SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
(cherry picked from meta-toradex-nxp commit
18a87021f079a84171885c6e816fb8800ce3b974 limited to
recipes-kernel/linux/linux-toradex-3.14.52/apalis-imx6/defconfig resp.
colibri-imx6/defconfig)
linux-toradex.inc's functionality is provided with linux-dtb.inc for current
device tree enabled kernels. So don't include both include files.
Prevents
ERROR: QA Issue: kernel-devicetree is listed in PACKAGES multiple times, this leads to packaging errors. [packages-list]
Resynchronize defconfig with the git tree version:
The audio Codec Machine driver was missing hence the sound card
got not detected by the SAI driver.
Synchronize defconfig with kernel git.
While we enable CONFIG_IIO_SYSFS_TRIGGER in kernel source defconfig
this is not enabled in defconfig being used in OpenEmbedded. This
results in sysfs triggers not being enabled by default in an image
build with OpenEmbedded. This is already observed with our last
release 2.6 Beta1 image.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
A new i.MX6/i.MX7 real-time 3.14.52 kernel recipe was added with a
modified PREEMPT_RT patch to accomodate the backports applied to
the Toradex kernel.
To select the kernel use a preferred provider variable in your
configuration files (e.g. local.conf):
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt"
Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com>
Use KERNEL_MODULE_AUTOLOAD to load USB gadget support. This is
required for libusbg (gadget-import) to work.
Update defconfigs and drop picking the defconfig from the kernel sources.
A new i.MX6 real-time kernel recipe was added with a modified
PREEMPT_RT patch to accomodate the backports applied to the
Toradex kernel.
Signed-off--by: Max Krummenacher <max.krummenacher@toradex.com>
This recipe provides a kernel for the Freescale i.MX 7 based module
Colibri iMX7.
- based on Freescale's BSP release imx_3.14.52_1.1.0_ga release
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Update to latest revision which contains a SPI bugfix and the latest
upstream stable release v4.1.15.
Also synchronize the VF defconfig.
Update to latest revision which fixes Colibri iMX6D not powerering off but
creating a stacktrace.
Update to latest revision.
While at it remove the module specific override of SRCREV and PR and set
the git branch with its own variable.
While at it use 4 spaces to indent code as customary in recipes.
We have this recipe in meta-fsl-arm-extra.
Convert it to a bbappend and only keep the changes to the bb files.
Enable RTL8192CU driver to support LM006 USB WiFi adapter.
Add LOCALVERSION and generate a scmversion file to annotate the
Kernel with the Toradex release and a git hash.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
Update defconfig and kernel version to latest version from git. This
also configures the USB Gadget ConfigFS as a module. Add the ConfigFS
module to the list of autoloaded modules.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
SCSI lock device disk support is required for USB mass storage to
work. Also enable asynchronous SCSI scanning by default.
Use a fixed revision of the MCC kernel module which makes sure it
builds with the corresponding Vybrid Linux kernel, which also uses
a fixed git hash.
