The resize command confuses Eclipse's launcher.
On a ssh console resize isn't needed anyway so only start it if
the console device starts with /dev/tty to work around the issue.
Double clicking launches a video always in fullscreen mode, i.e. the parameters
for size and offset of video output are not used.
Fix parmeter escaping for new versions of shell or gst-launch.
- use % in bbappend
- tegra: build with icu, so qtwebkit can be built
- tegra: build with gstreamer 0.10
- remove workaround for gcc 4.8
Include the NVIDIA binaries as soon as X11 is in distribution
features. This allows to use the hardware accelerated X11 DDX
driver "tegra" even when OpenGL is not selected by the image.
Consolidate Tegra specific machine configuration in a common
tegra-base.inc file.
Since the boot loader requires a kernel-image in /boot, add the
kernel-image to MACHINE_ESSENTIAL_EXTRA_RDEPENDS. This allows to
boot images which do not select packagegroup-boot by default such
as the Poky reference distribution images.
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
Remove udev-extra-rules since the main functionality, automatic
mounting using udev/mount.sh, does not work anymore. Systemd
starts the udev daemon using mount namespaces, which leads to
mounts not being visible outside of the udev processes scope.
Hence the file system get mounted, but other then the udev process
nobody can actually use them.
To make mounting using udev/mount.sh work again, one needs to
remove the MountFlags option in the systemd-udevd.service file
(/lib/systemd/system/systemd-udevd.service).
Another possible solution which might fit the needs of automouting
is to use a systemd mount unit.
Currently udisks and udev-extra-rules (which provides a udev based
automount approach) are installed. Since the UI is prefering the
D-Bus based udisks approach, remove udev-extra-rules in favor of
udisks.
SCSI lock device disk support is required for USB mass storage to
work. Also enable asynchronous SCSI scanning by default.
Use a fixed revision of the MCC kernel module which makes sure it
builds with the corresponding Vybrid Linux kernel, which also uses
a fixed git hash.
for V2.3 stable image.
We now use mkimage during do_imagedeploy to build the u-boot scripts.
For machines which build a zImage this tool has not yet been built and
we get an error because the tool is missing.
And use 2015.04-toradex branch
OpenMAX-IL implementation library aka libgstomx, evaluation version
with fix to validate input frame rate.
GPIOConfig CPU detection was broken on Colibri VF50. Update to latest
revision 674 which fixes CPU detection on newer kernel for Colibri
VF50 too.
Our kernel defconfigs build a number of drivers as modules.
Deploy all of these into the final image instead of only deploying
a number of explicitely named module packages.
Angstom Dizzy now uses systemd V218 so there is no need to build
a component seperately anymore.
This reverts commit 16b8b392ad048566729f30d7c3887d1bfdf21bd4.
Angstom Dizzy now uses systemd V218 so there is no need to deploy
If one has to run systemd-machine-id-commit on first boot one has
to add an additional recipe or bbappend to to systemd_%.bb
This reverts commit 908149098ed9d31d817c438e505ecdbf15f9f3db.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
This changes the minimum required Linux version from 3.7 back to 3.0.
[YOCTO #7409]
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
backported from openembedded-core,
commit 31163abc7bedd477c1aad10e6d1f47dbee194513
This reverts commit 3cf2edb10f5e8ac60db7ca2e71d1e754a177d08c.
recipes-core/systemd/systemd_%.bbappend
Fix and enhance messages durring Colibri VF50/VF61 upgrade.
Fix missing run command
Was Boot and arm
We need libcryptopp only for a 32bit x86 target for tegrarcm.
However linking libcryptopp dynamically and using the distro supplied 32bit
compatibility libcryptopp raises an assertion:
tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed.
Building only a static library with OE, (if native build forcing 32bit)
fixes the issue.
Create the U-Boot scipts at image buildtime and remove the binary
script representation from version control.
This fixes:
WARNING: QA Issue: tegrastats-gtk requires libpangocairo-1.0.so.0, libpango-1.0.so.0,
libcairo.so.2, libpangoft2-1.0.so.0, libgtk-x11-2.0.so.0, libgdk-x11-2.0.so.0,
but no providers in its RDEPENDS [file-rdeps]
iMX6: Always do use a secondary argument for the 'mmc dev' command.
T30: Do rootfs update of eMMC in chunks as well. Requires pre-splitting
file in Ethernet case. As an advantage allows flashing rootfs bigger
than RAM plus avoids timeouts during flashing. Added wrapper flash_mmc
script as well for backwards compatibility reason.
While at it cleanup various whitespaces throughout the update scripts.
