Related-to: TOR-2710
Change-Id: I332811eed747037a245b15827ff0a41991068023
Signed-off-by: Eduardo Ferreira <eduardo.barbosa@toradex.com>
Bump git hashes as used in nightly build of Wed Feb 1 16:56:35 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 189
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/189
Signed-off-by: ci.toradex <cicd@toradex.com>
Bump git hashes as used in extint build of Sat Jan 28 19:18:52 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-extint-matrix 41
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-extint-matrix/41
Related-to: TOR-2464
Bump git hashes as used in nightly build of Thu Jan 5 09:50:55 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 164
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/164
Bump git hashes as used in nightly build of Wed Jan 4 13:58:49 UTC 2023
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 161
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/161
Now that we bumped openembedded-core layer, they removed the 'copy_data'
function, which was used by meta-updater layer, causing this build
failure on jenkins:
12-29:21:15:07 File "/workdir/oe/build/conf/../../layers/meta-updater/classes/sota_sanity.bbclass",
line 100, in defaultsota_check_sanity_eventhandler(e=<bb.event.SanityCheck object at 0x7f78e56a1048>):
12-29:21:15:07 if bb.event.getName(e) == "SanityCheck":
12-29:21:15:07 > sanity_data = copy_data(e)
12-29:21:15:07 if e.generateevents:
12-29:21:15:07 NameError: name 'copy_data' is not defined
So we bnuump meta-updater layer to get a fix for this function.
Change-Id: I9e1b7cd49f2f44ba6f25f8fa74562e10b13f7b67
Bump git hashes as used in extint build of Sat Dec 24 23:37:34 UTC 2022
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 23
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/23
Related-to: TOR-2463
Change-Id: I2a96c1817c6d76781b9b88253e2c0db56ea64196
Bump git hashes as used in nightly build of Thu Dec 1 09:43:38 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 129
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/129
Bump git hashes as used in extint build of Mon Nov 28 19:11:21 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-extint-matrix 31
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-extint-matrix/31
Bump git hashes as used in extint build of Sun Nov 27 04:49:41 UTC 2022
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 19
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/19
Related-to: TOR-2325
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
Related-to: TOR-2462
Change-Id: Ie9f5711cd79ba56f510488cf7334070b2e6a47ff
Bump git hashes as used in nightly build of Wed Nov 2 13:37:05 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 98
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/98
Bump git hashes as used in extint build of Sat Oct 22 17:22:16 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-extint-matrix 22
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-extint-matrix/22
Related-to: TOR-2329
Change-Id: Iec3106a4502b82ccd4896d9b0b293eb7f6cfdf4b
Bump git hashes as used in nightly build of Wed Oct 5 22:29:57 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 77
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/77
Bump git hashes as used in extint build of Sun Sep 18 05:20:59 UTC 2022
Matrix Build: image-torizoncore-kirkstone-6.x.y-extint-matrix 7
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-extint-matrix/7
Related-to: TOR-2328
Change-Id: I7f5f56526534693f9e9556f2fe363892d179f086
Bump git hashes as used in nightly build of Fri Sep 2 11:09:54 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 49
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/49
Use kirkstone-6.x.y for all meta-toradex-* layers as the branches now
got created.
While at it also bump the hashes of these layers to the latest hash.
Related-to: ELB-4618
Bump git hashes as used in extint build of Tue Aug 30 15:51:55 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-extint-matrix 12
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-extint-matrix/12
meta-updater has recently created the kirkstone branch.
Bump git hashes as used in extint build of Sat Aug 6 21:35:39 UTC 2022
Matrix Build Status: FAILURE
We wont maintain meta-toradex-tegra since BSP6, drop it.
Related-to: ELB-4471
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Also update the hashes to latest.
Related-to: TOR-2122
In preparation of BSP 6 set all layers not provided from Toradex to the
latest of their kirkstone branches. (meta-updater didn't fork yet so it
is kept on master)
Related-to: ELB-4476
Also move meta-updater to the Uptane space on GitHub.
Related-to: TOR-2213
(cherry picked from commit e7d2316c407f9a6fce95944f21af88fbfe84d2cd)
TorizonCore does not use meta-lmp anymore, so let's remove it.
Related-to: TOR-2247
(cherry picked from commit 17e25f4eef2283c7e6866148a0432152bed5b5bb)
Bump git hashes as used in extint build of Tue Jul 5 18:36:11 UTC 2022
Matrix Build: image-tdxref-master-extint-matrix 208
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-master-extint-matrix/208
Updated meta-toradex-* hashes in pinned/default.xml.
Matrix Build: image-torizoncore-master-extint-matrix 90
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-master-extint-matrix/90
Bump git hashes as used in extint build of Sun Mar 27 14:06:31 UTC 2022
Matrix Build: image-tdxref-master-extint-matrix 177
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-master-extint-matrix/177
Bump git hashes as used in extint build of Tue Oct 19 14:17:55 UTC 2021
Matrix Build: image-tdxref-master-extint-matrix 133
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-master-extint-matrix/133
Bump the layers to latest with cherry-picks of what is used in
dunfell-5.3.0 quarterly plus updates to make colibri-vf build.
The build matrix with these hashes was successfully built.
Import from dunfell-5.x.y branch @ 1687afa.
This does a repo init; repo sync.
It will fail if any of the layers cannot be cloned at the given revision.
Bump git hashes as used in extint build of Sat Nov 7 11:04:04 UTC 2020
Matrix Build: image-torizoncore-master-extint-matrix 22
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-master-extint-matrix/22
Bump git hashes as used in extint build of Sun Oct 25 2020.
Change-Id: I011188f854bb19a45bb82a9caecb212a8d12f02d
To involve in some fixes from external layers, basically for:
meta-updater:
235da14 image_repo_manifest.bbclass: explicitly call python3
c6df41e aktualizr: Bump to latest and install headers in dev package.
628c4e3 Inherit python3native instead of using HOSTTOOLS.
Related-to: TOR-1283
Related-to: TOR-1239
This reverts commit 8467ec79ec58508a59bfc9e01203cc77a178980c.
Drop a .git suffix from meta-toradex-distro layer to be consistent with
other layers.
Related-to: TOR-1126
Update hashes of the following external meta layers:
- meta-lmp
- meta-security
- meta-updater
- meta-virtualization
Also update hashes of toradex meta layers:
- meta-toradex-distro
- meta-toradex-torizon
meta-qt5 layer got added and recipe names changed. Bump the hash
so builds are not failing due to missing bblayers.conf.
Related-to: ELB-2838
Change-Id: I967c29d7a6dccaaa9189af665770663157f172f3
