Add missing error message to blk_get_device_part_str.
Related-to: ELB-4082
Signed-off-by: Oleksii Bidnichenko <oleksii.bidnichenko@toradex.com>
commit 8e2b0af7216d78b60fccb46a107a4a047938aea9 upstream.
commit ef5ab0d13a7a44469f6c765c8acc8d54c23213de upstream.
Update a __mmc_switch MMC_STATUS_SWITCH_ERROR notification level from
debug to error.
As the ${variant} variable includes the leading dash adding another one
leads to the following:
Apalis iMX8 TEZI # echo $fdtfile
imx8qm-apalis--v1.1-eval.dtb
Fix this by removing that extra dash.
Note that this does not change anything for the recovery mode use case.
There another fix to the distro boot script in meta-toradex-tezi is
required.
Fixes: commit f499632b31f8 ("apalis-imx8: construct fdtfile dynamically")
Related-to: TEI-934
The following expression is used to construct the device tree name:
fdtfile=${soc}-colibri-${fdt_board}.dtb
- soc is set dynamically (either imx8qxp imx8dx)
- fdt_board can be modified by the user (eval-V3, aster, iris/iris-V2)
Related-to: ELB-2800
Signed-of-by: Stefano Viola <stefano.viola@toradex.com>
The bit12 of IOMUXC_GPR_GPR14/16 are used to bypass internal regulator for
two PCIE PHYs:
When PCIE_VPH = 3.3V, enable internal 3.3V to 1.8V regulator to generate the
1.8V, the register of IOMUXC_GPR_GPR14/16 bit 12 = 1'b0;
When PCIE_VPH = 1.8V, disable the internal 3.3V to 1.8V regulator, using the
external 1.8V for the PHY, the register of IOMUXC_GPR_GPR14/16 bit 12 = 1'b1;"
This bit is reset to 1 which means bypass the internal regulator. However the
EVK board connects 3.3v supply to PCIE_VPH. So we must enable the regulator,
otherwise it could potentially impact the product lifetime of the device.
Signed-off-by: Ye Li <ye.li@nxp.com>
Acked-by: Richard Zhu <hongxing.zhu@nxp.com>
(cherry picked from commit 3fd0991551c8236319b8bf29ca47813c9242c18f)
fdtfile=${soc}-apalis${variant}-${fdt_board}.dtb
- soc is set dynamically (either imx8qp or imx8qm),
- variant is set dynamically (either empty or -v1.1),
- fdt_board can be modified by the user (eval or ixora)
Related-to: ELB-3338
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
We don't like to print module revision all the time.
Drop the module revision output from the code
Toradex Linux kernel supports different device trees
for Apalis iMX8QM and Apalis iMX8QP SKUs and
board revisions. Update apalis-imx8 to support both
QM and QP revisions
First, try configuring for quad die, dual rank aka 8 GB RAM
configuration. Falling back to dual die, single rank aka 1 GB
(untested), 2 GB or 4 GB RAM configuration if it fails.
Related-to: ELB-3938
Re-add previous dual die, single rank aka 1 GB (untested), 2 GB or 4GB
RAM configuration as a separate parameter set.
A later commit uses this as a fall-back configuration allowing for
dynamic unified memory configuration of all our (current) SKUs.
As a first step, integrate the quad die, dual rank aka 8 GB
configuration.
In a later step, the previous dual die, single rank aka 1 GB (untested),
2 GB or 4 GB configuration will be re-added as a fall-back configuration
allowing for dynamic unified memory configuration of all our (current)
SKUs.
Fixes commit 283ec8678 ('board: verdin-imx8mp: add missing modules to
the wifi-device tree list')
Related-to: ELB-4003
Enable usb and fastboot for serial download support
Signed-off-by: Adrian Alonso <adrian.alonso@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit d12ef0f1fe200d44738684d90f92523fc971aef4)
Enable usb and fastboot for serial download mode support
(cherry picked from commit 9dd80d8541656cf443b03d48525d05b773e36ed8)
(cherry picked from commit 99903f47bd538d23ed80c05e0bda515c911f642d)
Enable usb and fastboot support for serial download mode
(cherry picked from commit 308b99721cfa348feb0dd48380440b1dab8faf61)
(cherry picked from commit 96efe63a61054406aa849f4f929497d24c3a46a6)
(cherry picked from commit 3e8a7a0fb379cde29b2c6e63811175a52e9b37e6)
Enable usbotg1 on host mode for serial download support
(cherry picked from commit e055f5b5a36c71060e17bcd8e9eaefc1198b51c3)
(cherry picked from commit 09e5e3f3e246849b13a62c573d44042f3a944db3)
Enable usb configs options for imx8mn audio board 2 targets
(cherry picked from commit 0f2ac0ce21ef81769a273733d730a98fa090950e)
Enable usb configs options for imx8mm audio board 2 targets
(cherry picked from commit ef033c71ee133c9d49f10432612a1f48bd565d86)
Enable usb boot device support for imx8mm ab2 target boards
(cherry picked from commit 14639c28a70005016d343bfd883948f37e509234)
on Audio board 2 targets
(cherry picked from commit 60239e91a6a5658af3f36428fa55b160c90a6858)
The distro boot script for TEZI has another name to prevent u-boot of
regular BSP trying to boot TEZI image. Expand the usage of
TDX_EASY_INSTALLER Kconfig option to seek and use the TEZI-specific
name of the script.
Related-to: TEI-791
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
The distroboot script system scans boot_scripts variable and
try to find and use to boot each script name mentioned there.
Setting global variable "script" breaks this general mechanism
of searching and running a distro boot script.
Remove global variables "script" to fix working the general
distro boot script mechanism.
Related-to: TEI-791
Add Toradex Easy Installer specific option. Currently this is needed
to choose the correct ubiboot options and use correct name of distro
boot script for Easy Installer.
Related-to: TEI-791
Fastboot protocol should be enabled for Easy Installer.
Enable fastboot options in configuration file
Related-to: TEI-745
Reported-by: Dominik Sliwa <dominik.sliwa@toradex.com>
Add new i.MX 6ULL and 8M Plus SKUs to ConfigBlock handling:
0062: Colibri iMX6ULL 1GB IT (eMMC)
0063: Verdin iMX8M Plus Quad 4GB IT
0064: Verdin iMX8M Plus Quad 2GB Wi-Fi / BT IT
0065: Verdin iMX8M Plus QuadLite 1GB IT
0066: Verdin iMX8M Plus Quad 8GB Wi-Fi / BT
Variable rootpath is used by distroboot script as a default path to
a rootfs on an NFS server. Set this variable properly for all aarch64
modules, which support a Distro Boot.
toradex_imx_v2020.04_5.4.70_2.3.0
Update to NXP BSP tag rel_imx_5.4.70_2.3.2
https://source.codeaurora.org/external/imx/uboot-imx/tag/?h=rel_imx_5.4.70_2.3.2
Related-to: ELB-3957
Default reset_cpu in imx_watchdog driver is clearing the WDA bit
to assert WDOG_B output. However, this requires the iomuxc for the WDOG_B
is configured by board codes or DTS. Without it, next external reset
with WDOG_B iomuxc configured will not work.
On iMX6, we always use internal reset to support some features like bmode.
So the iomuxc for WDOG_B never be set. Change back the reset_cpu to use
internal reset.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit aa97f1de484a165212cec56bd8ed38227c8f828a)
U-boot might display wrong module revision information
for modules with an assembly version 'K'. "cfgblock create"
does not takes into account all revision digits from PID8.
This fix takes into account 6th,7th digits of PID8
to store module revision.
Related-to: ELB-3893
The on module USB hub connects upstream to SoC USB_OTG2 and provides
two downstream ports, one to the on module Wi-Fi, one to the SODIMM
connector.
In bypass mode the upstream port is directly connected to the SODIMM
connector pins.
Related-to: ELB-3853
The macros are no longer used as the pins concerned are now configured
in the device tree.
This gpio setup code is from the initial bringup and was never needed
in the first place. Just delete it.
Enable the ADC supply (LDO4) @ 3.3V before enabling the I2C level
shifter so that both sides of the level shifter are properly powered.
Otherwise, depending on ADC connections the on module PMIC I2C bus
might not be functional.
Relates-to: ELB-3873
Add missing support of FIT-images and enable a verbosity for
this feature.
We drop support for Verdin iMX8M Mini V1.0B.
Releated-to: ELB-3551
Restore "Is the module an IT version? [y/N]" for "cfgblock create"
interactive mode command, which was leading to invalid detection
of 0051 Colibri iMX8DX 1GB WB module;
Fixes: c0c3978cba34 ("toradex: tdx-cfg-block: add Verdin iMX8M Mini/Nano support")
Fixes: 7780d4ec8ee3 ("toradex: tdx-cfg-clock: add new i.mx 8m mini/plus skus")
Related-to: ELB-3482
The driver supports combined flag to disable srp/hnp and doesn't support
disabling adp. Fix flag properties.
Related-to: ELB-3424
Currently the Cadence,usb3 driver doesn't support a phy vbus regulator.
Emulate it keeping the USBH_EN signal high with gpio-hog entry.
This enables the on-board USB-Hub with ports USB2[ABCD] and on-board
USB ports USBH3/4.
Request using the pin of USBH_EN signal that enables
on-board USB hub (USBH2[ABCD] ports) and USBH3/4 ports.
Trying to use the usbotg1 port in host mode led to the following
error:
starting USB...
Bus usb@5b0d0000: usb dr_mode not found
Port not available.
Adding the correct dual-role mode fixes this issue and let the usbotg1
port working in both peripheral and host mode.
This prevents messages like:
gpio@5d0d0000: get_value: error: gpio GPIO5_9 not reserved
when CONFIG_DM_GPIO is enabled.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Both Verdin Developer Board V1.0A and V1.1A have their PHYs at address
7. Only V1.0B had it at the address 3!
Remove CONFIG_FEC_MXC_PHYADDR, CONFIG_FEC_XCV_TYPE and PHY_ANEG_TIMEOUT
in favour of device tree configuration via DM_ETH_PHY/PHYLIB.
Eqos is set to primary as it is the on-module Ethernet interface
nothing to do with its MDIO usage which BTW isn't even correct in the
i.MX 8M Plus LPDDR4 EVK case!
