* Configure PPChameleon board to use JFFS2 NAND support.
* Added support for JFFS2 filesystem (read-only) on top of NAND flash
* Patch by Rune Torgersen, 16 Apr 2004:
LBA48 fixes
* Patches by Pantelis Antoniou, 16 Apr 2004:
- Fix some compile problems;
add "once" functionality for the netretry variable
- add support for a new version of an Intracom board and fix
various other things on others.
- add verify support to the crc32 command (define
CONFIG_CRC32_VERIFY to enable it)
- fix FEC driver for MPC8xx systems:
1. fix compilation problems for boards that use dynamic
allocation of DPRAM
2. shut down FEC after network transfers
- HUSH parser fixes:
1. A new test command was added. This is a simplified version of
the one in the bourne shell.
2. A new exit command was added which terminates the current
executing script.
3. Fixed handing of $? (exit code of last executed command)
add support for Intel Assabet board
Add support for Picture Elements JSE board
* Patch by Christian Pell, 01 Apr 2004:
Add CompactFlash support for PXA systems.
- some minor patches / cleanup
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
Improve and fix various things in the MPC8xx FEC driver:
1. The new 87x and 88x series of processors have two FECs,
and the new driver supports them both.
2. Another change in the 87x/88x series is support for
the RMII (Reduced MII) interface. However numerous
changes are needed to make it work since the PHYs
are connected to the same lines. That means that
you have to address them correctly over the MII
interface.
- add support for the Epson 156x series of graphical displays
(These displays are serial and not suitable for using a normal
framebuffer console on them)
- add infrastructure needed in order to POST any DSPs in a board
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
unconfiguring the board
* Adapt RMU board for bigger flash memory
* Test fix for ethernet problems on MPC5200
Add support for KUP4X Board
Add Reiserfs support
* Patch by Hinko Kocevar, 20 Mar 2004
- Add auto-release for SMSC LAN91c111 driver
- Add save/restore of PTR and PNR regs as suggested in datasheet
Increase speed of sector reads from SystemACE,
shorten poll timeout and remove a useless reset
* Patch by Tolunay Orkun, 19 Mar 2004:
Make GigE PHY 1000Mbps Speed/Duplex detection conditional
(CONFIG_PHY_GIGE)
* Patch by Brad Kemp, 18 Mar 2004:
prevent machine checks during a PCI scan
* Patch by Pierre Aubert, 18 Mar 2004:
Fix string cleaning in IDE identification
- Unify video mode handling for Chips & Technologies 69000 Video
chip and Silicon Motion SMI 712/710/810 Video chip
- Add selection of the video output (CRT or LCD) via 'videoout'
environment variable for the Silicon Motion
- README update
include/common.h typo fix
* Patches by Tolunay Orkun, 17 Mar 2004:
- Add support for bd->bi_iic_fast[] initialization via environment
variable "i2cfast" (CONFIG_I2CFAST)
- Add "i2cfast" u-boot environment variable support for csb272
Ignore '\0' characters in console input for use with telnet and
telco pads.
* Patch by Leon Kukovec, 17 Mar 2004:
typo fix for strswab prototype #ifdef
- show PCI clock frequency on MPC8260 systems
- add FCC_PSMR_RMII flag for HiP7 processors
- in do_jffs2_fsload(), take load address from load_addr if not set
explicit, update load_addr otherwise
- replaced printf by putc/puts when no formatting is needed
(smaller code size, faster execution)
avoid dereferencing NULL pointer in lib_arm/armlinux.c
* Patch by Stephen Williams, 15 Mar 2004:
Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation
* Patch by Tolunay Orkun, 15 Mar 2004:
Initialize bi_opbfreq to real OPB frequency via get_OPB_freq()
* Patch by Travis Sawyer, 15 Mar 2004:
Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
attempting to switch on USB on SX1 board.
* Patch by Josef Wagner, 18 Mar 2004:
- Add support for MicroSys XM250 board (PXA255)
- Add support for MicroSys PM828 board (MPC8280)
- Add support for 32 MB Flash on PM825/826
- new SDRAM refresh rate for PM825/PM826
- added support for MicroSys PM520 (MPC5200)
- replaced Query by Identify command in CPU86/flash.c
to support 28F160F3B
* Fix wrap around problem with udelay() on ARM920T
* Add support for Macronix flash on TRAB board
Fix buffer overflow in IDE identification
- Adding get_ticks() and get_tbclk() for AT91RM9200
- Many white space fixes in cpu/at91rm9200/interrupts.c
* Patches by Steven Scholz, 20 Feb 2004:
some cleanup in AT91RM9200 related code
- Fix Gigabit Ethernet support for 440GX
- Add Gigabit Ethernet Support to MII PHY utilities
* Patch by Brad Kemp, 12 Mar 2004:
Fixes for drivers/cfi_flash.c:
- Better support for x8/x16 implementations
- Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE
- Added defines for AMD command and address constants
* Patch by Leon Kukovec, 12 Mar 2004:
Fix get_dentfromdir() to correctly handle deleted dentries
* Patch by George G. Davis, 11 Mar 2004:
Remove hard coded network settings in TI OMAP1610 H2
default board config
add support for ADS GraphicsClient+ board.
- add bitmap command and splash screen support in cfb console
- add [optional] origin in the bitmap display command
* Patch by Travis Sawyer, 11 Mar 2004:
Fix ocotea board early init interrupt setup.
* Patch by Thomas Viehweger, 11 Mar 2004:
Remove redundand code; add PCI-specific bits to include/mpc8260.h
- Add support for the SSV ADNP/ESC1 (Nios Softcore)
* Patch by George G. Davis, 9 Mar 2004:
fix recent build failure for SA1100 target
* Patch by Travis Sawyer, 09 Mar 2004:
Support native interrupt mode for the IBM440GX.
Previously it was running in 440GP compatibility mode.
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference
Platform support.
* Patch by Masami Komiya, 08 Mar 2004:
Don't overwrite server IP address or boot file name
when the boot server does not return values
* Patch by listmember@orkun.us, 5 Mar 2004:
Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
Fix early board initialization for Cogent CSB272 board
* Patch by Ed Okerson, 3 Mar 2004:
fix CFI flash writes for little endian systems
* Patch by Reinhard Meyer, 01 Mar 2004:
generalize USB and IDE support for MPC5200 with according
changes to IceCube.h and TOP5200.h
add Am29LV256 256 MBit FLASH support for TOP5200 boards
add info about USB and IDE to README
Fix problems with GCC 3.3.x which changed handling of global
variables explicitly initialized to zero (now in .bss instead of
.data as before).
* Patch by Leon Kukovec, 02 Mar 2004:
add strswab() to fix IDE LBA capacity, firmware and model numbers
on little endian machines
* Patch by Masami Komiya, 02 Mar 2004:
- Remove get_ticks() from NFS code
- Add verification of RPC transaction ID
* Patch by Pierre Aubert, 02 Mar 2004:
cleanup for IDE and USB drivers for MPC5200
Ocotea:
- Add IBM PPC440GX Ref Platform support (Ocotea)
Original code by Paul Reynolds <PaulReynolds@lhsolutions.com>
Adapted to U-Boot and 440GX port
440gx_enet.c:
- Add gracious handling of all Ethernet Pin Selections for 440GX
- Add RGMII selection for Cicada CIS8201 Gigabit PHY
ppc440.h:
- Add needed bit definitions
- Fix formatting
* Patch by Carl Riechers, 1 Mar 2004:
Add PPC440GX prbdv0 divider to fix memory clock calculation.
* Patch by Stephan Linz, 27 Feb 2004
- avoid problems for targets without NFS download support
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA)
- Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF)
- Added support for 64bit strtoul (CFG_64BIT_STRTOUL)
* Patch by Masami Komiya, 27 Feb 2004:
Fix rarpboot: add autoload by NFS
* Patch by Dan Eisenhut, 26 Feb 2004:
fix flash_write return value in saveenv
* Patch by Stephan Linz, 11 Dec 2003
expand config.mk to avoid trigraph warnings on NIOS
* Rename "BMS2003" board into "HMI10"
use redundand environment storage;
auto-set console on USB port (using preboot command)
add support for USB-based console
(enable with "setenv stdout usbtty; setenv stdin usbtty")
* Handle Auti-MDIX / connection status for INCA-IP
* Fix USB problems when attempting to read 0 bytes
Fix broken compile for XPEDITE1K target.
* Patch by Stephan Linz, 26 Feb 2004:
Bug fix for NFS code on NIOS targets
* Patch by Stephen Williams, 26 Feb 2004:
Break up SystemACE reads of large block counts
add IDE support for MPC5200
* Patch by Masami Komiya, 26 Feb 2004:
add autoload via NFS
Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses
elsewhere in the source.
- Timeouts in FPGA code should be based on CFG_HZ
- Minor cleanup in code for Altera FPGA ACEX1K
* Patch by Steven Scholz, 25 Feb 2004:
Changed "Directory Hierarchy" section in README
* Patch by Masami Komiya, 25 Feb 2004:
Reduce copy count in nfs_read_reply() of NFS code
NS9750 DevBoard added
* Patch by Pierre AUBERT, 24 Feb 2004
add USB support for MPC5200
* Patch by Steven Scholz, 24 Feb 2004:
- fix MII commands to use values from last command
* Patch by Torsten Demke, 24 Feb 2004:
Add support for the eXalion platform (SPSW-8240, F-30, F-300)
Fixes for for OMAP1610 board:
- shift some IRQ specific code to platform.S file
- remove duplicatewatchdog reset code from start.S
* Make Auto-MDIX Support configurable on INCA-IP board
* Fix license for mkimage tool
Update NetBootFileXferSize in NFS code
* Patch by Scott McNutt, 24 Feb 2004:
fix packet length in NFS code
Add support for NFS for file download
* Minor code cleanup
Add support for S3C44B0 processor and DAVE B2 board
* Patch by Steven Scholz, 20 Feb 2004:
- Add support for MII commands on AT91RM9200 boards
- some cleanup in AT91RM9200 ethernet code
Add support for the Xilinx ML300 platform
* Patch by Stephan Linz, 17 Feb 2004:
Fix watchdog support for NIOS
* Patch by Josh Fryman, 16 Feb 2004:
Fix byte-swapping for cfi_flash.c for different bus widths
* Patch by Jon Diekema, 14 Jeb 2004:
Remove duplicate "FPGA Support" notes from the README file
