path: root/.gitignore
2013-10-03colibri_vf50: migrate nand vs. sdboot configurationMarcel Ziswiler
Migrate to default NAND boot configuration (e.g. colibri_vf50_config) and SD card boot on request (e.g. colibri_vf50_sdboot_config). Automatically do the padding required for NAND boot image (e.g. u-boot.nand). This is also more in-line with how we did stuff back on the Colibri T20.
2011-12-24arm, davinci: Add support for generating AIS images to the MakefileChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2011-11-11iMX28: Add u-boot.sb target to MakefileMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-10-26fdt: Add support for a separate device tree (CONFIG_OF_SEPARATE)Simon Glass
This adds support for an FDT to be build as a separate binary file called u-boot.dtb. This can be concatenated with the U-Boot binary to provide a device tree located at run-time by U-Boot. The Makefile is modified to provide this file in u-boot-dtb.bin. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17Adjust dependency rules to permit per-file flagsSimon Glass
The dependency rules are currently done in a shell 'for' loop. This does not permit Makefile variables to adjust preprocessor flags as is done with normal compile flags, using the CFLAGS_path/file.o syntax. This change moves the dependency generation into the Makefile itself, and permits a CPPFLAGS_path/file.o to adjust preprocessor flags on a file or directory basis. The CPPFLAGS_... variable is also folded into CFLAGS during the build. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-06Tell git to ignore asm-offsets.sLaurence Withers
The generated file asm-offsets.s may be found at various depths in the arch subdirectories, so simply ignore it throughout the tree. Signed-off-by: Laurence Withers <lwithers@guralp.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-30omap4_panda: Ignore omap4 SPL called MLOJoe Hershberger
Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-21ignore soc asm-offsets.sMike Frysinger
Recent commit a4814a69d3bca6ee05f4bfc4 cleaned up generation of asm-offsets.s for SoC dirs, but missed adding it to the ignore list which makes it show up in `git status`. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-05-22.gitignore: update list of u-boot.* files and add *.binecc
This patch adds additional u-boot.* files mentioned in Makefile, and adds *.bin since these are deleted as part of "make clean". Signed-off-by: Eric Cooper <ecc@cmu.edu>
2011-01-17.gitignore: ignore generated u-boot.imxStefano Babic
2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-23.gitignore: ignore generated u-boot.ldsMike Frysinger
2009-07-21Add "tags" to .gitignore file.Po-Yu Chuang
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-05ignore .gdb_history filesMike Frysinger
When using gdb, history files will often get generated. So ignore them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-09gitignore: add tags files and Vim swap fileMarkus Heidelberg
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
2008-08-06Fix merge problemsStefan Roese
2008-04-18gitignore: udpate stgit generated and .patch fileJean-Christophe PLAGNIOL-VILLARD
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14Add *~ to .gitignoreNiklaus Giger
One should never add a backup file ending in with ~ to the git repository. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-04generate u-boot.ldr for Blackfin targetsMike Frysinger
2008-01-09Add missing file in gitignore and commentsJean-Christophe PLAGNIOL-VILLARD
based on Linux source tree's .gitignore files Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-15Add .gitignore filesGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kim Phillips <kim.phillips@freescale.com>
