2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-04-04Patch from Stefan Roese.stroese
2003-04-04Changed CPCI405 to use CTS instead of DSR on PPC405 UART1.stroese
2003-04-04U-Boot version environment variable "ver" added (CONFIG_VERSION_VARIABLE).stroese
2003-04-04Changed PPC405GPr version from A to B.stroese
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
2003-03-31* Patch by Arun Dharankar, 24 Mar 2003:wdenk
- add threads / scheduler example code * Add patches by Robert Schwebel, 31 Mar 2003: - add ctrl-c support for kermit download - align bdinfo output on ARM * Add CPU ID, version, and clock speed for INCA-IP
2003-03-28Patches by Dave Ellis, 18 Mar 2003 for SXNI855T board:wdenk
- fix SRAM and SDRAM memory sizing - add status LED support - add MAC address for second (SCC1) ethernet port Update default environment for TQM8260 board
2003-03-27Fix MIPS build problemLABEL_2003_03_27_1900wdenk
2003-03-27* Add support for MIPS32 4Kc CPUswdenk
* Add support for INCA-IP Board
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-26esd PCI405 updated.stroese
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2003-03-25*** empty log message ***LABEL_2003_03_25_1830wdenk
2003-03-25Add PCI support for MPC8250 Boards (PM825 module)wdenk
2003-03-25Patch by Stefan Roese , 25 Mar 2003.stroese
2003-03-25BSP-Command for esd PCI405 added.stroese
2003-03-25esd PCI405 updated.stroese
2003-03-20Patch by Stefan Roese , 20 Mar 2003.stroese
2003-03-20CPCI4052 update (support for revision 3).stroese
2003-03-20Added edge conditioning register (ecr) for PPC405GPr.stroese
2003-03-20Clip udiv to 5 bits on PPC405 (serial.c).stroese
2003-03-20Set edge conditioning circuitry on PPC405GPr for compatibility to existing ↵stroese
PPC405GP designs.
2003-03-14Add files that were forgottenLABEL_2003_03_14_2150wdenk
2003-03-14* Avoid flicker on the TRAB's VFD by synchronizing the enable withwdenk
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100 boards, version 153 for Rev. 200 boards). * Patch by Vladimir Gurevich, 12 Mar 2003: Fix relocation problem of statically initialized string pointers in common/cmd_pci.c * Patch by Kai-Uwe Blöm, 12 Mar 2003: Cleanup & bug fixes for JFFS2 code: - the memory mangement was broken. It caused havoc on malloc by writing beyond the block boundaries. - the length calculation for files was wrong, sometimes resulting in short file reads. - data copying now optionally takes fragment version numbers into account, to avoid copying from older data. See doc/README.JFFS2 for details.
2003-03-12Cleanup compiler warningwdenk
2003-03-06* Patches by David Müller, 31 Jan 2003:LABEL_2003_03_06_2255wdenk
- minimal setup for CardBus bridges - add EEPROM read/write support in the CS8900 driver - add support for the builtin I2C controller in the Samsung s3c24x0 chips - add support for MPL's VCMA9 (Samsung s3c2410 based) board * Patch by Steven Scholz, 04 Feb 2003: add support for RTC DS1307 * Patch by Reinhard Meyer, 5 Feb 2003: fix PLPRCR/SCCR init sequence on 8xx to allow for changes of EBDF by software * Patch by Vladimir Gurevich, 07 Feb 2003: "API-compatibility patch" for 4xx I2C driver
2003-03-06Fix problem with default #definesLABEL_2003_03_06_1440wdenk
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
2003-03-06* Patch by Rune Torgersen, 13 Feb 2003:LABEL_2003_03_06_0200wdenk
Add support for Motorola MPC8266ADS board * Patch by Kyle Harris, 19 Feb 2003: patches for the Intel lubbock board: memsetup.S - general cleanup (based on Robert's csb226 code) flash.c - overhaul, actually works now lubbock.c - fix init funcs to return proper value * Patch by Kenneth Johansson, 26 Feb 2003: - Fixed off by one in RFTA calculation. - No need to abort when LDF is lower than we can program it's only minimum timing so clamp it to what we can do. - Takes function pointer to function for reading the spd_nvram. Usefull for faking data or hardcode a module without the nvram. - fix other user for above change - fix some comments. * Patches by Brian Waite, 26 Feb 2003: - fix port for evb64260 board - fix PCI for evb64260 board - fix PCI scan * Patch by Reinhard Meyer, 1 Mar 2003: Add support for EMK TOP860 Module * Patch by Yuli Barcohen, 02 Mar 2003: Add SPD EEPROM support for MPC8260ADS board
2003-03-06* Patch by Robert Schwebel, 21 Jan 2003:LABEL_2003_03_06_0050wdenk
- Add support for Innokom board - Don't complain if "install" fails - README cleanup (remove duplicated lines) - Update PXA header files * Add documentation for existing POST code (doc/README.POST) * Patch by Laudney Ren, 15 Jan 2003: Fix handling of redundand environment in "tools/envcrc.c" * Patch by Detlev Zundel, 28 Feb 2003: Add bedbug support for 824x systems * Add support for 16 MB flash configuration of TRAB board * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2003-02-18CPCIISER4 configuration updated.stroese
2003-02-17Fixed bug in ext. serial clock setup on PPC405 (since PPC440 port).stroese
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2003-02-11Cleanup: remove trailing white spacewdenk
2003-02-10Add support for 4MB and 128MB onboard SDRAM (cpu/ppc4xx/sdram.c)stroese
2003-02-10Added 4MByte and 128MByte onboard SDRAMstroese
2003-01-17* Add dual ethernet support on PM826wdenk
* Add support for LXT971 PHY on PM826 * Patch by Tord Andersson, 16 Jan 2003: Fix flash sector count for TQM8xxL * Fix I2C EEPROM problem on ICU862 board (would only write the first 16 bytes out of each 32 byte block)
2003-01-13Add support for V37 boardLABEL_2003_01_14_0055wdenk
(patch by Jón Benediktsson, 11 Dec 2002)
2003-01-11* Restrict baudrate settings on LWMON to higher speedsLABEL_2003_01_11_1050wdenk
when watchdog is on * Update baudrate in bd_info when it gets changed * Add watchdog trigger points while waiting for serial port (so far only 8xx -- needed on LWMON with 100ms watchdog) * Improve command line tool to access the U-Boot's environment (figuration of the utility, using a config file)
2003-01-02Patch by Detlev Zundel, 30 Dec 2002:wdenk
Add single quote support for (old) command line parser
2002-12-28Adjust LWMON environment to current requirementsLABEL_2002_12_28_1700wdenk
2002-12-20* Switch LWMON board default config from FRAM to EEPROM;LABEL_2002_12_21_0040wdenk
in POST, EEPROM shows up on 8 addresses
2002-12-17*** empty log message ***U-Boot-0_2_0wdenk
2002-12-17Prepare for release of version 0.2.0wdenk
2002-12-17* Use 1-byte-read instead of -write for iprobe() functionwdenk
Add i2c commands to PM826 config * extend I2C POST code: check for list on known addresses
