Related-to: TOR-3072
Change-Id: I6171ca2a42a75885ccba70357e97967fd9772e95
Signed-off-by: Eduardo Ferreira <eduardo.barbosa@toradex.com>
Bump git hashes as used in nightly build of Thu 03 Aug 2023 02:39:18 AM UTC
Matrix Build: image-torizoncore-kirkstone-6.x.y-nightly-matrix 346
Matrix Build Status: FAILURE
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-nightly-matrix/346
Signed-off-by: ci.toradex <cicd@toradex.com>
Bump git hashes as used in extint build of Sat 22 Jul 2023 05:26:16 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-extint-matrix 69
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-extint-matrix/69
Related-to: TOR-2905
Change-Id: I5d3910b01531c4deabc875e47673524ec6ce843a
Signed-off-by: Thomas Keller <thomas.keller@toradex.com>
Bump git hashes as used in nightly build of Wed 05 Jul 2023 07:18:29 AM UTC
Matrix Build: image-tezi-kirkstone-6.x.y-nightly-matrix 50
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-kirkstone-6.x.y-nightly-matrix/50
Bumping meta-security, meta-updater and meta-virtualization for both
integration.xml and default.xml.
Related-to: TOR-2700
Change-Id: I7dabec373c80df3052a3f8ed13e3fbcdaf03ce31
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
Related-to: TOR-2904
Change-Id: I8a4e9dc94cfb826fe61550c97dce8823e0b91402
Bump git hashes as used in nightly build of Fri 02 Jun 2023 11:14:13 AM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 300
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/300
Bump git hashes as used in extint build of Fri 02 Jun 2023 11:27:30 AM UTC
Matrix Build: image-tezi-kirkstone-6.x.y-extint-matrix 3
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-kirkstone-6.x.y-extint-matrix/3
Bump git hashes as used in nightly build of Fri 26 May 2023 03:14:21 PM UTC
Matrix Build: image-tezi-kirkstone-6.x.y-nightly-matrix 15
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-kirkstone-6.x.y-nightly-matrix/15
Pull in from dunfell-5.x.y commit 9f32a31 ("tester: bump git hashes")
Add missing ti layers.
Signed-off-by: Samuel Bissig <samuel.bissig@toradex.com>
Bump git hashes as used in extint build of Sat 20 May 2023 05:51:03 PM UTC
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 45
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/45
Related-to: TOR-2903
Change-Id: Iff36e8b8424fb1c022759a95471508ceae4f04a6
Bump git hashes as used in nightly build of Tue 02 May 2023 01:38:52 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 275
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/275
- use one of our regular containers. (with a fixup for /usr/bin/python missing)
- keep the artefacts inside the checked out git repo
(cherry picked from commit 438a914de6054490c8a1edbb5d3a441a69ece49e)
Related-to: ELB-4127
(cherry picked from commit 84aaadb2acebdafb812874a7935483dcb3bbcc59)
Related-to: TEI-1055
Bump git hashes as used in extint build of Sat 22 Apr 2023 04:20:38 PM UTC
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 41
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/41
Related-to: TOR-2712
Change-Id: I1355200b182dcff4aa6480cf085edf07a58f931b
Bump git hashes as used in nightly build of Mon 03 Apr 2023 11:13:19 AM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 252
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/252
Related-to: TOR-2711
Change-Id: I6723b3582b9a6dad3b631c10b12ed774d3a979e6
Bump git hashes as used in nightly build of Thu 02 Mar 2023 09:29:40 AM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 218
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/218
Bump git hashes as used in extint build of Sun 26 Feb 2023 02:36:43 AM UTC
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 33
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/33
Related-to: TOR-2457
Related-to: ELB-4978
Related-to: TOR-2710
Change-Id: I332811eed747037a245b15827ff0a41991068023
Bump git hashes as used in nightly build of Wed Feb 1 16:56:35 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 189
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/189
Bump git hashes as used in extint build of Sat Jan 28 19:18:52 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-extint-matrix 41
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-extint-matrix/41
Related-to: TOR-2464
Bump git hashes as used in nightly build of Thu Jan 5 09:50:55 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 164
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/164
Bump git hashes as used in nightly build of Wed Jan 4 13:58:49 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 161
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/161
Now that we bumped openembedded-core layer, they removed the 'copy_data'
function, which was used by meta-updater layer, causing this build
failure on jenkins:
12-29:21:15:07 File "/workdir/oe/build/conf/../../layers/meta-updater/classes/sota_sanity.bbclass",
line 100, in defaultsota_check_sanity_eventhandler(e=<bb.event.SanityCheck object at 0x7f78e56a1048>):
12-29:21:15:07 if bb.event.getName(e) == "SanityCheck":
12-29:21:15:07 > sanity_data = copy_data(e)
12-29:21:15:07 if e.generateevents:
12-29:21:15:07 NameError: name 'copy_data' is not defined
So we bnuump meta-updater layer to get a fix for this function.
Change-Id: I9e1b7cd49f2f44ba6f25f8fa74562e10b13f7b67
Bump git hashes as used in extint build of Sat Dec 24 23:37:34 UTC 2022
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 23
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/23
Related-to: TOR-2463
Change-Id: I2a96c1817c6d76781b9b88253e2c0db56ea64196
Bump git hashes as used in nightly build of Thu Dec 1 09:43:38 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 129
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/129
Bump git hashes as used in extint build of Mon Nov 28 19:11:21 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-extint-matrix 31
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-extint-matrix/31
Bump git hashes as used in extint build of Sun Nov 27 04:49:41 UTC 2022
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 19
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/19
Related-to: TOR-2325
Related-to: TOR-2462
Change-Id: Ie9f5711cd79ba56f510488cf7334070b2e6a47ff
Bump git hashes as used in nightly build of Wed Nov 2 13:37:05 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 98
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/98
Bump git hashes as used in extint build of Sat Oct 22 17:22:16 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-extint-matrix 22
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-extint-matrix/22
Related-to: TOR-2329
Change-Id: Iec3106a4502b82ccd4896d9b0b293eb7f6cfdf4b
Bump git hashes as used in nightly build of Wed Oct 5 22:29:57 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 77
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/77
Bump git hashes as used in extint build of Sun Sep 18 05:20:59 UTC 2022
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 7
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/7
Related-to: TOR-2328
Change-Id: I7f5f56526534693f9e9556f2fe363892d179f086
