path: root/recipes-core
2018-11-09eglibc-linaro: update to 2.19 14.05Marcel Ziswiler
Update to later linaro eglibc 2.19 14.05 version as previous 14.04 is no longer available for download. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-03-10usb-rndis: fix various issues with dhcpd service for RNDISMax Krummenacher
- Make sure leases file is not persistent (in /var/run now) This allows to serve the same IP to the generated (and hence different IP addresses) - Start RNDIS service after the network.target - Tegra: Add extra service for udhcpd. When running dhcpd directly from udev, the daemon will be killed after a while
2015-03-05journald: remove journald.conf patchMax Krummenacher
meta-angstrom now overrides the effect of the patch and provides the journald.conffile in full. To override a setting either create the file with your settings in meta-toradex/recipes-core/systemd/systemd/journald.conf or edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
2014-12-18systemd-machine-id-commit: add standalone recipeMax Krummenacher
2014-11-13apalis/colibri_imx6: disable usb rndis systemd serviceMarcel Ziswiler
Disable USB RNDIS systemd service for now due to possible race upon first boot: [ OK ] Started Load/Configure the kernel driver providing the RNDIS gadget. => system hang
2014-11-13apalis/colibri_t30: fix resizefsMarcel Ziswiler
2014-10-30timestamp-service: remove in favor of meta-angstrom patchMax Krummenacher
2014-08-04usb-rndis: drop use of ifconfig in favor of ipMax Krummenacher
ifconfig does no longer understand 192.168.11.2/24 and its use is deprecated, so instead of changing to another way of stating the subnetmask use /sbin/ip.
2014-08-04usb-rndis: add config for g_ether.ko solutionMax Krummenacher
i.MX6 and Vybrid modules use the g_ether driver for RNDIS functionality. This commit uses a systemd service to load the kernel module, configures the new usb0 NIC and starts a dhcp server to serve an IP address to a USB host. The Tegras use the android gadget driver. The configuration remains unchanged.
2014-08-04timestamp-service: change to new timestamp formatMax Krummenacher
Patch pending in meta-angstrom
2014-08-04recipes-core/hdmi-hotplug/hdmi-hotplug.bbMax Krummenacher
2014-08-04util-linux: fstrim: remove now integrated backportMax Krummenacher
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-08-04Use generic bbappend filesMax Krummenacher
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it.
2014-04-01util-linux bbappend: update to match bb versionMax Krummenacher
2014-04-01resizefs.sh: add iMX6 specificsMax Krummenacher
2014-04-01journald patch: update to systemd 206Max Krummenacher
2014-04-01systemd bbappend: update to match bb versionMax Krummenacher
2014-04-01udev-extraconf: remove space from pathMax Krummenacher
If the path is appended by someone else, the space introduces an error
2014-04-01dropbear connman bbappend: update to match bb versionMax Krummenacher
2014-02-04util-linux: add fstrimMax Krummenacher
Add the fstrim utility to Colibri T30 image. The utility allows to send trim commands to the underlaying flash translation layer, which allows too free not used flash sectors and those improve wear- leveling
2013-10-21hdmi: add udev rule to start an X output on hotplugMax Krummenacher
2013-10-07resizefs.sh: start from current fs size, not from a constMax Krummenacher
2013-09-22dropbear: fix moved path to sftp serverMax Krummenacher
2013-09-22systemd: systemd bbappend update to version 199Max Krummenacher
2013-09-22systemd: adapt to new systemd handlingMax Krummenacher
with the move from meta-openembedded to oe-core some things have changed, e.g. the config files have to explicitly installed
2013-09-22systemd: follow update of recipe with bbappendMax Krummenacher
2013-06-26systemd: fix patch path so the default -p 1 appliesMax Krummenacher
2013-06-26fs-init: add recipe to extend rootfs partition on eMMCMax Krummenacher
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size. On first boot this filesystem is resized to fill its full partion. This slows down IO responsivness during the first 5 minutes.
2013-06-26udev: don't try to automount mmcblk0bootXMax Krummenacher
- these partitions are not meant to be mounted
2013-06-07systemd-journald: limit journal sizeMax Krummenacher
2012-12-17rndis: set a revision in recipe, limit leases to 1Max Krummenacher
2012-12-07usb-rndis: make sure the interface is up when a host connectsMax Krummenacher
2012-12-07dropbear: disable reverse DNS lookupsMax Krummenacher
2012-11-26usb-rndis:Max Krummenacher
- add recipe which configures RNDIS and dhcp on the new NIC requires kernel commit b7e977a36ee2b1ab1a55238761fe8d63df9bc638 see also http://permalink.gmane.org/gmane.linux.usb.general/56244
2012-08-24 ${BPN} errors to psplash-angstrom instead of psplash, fetch fails.Max Krummenacher
