2005-12-16Merge with /home/sr/git/u-bootv1.1.4U-Boot-1_1_4Wolfgang Denk
2005-12-16MPC5200: Set PCI retry counter to 0 = infinite retry;Wolfgang Denk
The default of 255 is too short for slow devices. Patch by Martin Nykodym, 12 Dec 2005
2005-12-15Changes to Yellowstone & Yosemite 440EP/GR eval boards:Stefan Roese
- Changed GPIO setup to enable another address line in order to address 64M of FLASH. - Added function sdram_tr1_set to auto calculate the tr1 value for the DDR. Patch by Steven Blakeslee, 12 Dec 2005
2005-12-14Merge with /home/m8/git/u-bootWolfgang Denk
2005-12-06Change port configuration for O2DNT (CODEC1 on PSC1)Marian Balakowicz
2005-12-06Fix DPRAM offset/size for MPC8541/8555.Wolfgang Denk
Simplify TQM85xx Makefile handling.
2005-12-04Fix data overflow (typo?) in rtc/ds1302.cWolfgang Denk
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-12-01Fix U-Boot compilation for MIPS boards using ELDK 4.0Wolfgang Denk
2005-12-01Merge with /home/sr/git/u-bootWolfgang Denk
2005-12-01Adjust TQM834x PHY addresses for latest hardware revision.Wolfgang Denk
2005-12-01Increase malloc arena on TQM5200 board to 256 kB.Wolfgang Denk
With 64 kb uniform flash sector size the old value of 128 kB was too small.
2005-11-30Fix miiphy global data initialization (problem on 4xx boards when noMarian Balakowicz
ethaddr is assigned). Initialization moved from miiphy_register() to eth_initialize(). Based on initial patch for 4xx platform by Matthias Fuchs.
2005-11-30Add support for TQM8541/8555 boards, TQM85xx support reworked:Stefan Roese
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005
2005-11-29Compile warning fixedStefan Roese
Patch by Stefan Roese, 29 Nov 2005
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
2005-11-29Minor AMCC 4xx board cleanupsStefan Roese
Patch by Stefan Roese, 27 Nov 2005
2005-11-27Increase IPB and PCI clocks for O2DNT board.Marian Balakowicz
2005-11-27Changed PPC44x startup message (cpu info, speed...) to common style:Stefan Roese
On PPC44x platforms, the startup message generated in "cpu.c" only comprised the ppc type and revision but not additional informations like speed etc. Those speed infos where printed in the board specific code. This new implementation now prints all CPU infos in the common cpu specific code. No board specific code is needed anymore and therefore removed from all current 44x implementations. Patch by Stefan Roese, 27 Nov 2005
2005-11-25Remove unnnecessary #include <linux/types.h> from include/asm-*/u-boot.hWolfgang Denk
2005-11-25Allow use of include/image.h and include/asm-*/u-boot.h in proprietary code.Wolfgang Denk
The COPYING file was extended to make clear that these files can be used in non-GPL code, too.
2005-11-22Add support for Prodrive P3P440 board:Stefan Roese
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005
2005-11-17Minor changes to init flags in TQM834x PCI.Rafal Jaworowski
2005-11-15Add CHANGELOG entryStefan Roese
Patch by Stefan Roese, 15 Nov 2005
2005-11-15Merge with /server/home/stefan/git/u-boot/bamboo-sdramStefan Roese
2005-11-15Fix Bamboo DDR SDRAM initialization (problem with onboard SDRAM)Stefan Roese
2005-11-15New PPC 405EP board added: CMS700Stefan Roese
Added CONFIG_NET_MULTI for VOM405 board. Added reset_phy() for VOM405 board. Patch by Matthias Fuchs, 09 Nov 2005
2005-11-10Add explanation for CDP checksum algorithmWolfgang Denk
2005-11-08Updated PCI mapping for esd CPCI2DP board.Stefan Roese
Add support for error LED. Patch by Matthias Fuchs, 07 Nov 2005
2005-11-07Fix MPC85xx PCI support (pci_register_hose() before pci config access)Stefan Roese
Patch by Stefan Roese, 07 Nov 2005
2005-11-07Correct PPC Timebase register definitions (SPRN_TBRL...)Stefan Roese
2005-11-05Adjust bd->bi_flashstart on Yellowstone & Yosemite to correct sizeStefan Roese
Patch by Stefan Roese, 05 Nov 2005
2005-11-03Adjust TQM85x PHY addresses for latest hardware revision.Wolfgang Denk
2005-11-03Additional fix for external IRQ config on Yellowstone & YosemiteStefan Roese
Patch by Stefan Roese, 03 Nov 2005
2005-11-01Add support for Ocotea pass 3 with 440GX Rev. FStefan Roese
Patch by Stefan Roese, 01 Nov 2005
2005-11-01Merge with /git/u-boot.gitStefan Roese
2005-10-29More verbose CHANGELOG entry.DENX-2005-10-29-2350Wolfgang Denk
2005-10-29Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-29Add missing CHANGELOG entries.Marian Balakowicz
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-10-28Correct includes for flat tree builder.Marian Balakowicz
2005-10-28Fix conflicting types (flash_write()) in trab auto_update.cMarian Balakowicz
2005-10-28Fix external IRQ configuration on Yellowstone & YosemiteStefan Roese
The multiplexed signals Ext IRQ0...3 have to be configured as IRQ, because they default to GPIOx (440EP/GR). Patch by Stefan Roese, 28 Oct 2005
2005-10-21Merge with /home/wd/git/u-boot/masterWolfgang Denk
2005-10-20Add missing 4xx board to MAKEALLStefan Roese
Patch by Stefan Roese, 20 Oct 2005
2005-10-20Fix conflicting types (flash_write()) in esd auto_update.cStefan Roese
2005-10-20Fix problem with sleep in NetConsole (use get_timer())Stefan Roese
2005-10-20Add NetConsole Support for AMCC eval boardsStefan Roese
