There are issues with running it with the mesa EGL component.
Adjusted update scripts for fast boot mode migration as per the
following article on our developer website:
http://developer.toradex.com/knowledge-base/linux-booting#eMMC_Fast_Boot_Mode_ApalisColibri_iMX6
pcman-fm and gtk RRECOMMEND adwaita.
Do not install them and keep the lxde-icon-theme
On the tegras we have to stay with gstreamer 0.10.
Address the following warnings:
WARNING: QA Issue: nvsamples rdepends on libice, but it isn't a build dependency? [build-deps]
WARNING: QA Issue: nvsamples rdepends on libsm, but it isn't a build dependency? [build-deps]
We want to append to the generic VAR when we build for a tegra machine.
Using VAR_tegra += "" creates a machine specific VAR.
With the Linux 4.4 kernel a new DRM driver for the Display Controller Unit
(DCU) is available. To make direct use of the DRM driver use the Xorg
modesetting driver instead of the fbdev driver. This also allows to use
xrandr.
The Linux Kernel 4.4 for Colibri VF does currently not support the needed
interfaces for mcc.
e.g. look for files in ${board} subdirectory rather than in the media's root.
As we inject binary only drivers drop the DEPENDS and skip the checks
if all referenced shared objects have been built as a dependency.
Newer xserver recipes dropped some packages, move them to RRECOMMEND
rather than adding it to IMAGE_INSTALL. That way the image build
independently of the used xserver version.
midory has been dropped from oe-core
When building for a second machine after building for one the rootfs
creation fails because some license files are not found.
I belive this is caused by the following commit:
https://github.com/Angstrom-distribution/meta-angstrom/commit/dae094d69a1f8651c822fb35d606bf59a615f244
All packages which are created from sstate fail do install in the rootfs
likely because the license file is only available in the subdirectory of
the machine for which it was originally built.
Write kernel and device tree into seperate UBI Volumes. This
allows to use a lot less UBI/UBIFS support in U-Boot, which
should lower the risk of hitting bugs in this area. Boot times
are also slightly faster (measurements showed an improvement of
~150ms).
Enable USB suspend resume fix for Vybrid.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
When using TFTP update, the rootfs must be in decimal numbered chunks on the
tftp server. U-Boot reads the chunks, but does count hexadecimal thus
limiting the number of chunks to 10.
The U-Boot binary for the IT temperature range changed names from
u-boot-it.imx to u-boot.imx-it.
The flash_*.scr scripts did still use the old name resulting in the U-Boot
not being found on the SD card or TFTP server.
Avoids
WARNING: Unable to get checksum for gpioconfig SRC_URI entry GPIOConfig: file could not be found
during recipe parse by providing a dummy GPIOConfig.
The dummy displays a popup with a button that says that the program is not
available on this machine.
(cherry picked from commit e6959294ac99c87c7aabe2334d6582618ea3a825)
This has been missing since our move to boot from the eMMC boot partition.
While at it clarify update.sh help. _it applies only to
Apalis iMX6 IT modules.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
to meta-fsl-arm-extra.
The command 'mmc partconf 0 1 1 0' seems to have no effect when it is in the
middle of our migration cmdline resulting in U-Boot still being loaded from
the user partition.
Putting it as the last command seems to solve the issue.
http://developer.toradex.com/software-resources/arm-family/linux/linux/release-details?view=all&issue=14774
The LM006 USB WiFi adapter uses a Realtek RTL8188CUS chipset,
which requires the compatible firmware RTL8192CU.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
With the cfgblock command in U-Boot we now have a better solution.
Don't write the eMMC twice on Apalis in the not migrate case.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
Up until now, U-Boot for Colibri VF50/VF61 did not had an
environment variable board_name. Use the soc environment
variable to set the board_name.
To avoid code duplication call fwd_blk from fwd_mmc. This adds
one more indirection, but since flash_mmc.img is a compatibility
script anyway it is not the common case...
Source the update script only if loading succeeded. This avoids
loops if board_name is not set. Also add a test if board_name is
really set since this variable is/was not available in older
U-Boots.
Further generalise U-Boot update scripts by using ${board_name} instead
of hard coding module name like apalis_t30, colibri_t20 or colibri_t30.
Even though our downstream L4T based kernel does not use any
device tree stuff prepare for easy deployment thereof by using the
correct dtb name.
In the Ethernet aka TFTP update case this actually fixes an issue where
it previously tried to TFTP the whole ${board_name} directory which at
least on my setup failed with a permission denied which it retried
forever.
Deploy and enable CPU hot-plug configuration and startup on our T30
based modules. This significantly reduces power-consumption and
therefore improves thermal characteristics.
meta-openembedded provides a recipe for joe, use that one.
