Fix build failure because mqxboot_2.x is built instead of the
required mqxboot_1.x.
The mqxboot version changed from 1.0 to 1.0.1.
Choosing the preferred version with a wildcard prevents using
the not compatible 2.x version.
NOTE: preferred version 1.0 of mqxboot not available (for item mqxboot)
NOTE: versions of mqxboot available: 1.0.1 2.0.1
While at it set the prefered providers for mcc related recipes.
(ported from meta-fsl-arm-extra 6eefe6562d51525ff511adf81a84ad7af8a25814
and 0f4942175f8ae00741b2fee2ab82ceedb58f15c3)
The Toradex Colibri iMX7 computer module is based on i.MX 7.
The Colibri iMX7 is a member of the pincompatible Colibri family.
They feature on module RAM and NAND, Ethernet PHY, Resistive Touch
Controller and Audio Codec.
For additional specifications please visit:
https://www.toradex.com/computer-on-modules/colibri-arm-family/freescale-imx7
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Read machine configuration and remove Kernel image and device tree
from rootfs since we start using static UBI volumes.
Change DEFAULTTUNE in machine configurations to Thumb-2.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
Include the NVIDIA binaries as soon as X11 is in distribution
features. This allows to use the hardware accelerated X11 DDX
driver "tegra" even when OpenGL is not selected by the image.
Consolidate Tegra specific machine configuration in a common
tegra-base.inc file.
Since the boot loader requires a kernel-image in /boot, add the
kernel-image to MACHINE_ESSENTIAL_EXTRA_RDEPENDS. This allows to
boot images which do not select packagegroup-boot by default such
as the Poky reference distribution images.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
Use new library libusbg with its automatic gadget configuration
service. Also enable a console on USB gadget serial port (CDC ACM)
which is ttyGS0 on device side.
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
Update to a U-Boot and Kernel which can be used for Apalis iMX6
HW version V1.0 and V1.1.
Also deploy additional device tree for Apalis iMX6 V1.0 modules
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
Use latest U-Boot from git.
Migrate to using cbootimage and tegrarcm.
Use rebased U-Boot release 2014.10. The README has a new md5sum
and U-Boots new build system has default configurations ending
with defconfig too.
Due to U-Boot udpate we need to create one big UBI volume. Since
attaching the UBI volume is the expensive operation (compared to
mount the UBIFS inside that volume), it is relatively cheep to
load the kernel directly from the root filesystems /boot directory
instead of creating a own volume for the kernel. This also makes
it simpler to load a mainline kernel (along with the required dtb
file).
However, we loose the integrity check of the uImage. But since
there were no measures in place to handle a invalid image, we do
not loose functionality here. In case we need integrity check, we
should consider switching to the new FIT image format...
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
Angstrom default on armv7a would be thumb2, however there are some
recipes around with arm assembler which fails.
If the package manager finds a version newer than the prefered-version that one
gets installed. As we need a specific one for the tegras and for imx6 we
change the 'epoch' to something very high.
unify the features between machines
kernel26 is deprecated and unused
apm does not make sense on ARM
While at it remove some commented stuff
Be consistent with the other machine recipes
Help the autobuilder setup
This commit switches Colibri VF machine to use the 2014.04 git
branch. The change to latest U-Boot brings proper NAND hardware
ECC support, which is also enabled in latest Linux kernel.
Beside that, burnflash is updated to correctly work with the
new U-Boot version and the altered Config Block location.
File now provided by openembedded-core
This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419.
EGL, OpenGL ES1.1 and OpenGL ES2.0 provided in binary form.
virtual/bootloader is a commonly used target. This patch
adds it for meta-fsl-arm machines.
Other BSP layers have this provider and when using a mutli-machine
distro setup bitbake virtual/bootloader
builds a wrong u-boot for fsl machines
The patch was imported from the meta-arm-fsl git server
(https://github.com/Freescale/meta-fsl-arm/commit/93b3d7dd7cdbbc0a49394cc32d335fb85fd2da74)
and adapted to our machines.
remove the files copied from meta-fsl* for Colibri-VF V2.1
move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
The Colibri VFxx console gobbles most output and sometimes
provokes a kernel oops during boot, if a valid /dev/null
is already part of the rootfs before mounting devtmpfs.
The dynamically populated dev with devtmpfs / udev is enough.
