http://sw-stash.freescale.net/projects/IMX/repos/ddr-scripts-rel/commits/963fbc75ef6d36e12819e81de23410749754e5ef
http://compass.freescale.net/livelink/livelink?func=ll&objId=234709279&objAction=browse&viewType=1
Main change: (SDB board ddr density is different)
1. tRFC is different with density, tXS/tXPR refers tRFC
Test Results:
2 MX6DP-SDB and 2 MX6QP-SDB boards passed overnight stress test.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
(cherry picked from commit 603b89c8990868c51b1546db4877d198358485ff)
The current 36M offset will conflict with NAND FCB firmware2 when the
nand chip block is 1MB size. This patch change it to 36M + 1M offset,
so the redundant u-boot at firmware2 will not be broken.
Signed-off-by: Ye.Li <B37916@freescale.com>
ddr script update to 1.09:
234694528&objAction=browse&viewType=1
arik_r2_sabre_ddr3_528_1.09.inc is for sabre-auto board.
arik_r2_sdb_ddr3_528_1.09.inc is for sabre-sd board.
Changelog:
1. Optimize DQS duty cycle setting
2. Optimize ZQ PU/PD value
Test results:
2 ARD boards.
2 6QP-SDB boards.
1 6DP-SDB board.
All passed overnight memtester stress test.
(cherry picked from commit ba8dcef9d8e10e46130559ce6defe4411bd1d1a6)
1. Default support SPI-NOR for imx6q/dl/solo sabresd board.
2. Fix bug for mx6soloxxx_spinor_defconfig. "nosmp" should be
\"nosmp\".
Same issue as ENGR00321137, commit 3695635.
GIS module need total 3M+3M+1.5M+1.5M=9M video memory.
and sys reserved 16M memory for malloc.
When gis module enabled, malloc may failed to allocate memory
for other modules, that may cause system hang.
Expand malloc pool to 32M.
Signed-off-by: Sandor Yu <R01008@freescale.com>
The previous 8M address for NAND env might conflict with other boot
parameters as the NAND block size increasing, change it to 36M to avoid
it.
Signed-off-by: Han Xu <b45815@freescale.com>
The cod change updated the NAND driver BCH ECC layout algorithm to
support large oob size NAND chips(oob > 1024 bytes).
Current implementation requires each chunk size larger than oob size so
the bad block marker (BBM) can be guaranteed located in data chunk. The
ECC layout always using the unbalanced layout(Ecc for both meta and
Data0 chunk), but for the NAND chips with oob larger than 1k, the driver
cannot support because BCH doesn’t support GF 15 for 2K chunk.
The change keeps the data chunk no larger than 1k and adjust the ECC
strength or ECC layout to locate the BBM in data chunk. General idea for
large oob NAND chips is
1.Try all ECC strength from the minimum value required by NAND spec to
the maximum one that works, any ECC makes the BBM locate in data chunk
can be chosen.
2.If none of them works, using separate ECC for meta, which will add one
extra ecc with the same ECC strength as other data chunks. This extra
ECC can guarantee BBM located in data chunk, of course, we need to check
if oob can afford it.
enlarge the maximum nand page size and oob size to
16k byte and 1280byte.
According to the latest datasheet(Rev. C Draft 1, 10/2015) of
i.MX7D, change the VDD_SOC voltage to 0.95V in run mode, and
add a 25mV margin to cover the IR drop and board tolerance.
So setting VDD_SOC voltage to 0.975V.
Signed-off-by: Bai Ping <b51503@freescale.com>
IC team releases new DDR script "EVK_IMX6UL_DDR3L_400MHz_16bit_V1.2.inc",
update it to DCD and plugin for i.MX6UL 14x14 EVK board.
Updated items:
Removed:
0x020c4084
0x021B0858
Value changed:
0x020E027C
0x020E0280
0x021B0008
0x021B000C
0x021B0010
0x021B0018
0x021B08C0
The script versions of EVK board and Validation Board from the following link:
http://compass.freescale.net/livelink/livelink?func=ll&objId=234191407&obj
Test Results:
Two boards passed overnight memtester stress test.
The PST bit can't be set too small which will cause performance drop.
Refer the commit for same issue on MX6UL 9x9 EVK, now fix it for 14x14 LPDDR2 ARM2
commit e1ca547d198dde94c4d8278c99499ec2d2008880
The actual memory size is 256MB not 512MB, otherwise it has a wrap
problem in memory and will cause memtester failed.
enable bank interleave feature to improve the performance
downloaded from
http://compass.freescale.net/livelink/livelink?func=ll&objId=234609508&objAction=browse&viewType=1
Before:
$ /opt/fsl-samples/g2d/g2d_test
Width 1920, Height 1088, Format RGBA, Bpp 32
---------------- g2d blit performance ----------------
g2d blit time 15566us, 64fps, 134Mpixel/s ........
g2d blending time 20672us, 48fps, 101Mpixel/s ........
g2d blend-dim time 13616us, 73fps, 153Mpixel/s ........
---------------- g2d clear performance ----------------
g2d clear time 8433us, 118fps, 247Mpixel/s ........
---------------- g2d rotation performance ----------------
90 rotation time 15366us, 65fps, 135Mpixel/s ........
180 rotation time 15374us, 65fps, 135Mpixel/s ........
270 rotation time 15373us, 65fps, 135Mpixel/s ........
g2d flip-h time 15373us, 65fps, 135Mpixel/s ........
g2d flip-v time 15372us, 65fps, 135Mpixel/s ........
After:
g2d blit time 2810us, 355fps, 743Mpixel/s ........
g2d blending time 4025us, 248fps, 518Mpixel/s ........
g2d blend-dim time 2740us, 364fps, 762Mpixel/s ........
g2d clear time 1846us, 541fps, 1131Mpixel/s ........
90 rotation time 5234us, 191fps, 399Mpixel/s ........
180 rotation time 3176us, 314fps, 657Mpixel/s ........
270 rotation time 5248us, 190fps, 398Mpixel/s ........
g2d flip-h time 2765us, 361fps, 755Mpixel/s ........
g2d flip-v time 3179us, 314fps, 657Mpixel/s ........
Signed-off-by: Robby Cai <r63905@freescale.com>
Add android and sata defconfig file.
Since the mx6ul 9x9 evk has different DDR size with 14x14 evk, change
to use the half of PHYS_SDRAM_SIZE for mtest end.
The DDR initialization in plugin needs to update conformably with DCD.
This piece of code is for mx7, we should not use
do_mx6_showclocks.
MMDC auto power saving timer can NOT be too small,
as enter/exit auto self-refresh mode too frequently
may introduce too many latency for MMDC access,
set it to 0x10, same as previous value on i.MX6.
Signed-off-by: Anson Huang <b20788@freescale.com>
Add i.MX6QP SabreSD board support.
Need to check fuse bit 25 of bank 0 word 4 before initialize bee.
The bit: 0 means bee enabled, 1 means bee disabled.
If disabled, continuing initialize bee will cause system hang, so
need to check this bit before initialize bee.
Add macro to enable BEE in header file, default disabled.
We meet reset failure on mx6ul 9x9 evk. The internal reset logic between MMDC and
functional modules seems relate with the issue.
Turn off the LCDIF to stop DDR access before reset to avoid this possible internal
reset problem.
The lpddr2 memsize of mx6ul_9x9_evk is 256MB, not 512M, so
the CS0_END should be 0x47, but not 0x4F.
Disable PFuze3000 low power mode during standby mode, otherwise,
if the power consumption exceed the threshold, PFuze will reboot.
Add new build target: mx6ul_9x9_evk_qspi1_config
Updated items:
memory set 0x307a0000 32 0x03040001 --> memory set 0x307a0000 32 0x01040001
This is just enable when LPDDR4 is enabled .
memory set 0x307a0064 32 0x0040005e --> memory set 0x307a0064 32 0x00400046
T_RFC_MIN this should be: RU(260ns*528Mhz)/2=69 (0x45)
memory set 0x307a00d0 32 0x00020001 --> memory set 0x307a00d0 32 0x00020083
PRE_CKE_X1024 be (500us*528Mhz/2)/1024 = 129, or 0x81
memory set 0x307a00d4 32 0x00010000 --> memory set 0x307a00d4 32 0x00690000
DRAM_RSTN_X1024 (200us*528Mhz)/1024=104, or 0x68
memory set 0x307a00e4 32 0x00090004 --> memory set 0x307a00e4 32 0x00100004
DEV_ZQINIT_X32 . Should be 16 clocks
memory set 0x307a0100 32 0x0908120a --> memory set 0x307a0100 32 0x09081109
T_FAW=(40ns*528Mhz)/2)=11
memory set 0x307a0104 32 0x0002020e --> memory set 0x307a0104 32 0x0007020d
tXPDLL=24ns*528Mhz=13clocks
File:
MX7D_EVK_DDR3_1GB_32bit.ds
Test result:
3 boards pass 2 days stress test.
i.MX6UL-9x9-EVK board has PFUZE3000, so enable LDO
bypass support for this board.
CONFIG_FASTBOOT is not used, since we have CONFIG_FSL_FASTBOOT and
CONFIG_CMD_FASTBOOT for fastboot. "drivers/fastboot" can be discarded.
In current design, if any peripheral was assigned to both A7 and M4,
it will receive ipg_stop or ipg_wait when any of the 2 platforms
enter low power mode. We will have a risk that, if A7 enter wait,
M4 enter stop, peripheral will have chance to get ipg_stop and ipg_wait
asserted same time.
There are 26 peripherals impacted by this IC issue:
SIM2(sim2/emvsim2)
SIM1(sim1/emvsim1)
UART1/UART2/UART3/UART4/UART5/UART6/UART7
SAI1/SAI2/SAI3
WDOG1/WDOG2/WDOG3/WDOG4
GPT1/GPT2/GPT3/GPT4
PWM1/PWM2/PWM3/PWM4
ENET1/ENET2
Software Workaround:
The solution is set M4 to a different domain with A core.
So the peripherals are not shared by them. This way requires
the uboot implemented the RDC driver and set the 26 IPs above to domain 0 only.
CM4 image will set the M4 to domain 1 only.
This patch enables the CONFIG_MXC_RDC for mx7d SABRESD board and ARM2 boards, and
setup the 26 IP resources to domain 0.
Add the peripherals/masters definitions and registers base addresses
for mx7d RDC. Enable the RDC driver by setting CONFIG_MXC_RDC.
When dcd_len is 0 the Write Data command that the set_dcd_rst_v2() routine
generates is empty. This causes HAB to complain that the command is invalid.
--------- HAB Event 1 -----------------
event data:
0xdb 0x00 0x0c 0x41 0x33 0x06 0xc0 0x00
0xcc 0x00 0x04 0x04
To fix this set the DCD pointer in the IVT to NULL in this case. The DCD header
itself is still needed for detect_imximage_version() to determine the image
version.
tools/imximage.c
cherry-picked from
http://git.denx.de/?p=u-boot/u-boot-imx.git;a=commitdiff;h=873bf926bfbb0a667158261813115fa6819661b7
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
(cherry picked from commit 873bf926bfbb0a667158261813115fa6819661b7)
This mx7d 19x19 lpddr2 arm2 board is based on 19x19 lpddr3 arm2 board
with DDR changed to 512M LPDDR2. We added DDR script for LPDDR2 and
a new u-boot build target: mx7d_19x19_lpddr2_arm2_config
LPDDR2 script source: lpddr2_0_1.ds
Since the i.MX6ul 9x9 evk board only has 256MB LPDDR2, while the
CMA size used in kernel configuration is 320MB, so we have to set
another value for the 9x9 evk board.
This patch sets the cma=96M bootargs to in uboot. So the kernel will
overwrite to use the new value.
The i.mx6ul 9x9 EVK shares the same base board with 6ul 14x14 EVK
with two main changes on CPU board:
1. Change to use pfuze 3000.
2. Use 256MB LPDDR2 memory.
This patch uses a macro CONFIG_6UL_9X9_LPDDR2 to distinguish the changes above,
basing on 14x14 EVK board level codes.
The new build target for the 9x9 EVK: mx6ul_9x9_evk_config
we change it to other values(sabresd dq and auto 6qp 0812 daily build)
Correct the bootargs which is printed.
It should be newbootargs rather than bootimage's bootargs.
Signed-off-by: zhang sanshan <b51434@freescale.com>
In LPSR mode, wdog will be reset when resume, need
to disable wdog powerdown timer to avoid system
reset after timeout setting of 16 seconds.
As we need to support LPSR mode resume and due to hardware
design requirement, DCD can NOT put DRAM exit from retention
mode, so only plug in mode can do that to support LPSR mode,
so enabled plug in mode by default for imx7d 12x12-lpddr3-arm2
board.
For imx7d 12x12-lpddr3-arm2 board, when system enters LPSR
mode and waked up, ARM core will be reset and uboot needs to be
executed first, the LPSR register contains a resume entery,
if this entry is non-zero, then it means it is a resume from
LPSR mode, uboot plug in code needs to make DRAM exit from
retention mode then jump to the entry directly, otherwise,
it is a cold boot, normal boot process will be performed.
Since setup_waveform_file in different boards code have same implementation,
move setup_waveform_file to board common code. Also rename it to
board_setup_waveform_file
This patch also fix a bug when using flush_cache. We should pass
'waveform_buf' to flush_cache, but not a string named 'addr'.
Support draw image on E-ink screen.
1. The image format should be PGM-P5 raw data format.
2. The image should be named epdc_logo.pgm.
3. If no epdc_logo.pgm found in the first partition(FAT), will choose
to draw black border on the screen.
4. Default configuration is to draw image at pos (0,0). If 'splashpos'
env is set, will choose the pos from 'splashpos'.
5. The image size should not be bigger than screen total pixel size.
6. Implement board_setup_logo_file in board/freescale/common/epdc_setup.c
7. Introudce function prototype for board_setup_logo_file.
Note: i.MX7D EPDC supports advanced mode and standard mode. Since current
PXP in uboot for i.MX7D not ready, only support standard mode now.
advanced and standard mode needs waveform firmware's support.
Datasheet Rev-B defines standby voltage as 1V for i.MX7D, we add
25mV for board level IR drop.
There is narrow window that PRE driver is ready but GPU driver probe later,
and the later GPU driver turn on PU may cause 'PRE hang' issue. To simplify
thing, do not turn off PU in u-boot.
Signed-off-by: Robin Gong <b38343@freescale.com>
(cherry picked from commit 6b0787b726e2ff32210d742d93ecd3f4bb2ae402)
As the HDMI splash screen feature is not well supported,
we should not set it to be the default display. In case,
users leave the 'panel' uboot environment variable empty
and connect the board with a HDMI monitor, the HDMI detect
funtion will work and enable the HDMI splash screen. So,
this patch disables HDMI detect function so that users
may only explicitly set the 'panel' variable to be 'HDMI'
to use HDMI splash screen.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
The bootargs is not set correctly.
The final bootargs consist of uboot's bootargs and bootimg's bootargs.
This patch set bootimg's bootargs as final bootargs if uboot's bootargs is not set.
And take uboot's bootargs as final bootargs if uboot's bootargs is set.
'fastboot reboot-bootloader' is took as 'fastboot reboot' in V2015.04.
The length of fastboot command is decided by the length of cmd_dispatch_info's cmd.
So need put reboot-bootloader in front of reboot.
This pin is missed to change in patch:
"MLK-11230 imx6: USB: Modify OTG ID pin pad setting to pull up"
Should set it to pull down at default.
The SW1AB on PMIC is used for ARM_SOC_IN supply, set the standby voltage to
0.975V to save power when system is in DSM mode.
For USB boot, eg, mfgtool programming case, some laptops/pcs
may not work properly if the board do not disconnect until
linux kernel usb driver initialization process, finishes the
ROM code connection at u-boot can fix this problem, and this
was the original work flow when mfgtool flow was introduced at
u-boot.
Tested-by: Spring Zhang <b17931@freescale.com>
Tested-by: Zhang Sanshan <b51434@freescale.com>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Add disconnect_from_pc API which is used to disconnect the connection
with PC which is established at rom code.
To CD/VSELECT/RST, should use same pad settings with USDHC_PAD_CTRL,
because default NO_PAD_CTRL's settings is 100K Pull-Down. But, we need
pull-up for CD/VSELECT/RST.
Also some board provides external pull-down/up, we'd better use internal
pull-up for these pad settings.
To mx7d_12x12_lpddr3_arm2:
If no card plugged in, "mmc dev 1" will show "Card did not respond to
voltage select". After apply this patch, it will show "MMC: no card present".
To mx7dsabresd:
Alougth without this patch, if no card plugged in sd1, still correct msg
"MMC: no card present", anyway we'd better use pull-up.
