25 hoursall: update layers from master to scarthgap branchscarthgap-7.x.yHiago De Franco
Layers that were using the master branch and have a scarthgap branch available now: - meta-arm - meta-freescale - meta-freescale-3rdparty - meta-freescale-distro - meta-openembedded - meta-qt5 - meta-security - meta-ti - meta-virtualization Therefore update the branches to scarthgap and set the revision to the last commit present now. Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
2024-03-12Bump git hashesci.toradex
Bump git hashes to latest head as of March 12. Related-to: ELB-5617 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-03-07bsp: move branch to scarthgap-7.x.yMax Krummenacher
Move the branch checked out to scarthgap where already branched. Related-to: ELB-5617 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-03-07base: move branch to scarthgapMax Krummenacher
2024-03-04gitlab-ci: no longer modify repo shebangRogerio Guerra Borin
Google updated the repo command to use python3 by default so that now the modification of the interpreter is no longer necessary. Signed-off-by: Rogerio Guerra Borin <rogerio.borin@toradex.com> (cherry picked from commit e4b70deaf8bf8bb7bdbee4705709d3cfe9202d7c)
2024-01-29torizoncore: add new torizon Github repoEduardo Ferreira
We've migrated meta-toradex-torizon to github.com/torizon, so we're adding this new repo to our manifests, and renaming accordingly: * github.com/toradex -> toradex * github.com/torizon -> torizon Related-to: TOR-3369 Signed-off-by: Eduardo Ferreira <eduardo.barbosa@toradex.com>
2023-12-18manifest: add meta-security for tpm to masterJoao Paulo Goncalves
Some Toradex hardware started to include a TPM device so for its software support add meta-security to the manifest making possible to use meta-tpm layer. Related-to: ELB-5500 Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
2023-10-11torizoncore: add meta-toradex-security layer to manifestEduardo Ferreira
Related-to: TOR-3162 Change-Id: I4634834396cc0166189691e411c4fdcb3be52701 Signed-off-by: Eduardo Ferreira <eduardo.barbosa@toradex.com>
2023-09-25tezi: checkout master branch if availableMax Krummenacher
In the tezi manifest we still have some layers checking out kirkstone, even if the layers would have a master branch. Change to master. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2023-09-25meta-toradex-ti: checkout the newly created master branchMax Krummenacher
Related-to: ELB-5357 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2023-05-02gitlab-ci: refactorMax Krummenacher
- use one of our regular containers. (with a fixup for /usr/bin/python missing) - keep the artefacts inside the checked out git repo Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 495b48717be1dbfb415e427613a48099f553889a)
2023-05-02update ci script with tezi manifestsPhilippe Schenker
Related-to: ELB-4127 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> (cherry picked from commit 84aaadb2acebdafb812874a7935483dcb3bbcc59) (cherry picked from commit 0af4f74ab7a9db87f705db5815e6b9febfc2176e)
2023-05-02tezi: add to master manifestMax Krummenacher
meta-toradex-tezi currently stays at kirkstone-6.x.y until we have this up and running. Related-to: TEI-1055 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2023-04-18manifest: prepare for verdin am62 additionMax Krummenacher
Related-to: ELB-4978 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2023-01-30Bump git hashesci.toradex
Bump git hashes as used in extint build of Mon Jan 30 13:01:20 UTC 2023 Matrix Build: image-torizoncore-master-extint-matrix 141 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-master-extint-matrix/141 Signed-off-by: ci.toradex <cicd@toradex.com>
2022-08-08torizoncore: fix sha after master branch rewriteMax Krummenacher
meta-toradex-torizon has its master branch reworked so that the older git hash no longer exists. Fix the repo sync step by providing current head of master. Fixes: | $ ../bin/repo sync | error.GitError: Cannot fetch meta-toradex-torizon update-ref: fatal: 6054c5e5df22c7e3c9b25ac865417695ebe1eca3^0: not a valid SHA1 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2022-08-03manifests:tdx: drop meta-toradex-tegraMing Liu
We wont maintain meta-toradex-tegra in master, drop it. Related-to: ELB-4471 Signed-off-by: Ming Liu <ming.liu@toradex.com>
2022-07-06torizoncore: update external hashesSergio Prado
Also move meta-updater to the Uptane space on GitHub. Related-to: TOR-2213 Signed-off-by: Sergio Prado <sergio.prado@toradex.com> (cherry picked from commit e7d2316c407f9a6fce95944f21af88fbfe84d2cd)
2022-07-06torizoncore: remove meta-lmpSergio Prado
TorizonCore does not use meta-lmp anymore, so let's remove it. Related-to: TOR-2247 Signed-off-by: Sergio Prado <sergio.prado@toradex.com> (cherry picked from commit 17e25f4eef2283c7e6866148a0432152bed5b5bb)
2022-07-06Bump git hashesci.toradex
Bump git hashes as used in extint build of Tue Jul 5 18:36:11 UTC 2022 Matrix Build: image-tdxref-master-extint-matrix 208 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-master-extint-matrix/208 Signed-off-by: ci.toradex <cicd@toradex.com> Updated meta-toradex-* hashes in pinned/default.xml. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2022-05-03Bump git hashes as used in extint build of Sat Apr 30 11:58:19 UTC 2022Toradex CI
Matrix Build: image-torizoncore-master-extint-matrix 90 Matrix Build Status: FAILURE Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-master-extint-matrix/90 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2022-03-28Bump git hashesci.toradex
Bump git hashes as used in extint build of Sun Mar 27 14:06:31 UTC 2022 Matrix Build: image-tdxref-master-extint-matrix 177 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-master-extint-matrix/177 Signed-off-by: ci.toradex <cicd@toradex.com>
2021-10-20Bump git hashesci.toradex
Bump git hashes as used in extint build of Tue Oct 19 14:17:55 UTC 2021 Matrix Build: image-tdxref-master-extint-matrix 133 Matrix Build Status: SUCCESS Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-master-extint-matrix/133 Signed-off-by: ci.toradex <cicd@toradex.com>
2021-07-12bump meta-toradex-* layersMax Krummenacher
Bump the layers to latest with cherry-picks of what is used in dunfell-5.3.0 quarterly plus updates to make colibri-vf build. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-07-12Bump git hashes as used in nightly build of Jul 10, 2021Max Krummenacher
The build matrix with these hashes was successfully built. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-07-08add gitlab-ciMax Krummenacher
Import from dunfell-5.x.y branch @ 1687afa. This does a repo init; repo sync. It will fail if any of the layers cannot be cloned at the given revision. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-11-30Bump git hashesToardex CI
Bump git hashes as used in extint build of Sat Nov 7 11:04:04 UTC 2020 Matrix Build: image-torizoncore-master-extint-matrix 22 Matrix Build Status: FAILURE Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-master-extint-matrix/22 Signed-off-by: ci.toradex <cicd@toradex.com>
2020-10-26Bump git hashesci.toradex
Bump git hashes as used in extint build of Sun Oct 25 2020. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Change-Id: I011188f854bb19a45bb82a9caecb212a8d12f02d
2020-08-20Update layer hashes of bsp/tdxref/torizoncoreMarcel Ziswiler
2020-08-12torizoncore:integration.xml: update hashes of external layersMing Liu
To involve in some fixes from external layers, basically for: meta-updater: ``` 235da14 image_repo_manifest.bbclass: explicitly call python3 c6df41e aktualizr: Bump to latest and install headers in dev package. 628c4e3 Inherit python3native instead of using HOSTTOOLS. ``` Related-to: TOR-1283 Signed-off-by: Ming Liu <ming.liu@toradex.com>
2020-08-03Update layer hashes of tdxref/torizoncoreMing Liu
Related-to: TOR-1239 Signed-off-by: Ming Liu <ming.liu@toradex.com>
2020-07-27Revert "torizoncore: drop a .git suffix to be consistent with other layers"Ming Liu
This reverts commit 8467ec79ec58508a59bfc9e01203cc77a178980c.
2020-07-24torizoncore: drop a .git suffix to be consistent with other layersMing Liu
Drop a .git suffix from meta-toradex-distro layer to be consistent with other layers. Related-to: TOR-1126 Signed-off-by: Ming Liu <ming.liu@toradex.com>
2020-07-24torizoncore:default.xml: update hashes of meta layersMing Liu
Update hashes of the following external meta layers: - meta-lmp - meta-security - meta-updater - meta-virtualization Also update hashes of toradex meta layers: - meta-toradex-distro - meta-toradex-torizon Related-to: TOR-1126 Signed-off-by: Ming Liu <ming.liu@toradex.com>
2020-07-23torizoncore:integration.xml: update hashes of external layersMing Liu
2020-07-23tdxref: default.xml: bumb meta-toradex-distro hashPhilippe Schenker
meta-qt5 layer got added and recipe names changed. Bump the hash so builds are not failing due to missing bblayers.conf. Related-to: ELB-2838 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2020-07-22tdxref: add meta-qt5Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Change-Id: I967c29d7a6dccaaa9189af665770663157f172f3
2020-07-09Merge branch 'fix_bitbake_path' into 'master'Max Krummenacher
torizoncore/default.xml: bump meta-toradex-torizon See merge request rd/linux-bsp/toradex-manifest!3
2020-07-09torizoncore/default.xml: bump meta-toradex-torizonSergio Prado
Bump meta-toradex-torizon to latest commit on master. This will fix a problem with the bitbake path that is preventing the pipelines from running. Signed-off-by: Sergio Prado <sergio.prado@e-labworks.com>
2020-07-07Merge branch 'master' into 'master'Marcel Ziswiler
layer branches: add latest head and set all branches to master See merge request rd/linux-bsp/toradex-manifest!1
2020-07-06layer branches: add latest head and set all branches to masterMax Krummenacher
2020-06-22initial commitMax Krummenacher
This unifies and replaces the following manifests starting from version 5.x.y: http://git.toradex.com/toradex-bsp-platform.git https://github.com/toradex/toradex-torizon-manifest.git Related-to: ELB-2755 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
