Freescale MX25 SOCJohn Rigby
ARM926EJS core with MX31 peripherals. Signed-off-by: John Rigby <jcrigby@gmail.com> Earlier Version Signed-off-by: Wolfgang Denk <wd@denx.de> CC: Fred Fan <fanyefeng@gmail.com> CC: Tom <Tom.Rix@windriver.com>
2010-03-07mxc_serial replace platform specific clockJohn Rigby
remove ifdef'd clock selection code from serial_mxc.c and replace with call to imx_get_uartclk Add definitions for imx_get_uartclk to imx31 and imx27 include files. This makes it easier to add new imx platforms. Signed-off-by: John Rigby <jcrigby@gmail.com>
2010-03-07Add initial support for Freescale mx51evk boardStefano Babic
The patch adds initial support for the Freescale mx51evk board. Network (FEC) and SD controller (fsl_esdhc) are supported. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Fred Fan <fanyefeng@gmail.com>
2010-03-07fsl_esdhc: add support for mx51 processorStefano Babic
The esdhc controller in the mx51 processor is quite the same as the one in some powerpc processors (MPC83xx, MPC85xx). This patches adapts the driver to support the arm mx51. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-07ARM: add accessors functionsStefano Babic
Some Freescale's processors of different architecture have the same peripheral (eSDHC controller in PowerPC and i.MX51). This patch adds accessors for the internal registers of the SOCs, as already implemented in the PowerPC architecture. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-07MMC: add weak function to detect MMC/SD cardStefano Babic
Most controllers can check if there is a card in the slot. However, they require pins that could be not available because required by other functions and the detection of a card must be performed in another way. This patch adds a weak function that a board can implement to add its internal custom way to check the presence of a MMC/SD card. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-07mmc: check correctness of the voltage mask in ocrStefano Babic
Most cards do not answer if some reserved bits in the ocr are set. However, some controllers can set bit 7 (reserved for low voltages), but how to manage low voltages SD card is not yet specified. Signed-off-by: Stefano Babic <sbabic@denx.de>
