path: root/recipes-qt
2015-02-17qt-demo-init: converted to systemd serviceStefan Agner
Convert qt-demo-init to a systemd service. The service will only start when the systemd target is set to graphical, hence also set the new default target of the qt4e-demo-image to graphical.
2015-01-14qt4-x11-free: append to DEPENDS, not overwrite itMax Krummenacher
2014-12-08qt4-x11-free-systemd.bb: move init script to /usr/binStefan Agner
Due to the move to systemd, all init scripts located under /etc/init.d get deleted by the inherited systemd recipes (systemd.inc). Since we don't use the script as a system V init script, we can move the script to /usr/bin.
2014-12-08qt4 bbappend: add dependencies to OpenGL ES2Stefan Agner
Since we explicitly ask to build Qt for OpenGL ES2, we should also make OpenGL ES2 as a explicit dependency.
2014-10-06qt5: fix build failure with V2.3 imagesMax Krummenacher
2014-08-04qt4-x11-free-systemd.bb: Update after toplevel LICENSE file checksum changeMax Krummenacher
2014-08-04qt-demo-init: Update after toplevel LICENSE file checksum changeMax Krummenacher
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-06-25qt5: config for gles and build examplesraul
2014-04-01qt4 bbappend: update to match bb versionMax Krummenacher
2013-11-21qtdemo-init: Add start script for qtdemoEMax Krummenacher
2013-11-21qt4-embedded: configure for all supported screen depthsMax Krummenacher
2013-10-11qt4-embedded: configure with -depths genericMax Krummenacher
2013-09-22systemd: adapt to new systemd handlingMax Krummenacher
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed
2013-09-22qt4: follow update of recipe with bbappendMax Krummenacher
2013-03-27images: added a QT4 X11 imageMax Krummenacher
- bbappends to the base qt4-x11-free recipe to use OpenGL ES2 - script which starts X plus qtdemo, including a systemd service to activate script
