This is basically a back port of the following commits from the
openembedded-core master branch:
openssh: upgrade to 7.4p1
openssh: fix CVE-2016-8858
openssh: fix potential signed overflow to enable compilation with -ftrapv
openssh: Upgrade 7.2p2 -> 7.3p1
openssh: add ed25519 host key location to read-only sshd config
openssh: conditional compile DES code.
openssh: fix init script restart with read-only-rootfs
openssh: update homepage and summary
openssh: Backport fix for CVE-2015-8325
openssh: Upgrade 7.1p2 -> 7.2p2
openssh: change URI to http:
openssh: Security Fix CVE-2016-3115
openssh: Properly skip ptrace test if tools are missing
openssh: Fix regex that sets sftp-server path for tests
openssh: CVE-2016-1907
openssh: update to 7.1p2
openssh: redesign ssh-agent.sh regression test case
openssh: enable X11Forwarding if distro feature x11 is set
openssh: fix file permission for /etc/pam.d/sshd
openssh: fix sshd key generation when systemd is in use and rootfs is readonly
openssh: Upgrade 7.0p1 -> 7.1p1
openssh: build regression test binaries
openssh: Upgrade 6.9p1 -> 7.0p1
openssh: Upgrade 6.8p1 -> 6.9p1
openssh: fix login fails for ssh -o Batchmode=yes with empty passwords
openssh: Upgrade 6.7 - > 6.8
Revert "openssh: CVE-2015-6563 CVE-2015-6564 CVE-2015-6565"
openssl: actually apply Use-SHA256-not-MD5-as-default-digest.patch
openssl: Fix symlink creation
openssl: Updgrade 1.0.2j -> 1.0.2k
openssl: Use linux-aarch64 target for aarch64
openssl-native: Compile with -fPIC
openssl: Security fix CVE-2016-7055
OpenSSL: CVE-2004-2761 replace MD5 hash algorithm
openssl: fix bashism in c_rehash shell script
openssl: rehash actual mozilla certificates inside rootfs
openssl: Upgrade 1.0.2i -> 1.0.2j
openssl.inc: avoid random ptest failures
openssl: update to 1.0.2i (CVE-2016-6304 and more)
openssl: fix do_configure error when cwd is not in @INC
openssl: fix add missing dependencies building for test directory
openssl: Security fix CVE-2016-2178
openssl: Security fix CVE-2016-2177
openssl: prevent warnings from openssl-c_rehash.sh
openssl: fix the dangling libcrypto.a symlink
openssl: Ensure SSL certificates are stored on sysconfdir
openssl: Add Shell-Script based c_rehash utility
openssl: Security fix via update to 1.0.2h
openssl.inc: minor packaging cleanup
openssl: don't move libcrypto to base_libdir
openssl: add a patch to fix parallel builds
openssl: Security fix Drown via 1.0.2g update
openssl.inc: drop obsolete mtx-1 and mtx-2 over-rides
openssl: Explicitly set EXTRA_OEMAKE as required
openssl: update 1.0.2e -> 1.0.2f ( CVE-2016-0701 CVE-2015-3197 )
openssl: Add musl configuration support
openssl: update to 1.0.2e
openssl: enable parallel make
openssl: fix ptest issues
openssl: use subdir= instead of moving files in do_configure_prepend()
openssl: sanity check that the bignum module is present
openssl: fix ptest failures
Note that this requires a complete image rebuild due to ABI breakage. If
that is not desired something along those lines would need to be
integrated as well:
http://cgit.openembedded.org/openembedded-core/commit?id=480db6be99f9a53d8657b31b846f0079ee1a124f
Some packages are only built in plain ARM architecture (non-Thumb).
Those packages are currently not in the feeds, which leads at non
resolveable dependencies (e.g. for gst-plugins-base-meta).
New real-time iMX6 machine configurations were added along with a
real-time kernel recipe with a modified PREEMPT_RT patch to
accomodate the backports applied to our kernel.
To select the kernel use a preferred provider variable in your
configuration files (e.g. local.conf):
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt"
Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com>
[removed -rt machines]
Currently _tkinter is only built when tcl/tk is available before the
python do_configure task is built.
Make this deterministic by providing a PACKAGECONFIG for it.
If tkinter is in PACKAGECONFIG add the needed dependencies,
if not force that tkinter is not built.
Enable USB suspend resume fix for Vybrid.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Add systemd service which utilises systemd's suspend resume hooks
to excute scripts which take care of unbinding and binding the
necessary configurations and usb driver during suspend and resume
respectively.
When using TFTP update, the rootfs must be in decimal numbered chunks on the
tftp server. U-Boot reads the chunks, but does count hexadecimal thus
limiting the number of chunks to 10.
The U-Boot binary for the IT temperature range changed names from
u-boot-it.imx to u-boot.imx-it.
The flash_*.scr scripts did still use the old name resulting in the U-Boot
not being found on the SD card or TFTP server.
Avoids
WARNING: Unable to get checksum for gpioconfig SRC_URI entry GPIOConfig: file could not be found
during recipe parse by providing a dummy GPIOConfig.
The dummy displays a popup with a button that says that the program is not
available on this machine.
(cherry picked from commit e6959294ac99c87c7aabe2334d6582618ea3a825)
This has been missing since our move to boot from the eMMC boot partition.
While at it clarify update.sh help. _it applies only to
Apalis iMX6 IT modules.
Update to latest revision which contains a SPI bugfix and the latest
upstream stable release v4.1.15.
Also synchronize the VF defconfig.
Update to latest revision which fixes Colibri iMX6D not powerering off but
creating a stacktrace.
Update to latest revision.
While at it remove the module specific override of SRCREV and PR and set
the git branch with its own variable.
While at it use 4 spaces to indent code as customary in recipes.
We have this recipe in meta-fsl-arm-extra.
Convert it to a bbappend and only keep the changes to the bb files.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
to meta-fsl-arm-extra.
The command 'mmc partconf 0 1 1 0' seems to have no effect when it is in the
middle of our migration cmdline resulting in U-Boot still being loaded from
the user partition.
Putting it as the last command seems to solve the issue.
http://developer.toradex.com/software-resources/arm-family/linux/linux/release-details?view=all&issue=14774
Enable RTL8192CU driver to support LM006 USB WiFi adapter.
The LM006 USB WiFi adapter uses a Realtek RTL8188CUS chipset,
which requires the compatible firmware RTL8192CU.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Despite the reordering of when to load the USB Gadget configuration
with commit fadb16f153aa ("libusbg: enable USB Gadgets after Connman
to avoid interference") the network device ended up to be down after
startup. It seems that there is a race condition in systemd-networkd
which triggers especially in combination with USB Gadget, a issue on
the systemd issue tracker has been created:
https://github.com/systemd/systemd/issues/1784
There have been various changes related to link handling between
systemd 219 and the latest version 227. It is possible that the issue
is already solved.
Until this has been resolved, explicitly load the USB Gadget before
starting systemd-networkd seems to get around the issue.
With the cfgblock command in U-Boot we now have a better solution.
A meta-toolchain build or a build which does not use the angstrom distro
builds glibc_2.21 rather than glibc_linaro-2.20.
The patch to not use the slower memcpy implemented for NEON does not apply
cleanly for both versions of glibc.
This adds a bbappend for glibc_2.21 forcing memcpy_arm.
0001-memcpy-don-t-use-optimized-for-VFP-NEON-versions.patch applies
not to oe glibc_2.21
Don't write the eMMC twice on Apalis in the not migrate case.
Add LOCALVERSION and generate a scmversion file to annotate the
Kernel with the Toradex release and a git hash.
It seems that Connman disables ALL interfaces on startup, even if
they are listed in NetworkInterfaceBlacklist. This leads to the
following situation:
networkd starts...
usb0 gets created...
networkd sets the device up (event triggered)
connman starts... and sets the device down!
networkd does not restart the device in this situation. To avoid
the situation, create the USB Gadget functions after connman. It
seems that if connman is up and running, it does not touch the
device anymore.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
The Vybrid devices use a composite gadget device by default which
offers a serial connection over USB on the USB peripheral port.
This enables a serial console on that tty.
Change DEFAULTTUNE in machine configurations to Thumb-2.
To download the sources mirrored on sources.toradex.com add
the Toradex mirror as pre-mirror.
Up until now, U-Boot for Colibri VF50/VF61 did not had an
environment variable board_name. Use the soc environment
variable to set the board_name.
To avoid code duplication call fwd_blk from fwd_mmc. This adds
one more indirection, but since flash_mmc.img is a compatibility
script anyway it is not the common case...
Source the update script only if loading succeeded. This avoids
loops if board_name is not set. Also add a test if board_name is
really set since this variable is/was not available in older
U-Boots.
