2005-02-08Fix yet another recently introduced bug.LABEL_2005_02_08_1615wdenk
2005-02-07Fix cirrus voltage detection (for CPC45)LABEL_2005_02_07_2045wdenk
2005-02-04Fix for incomplete byteorder fix in cmd_scsi.c and cmd_usb.cwdenk
2005-02-04Fix byteorder problem in usbboot and scsiboot commands.wdenk
2005-02-04* Patch by Cajus Hahn, 04 Feb 2005:wdenk
- don't insist on leading '/' for filename in ext2load - set default partition to useful value (1) in ext2load * Patch by Andrew Dyer, 08 Jan 2005: fix wrong return codes in ext2 code
2005-02-03* Removed '--no-warn-mismatch' option from Makefile. This optionwdenk
makes 'ld' to overlook binary objects compatibility. * Moved $(PLATFORM_LIBS) from the library group (--start-group ... --end-group) outside of the group. This will make 'ld' to do _multiple_ search in the library group when resolving symbol references and do only a _single_ seach in libgcc.a after the group search. * Fix stability problems on CPC45 board again. * Make image detection for diskboot / usbboot / scsiboot more robust (also check header checksum)
2005-01-31* Update CPC45 board configuration.LABEL_2005_01_31_2245wdenk
* Add USB and PCI support for INKA4x0 board
2005-01-22Fix IDE stability problems on CPC45 board.wdenk
2005-01-22Code cleanup.wdenk
2005-01-12* Patch by Robin Getz, 13 Oct 2004:wdenk
Add standalone application to change SMC91C111 MAC addresses, see examples/README.smc91111_eeprom * Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004: Fix Flash support for ARM Integrator CP.
2005-01-12* Some Cleanup.wdenk
* Patch by Richard Woodruff, 10 Jan 2005: Update support for OMAP2420 (ARM11) and H4 board: o clean up and add new types to H4 memory probe code. o fix to work with internal boot. o added PRCM config III operation. o fix marginal flash timings. o add revison ATAG usage. o enable voltage scaling at power chip. o fix compile error for i2c. * Fix network problem (error when receiving multiple ARP packets)
2005-01-10Coding Style cleanupwdenk
2005-01-09* Patch by Daniel Poirot, 10 Oct 2004:wdenk
Add support for Wind River sbc405 board * Patch by Rainer Brestan, 12 Oct 2004: Make examples/Makefile more robust
2005-01-09* Patch by Sam Song, 11 October 2004:wdenk
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board - Adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz * Patch by Sam Song, 10 Oct 2004: Fix a parameter error in run_command() in main.c
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2005-01-09Patches by David Snowdon, 07 Sep 2004:wdenk
- add u-boot.hex target in the top level Makefile - add support for the UNSW/NICTA PLEB 2 board (pleb2) - use -mtune=xscale and -march=armv5 options for PXA
2005-01-09Patch by Florian Schlote, 08 Sep 2004:wdenk
Add support for SenTec-COBRA5272-board (Coldfire).
2005-01-09* Patch by Gleb Natapov, 07 Sep 2004:wdenk
mpc824x: set PCI latency timer to a sane value (is 0 after reset). * Patch by Kurt Stremerch, 03 Sep 2004: Add bitstream configuration option for fpga command (Xilinx only).
2005-01-09* Patch by Kurt Stremerch, 03 Sep 2004:wdenk
Add Xilinx Spartan2E family FPGA support * Patch by Jeff Angielski, 02 Sep 2004: Add Added support for H2 revision of the EP8260 board. Fixed formatting for some of the EP8260 related source files.
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2005-01-02Release U-Boot 1.1.2U-Boot-1_1_2wdenk
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-12-20Fix problems with CMC_PU2 flash driver.LABEL_2004_12_20_1220wdenk
2004-12-19* Fix problems with CMC_PU2 flash driver.LABEL_2004_12_19_2240wdenk
* Adjust INKA 4x0 default settings
2004-12-19Renamed UC100 => uc100LABEL_2004_12_19_1100wdenk
2004-12-19Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100wdenk
2004-12-18Add support for UC100 boardLABEL_2004_12_18_2335wdenk
2004-12-17One more code cleanup.stroese
2004-12-16Code cleanup.wdenk
2004-12-16PCI405 board updatestroese
2004-12-16AR405 board updatestroese
2004-12-16Patch by Stefan Roese, 16 Dez 2004stroese
2004-12-16CONFIG_MX_CYCLIC description addedstroese
2004-12-16some new esd boards addedstroese
2004-12-16esd common updatestroese
2004-12-16VOH405 board updatestroese
2004-12-16PMC405 board updatestroese
2004-12-16PLU405 board updatestroese
2004-12-16OCRTC board updatestroese
2004-12-16HUB405 board updatestroese
2004-12-16DU405 board updatestroese
2004-12-16DP405 board updatestroese
2004-12-16CPCIISER4 board updatestroese
2004-12-16CPCI440 board updatestroese
2004-12-16CANBT board updatestroese
2004-12-16ASH405 board updatestroese
2004-12-16ADCIOP board updatestroese
