SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
(cherry picked from meta-toradex-nxp commit
18a87021f079a84171885c6e816fb8800ce3b974 limited to
recipes-kernel/linux/linux-toradex-3.14.52/apalis-imx6/defconfig resp.
colibri-imx6/defconfig)
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
While we use only one erase block for the U-Boot environment, we
reserve four in case there are bad blocks in the environment area.
Specify the number of blocks so that the Linux utilities are able
to read/write the environment even if the first block of the
environment is bad.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
Deploy GPIOConfig V1.4.
Apalis iMX6: corrects the iomux offset of PAD_SD4_DATA6.
Colibri iMX6: corrects 'SODIMM Pin'/'EvalLoc' columns for pads:
DI0_PIN15
NANDF_D4
NANDF_D6
SD1_CLK
The script fails when -m is given but rootfs/etc/issue fails to provide
the version info.
While at it correct wrong text output on i.MX 6 based modules.
Using libimxvpuapi causes asserts when using certain pipelines,
e.g. with gst-play-1.0.
Don't build the plugins which base on libimxvpuapi for now.
Disable LVDS output in favour of primary HDMI one on Apalis TK1.
Fix pkg_postrm by renaming from previous erroneous pkg_postremove and
remove /${bindir}/ which would need escaping.
And while at it replace Apalis-T30 in summary with Apalis T30 and get
rid of PR and empty do_compile.
The Vivante X driver does not support the X video extension.
Remove the locally backported 6.8 version since bitbake anyway
use the newer 7.1 version from OpenEmbedded core.
This reverts commit 8d0349a08564a8044bad7f0f3ff0982e6d5a6aa2.
while at it move both to machine arch to reduce rebuilds.
Pass $libdir to 'waf configure' to prevent using the build hosts libdir.
Fixes:
WARNING: libimxvpuapi-0.10.2-r0 do_package: QA Issue: libimxvpuapi: Files/directories were installed but not shipped in any package:
/usr/lib64/libimxvpuapi.so
/usr/lib64/libimxvpuapi.so.0
/usr/lib64/libimxvpuapi.so.0.10.2
/usr/lib64/pkgconfig
/usr/lib64/pkgconfig/libimxvpuapi.pc
Signed-off-by: Max Krummenacher <max.krummenacher at toradex.com>
add configure options to build without sound. This removes the runtime
dependency on gstreamer 0.10.
The plain framebuffer X11 driver does not support xv so the
plugin does not work.
linux-toradex.inc's functionality is provided with linux-dtb.inc for current
device tree enabled kernels. So don't include both include files.
Prevents
ERROR: QA Issue: kernel-devicetree is listed in PACKAGES multiple times, this leads to packaging errors. [packages-list]
This is only used for choosing a custom logo size. Not needed in our
use case.
meta-openembedded/meta-oe/recipes-kernel/linux/linux.inc
Resynchronize defconfig with the git tree version:
The audio Codec Machine driver was missing hence the sound card
got not detected by the SAI driver.
Note: Currently only compiles -native but fails compiling for target!
This reverts commit 04324a6e680902d4c1aabeff7187975a6cbf09b0.
The patch is now part of meta-openembedded jethro branch.
