path: root/recipes-bsp
2018-06-18tdx-k20-fw: update to v1.1Dominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 64667adc9d1367c7554306bb89189461a90f9203)
2018-06-18apalis-t30: mainline kernel machineMarcel Ziswiler
This patch adds mainline linux based Apalis T30 machine. Just the bare minimum to run the Toradex Easy Installer. It does not yet include any compatible recipes for graphics. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-11-30tdx-k20-fw: update to v0.11Apalis-TK1_LXDE-Image_2.7b5-20171201Dominik Sliwa
2017-11-29u-boot recipes: update to latestMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29u-boot-toradex: move binary, image and symlink to machine configurationMarcel Ziswiler
Move UBOOT_BINARY, UBOOT_IMAGE and UBOOT_SYMLINK definitions to machine configuration re-used by the Toradex Easy Installer U-Boot recipe. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29u-boot recipes: automatically update to latest -next through overrideMax Krummenacher
This can be used e.g. for a CI setup to do nightly builds of latest and greatest. To use HEAD of xxx-next instead of the pinned version one would add in local.conf: MACHINEOVERRIDES =. "use-head-next:" Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-11-29tdx-nv-binaries: glesv2.pc: fix pathMax Krummenacher
Fix the include path. Reported-by: Andreas Holzammer, kdab.com Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-06tdx-k20-fw: update to v0.10Dominik Sliwa
2017-10-05u-boot-toradex: apalis-tk1/apalis-tk1-mainline: generate cbootimageMarcel Ziswiler
Generate cbootimage already during build as required for Toradex Easy Installer BSP package. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-10-05tdx-nv-binaries: add needed dependsMax Krummenacher
The binary drivers in tdx-nv-binaries have dependencies on gstreamer et. al. Add them to DEPENDS, so that they are available during do_rootfs. Addresses: | Collected errors: | * calculate_dependencies_for: Cannot satisfy the following dependencies for packagegroup-basic: | * gstreamer (>= 0.10.36) * libgstaudio-0.10-0 (>= 0.10.36) * libgstinterfaces-0.10-0 (>= 0.10.36) * libgstvideo-0.10-0 (>= 0.10.36) * libxv1 (>= 1.0.10) * | * opkg_solver_install: Cannot install package packagegroup-basic. | * calculate_dependencies_for: Cannot satisfy the following dependencies for tdx-nv-binaries-nv-gstapps: | * gstreamer (>= 0.10.36) * libgstinterfaces-0.10-0 (>= 0.10.36) * | * opkg_solver_install: Cannot install package tdx-nv-binaries-nv-gstapps. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-10-05u-boot recipes: update to latestMarcel Ziswiler
2017-06-30u-boot: update to latestMarcel Ziswiler
2017-06-30tegrarcm: allow target and native build, work with rssMax Krummenacher
- adapt to the changes introduced with recipe specific sysroots - tegrarcm can now also be built for a target - tegrarcm can now also be built for nativesdk Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-10tdx-nv-binaries: renamed from trdx-nv-binariesColibri-T30_LXDE-Image_2.7b2-20170410Colibri-T20_LXDE-Image_2.7b2-20170410Apalis-TK1_LXDE-Image_2.7b2-20170410Apalis-T30_LXDE-Image_2.7b2-20170410Marcel Ziswiler
While at it also update the comment in recipes-graphics/mesa/mesa_%.bbappend. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-04-10tdx-k20-fw: include licence fileDominik Sliwa
While at it also rename it from trdx-k20-fw to tdx-k20-fw. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-10tegrastats: rework inhibit warningsMax Krummenacher
Use INSANE_SKIP_<package> in place of the unusual WARN_QA_remove. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-10apalis/colibri-t20/t30/tk1: u-boot: new version plus git hashMarcel Ziswiler
Use the new version variables plus the git hash. Inspired by meta-freescale/classes/fsl-u-boot-localversion.bbclass. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-04-10u-boot: update to latestMax Krummenacher
2017-04-07u-boot: use the new version variablesMax Krummenacher
2017-04-07meta-toradex-tegra: cleanup whitespace useMax Krummenacher
2017-04-07u-boot-toradex-fsl-fw-utils: inherit pkgconfigMax Krummenacher
2017-04-07u-boot: update to latest -nextMax Krummenacher
2017-04-07recipes: remove unneeded RDEPENDSMax Krummenacher
The 'rdepending' packages are picked up automatically by the buildsystem. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07Revert "opencv4tegra: update to 2.4.12.3"Max Krummenacher
This reverts commit 5b5356a28d06ccb8806310b4133b345fae178aba. The commit duplicated the bbappend which now lives in jetson-tk1/recipes-bsp/binary-drivers. Thus remove the duplicated file. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-13trdx-k20-fw: fix unconnected touchscreen issueDominik Sliwa
When no resistive touch panel is connected spurious events were generated. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11u-boot: update to latestColibri_T30_LinuxImageV2.7Beta1_20170112Colibri_T20_LinuxImageV2.7Beta1_20170112Apalis_TK1_LinuxImageV2.7Beta1_20170112Apalis_T30_LinuxImageV2.7Beta1_20170112Max Krummenacher
2017-01-11trdx-k20-fw: Apalis TK1 K20 MCU firmwareDominik Sliwa
2017-01-11tegrastats, nvsamples: fix rdependsMarcel Ziswiler
2017-01-11tegrarcm-native: fix compilation not using host headers/librariesMarcel Ziswiler
Turns out our build was using the library from the build machine which at least on Fedora 23 seems broken. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11tegrarcm: update to latest from gitMarcel Ziswiler
Update to latest from git in order to have support for --usb-timeout= parameter. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11trdx-nv-binaries: openmax updated checksumMax Krummenacher
The OpenMAX_IL headers archive has been updated resulting in a changed checksum. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11u-boot/kernel: update version string to 2.7Max Krummenacher
While at it consistently use a lower case 'v' as with U-Boot and kernel in meta-toradex-nxp. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11apalis-tk1: Mainline kernel machineDominik Sliwa
This patch adds mainline linux based Apalis TK1 machine. It includes compatible recipes for libdrm, mesa, Xorg, and weston. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11tegrastats: address bitbake warningsMax Krummenacher
TK1 silence warning for hash-style not gnu Allow debug package, as for TK1 we have an unstripped binary Add to RDEPENDS for tegrastats-gtk WARNING: tegrastats-1.0-r3 ...tegrastats-gtk contained in package tegrastats-gtk requires libatk-1.0.so.0... [file-rdeps] WARNING: tegrastats-1.0-r3 ...tegrastats: Files/directories were installed but not shipped in any package: WARNING: tegrastats-1.0-r3 ...No GNU_HASH in the elf binary: '...packages-split/tegrastats/usr/bin/tegrastats' [ldflags] WARNING: tegrastats-1.0-r3 ...tegrastats-gtk contained in package tegrastats-gtk requires libpangocairo-1.0.so.0... [file-rdeps] Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11u-boot: upgrade to 2016.11 based versionMax Krummenacher
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11u-boot: fix compileMax Krummenacher
fix errors due to missing uint* types. Move to u-boot git. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11opencv4tegra: update to 2.4.12.3Max Krummenacher
2016-11-22u-boot: tk1: update to include changes for v1.1 modulesMax Krummenacher
2016-11-22alsa: apalis-tk1: add initial asound.stateMarcel Ziswiler
2016-09-29linux-driver-package: deploy additional gst componentsMax Krummenacher
While at it move the bbappend and xorg.conf under jetson-tk1 so that one only needs meta-jetson-tk1 when one builds for tk1. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29apalis-tk1: disable nvidia logo shown exlusively on lvdsMarcel Ziswiler
2016-09-29apalis-tk1: lvds-tegra124: configure lvds in extended mode by defaultBhuvanchandra DV
Disabling LVDS output by default has issue with pcmanfm consuming 100% CPU if HDMI is inactive. So to make sure HDMI is set as primiary display and to address the issue with pcmanfm, configure LVDS in extended mode by default so that if HDMI is not active LVDS will be on atleast. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29u-boot: update to latestMax Krummenacher
2016-09-29jetson-tk1 layer bbappendsMax Krummenacher
Move the appends on recipe's which are not in an essential required layer into a target layer specific directory and add them only if said layer is active in build/conf/bblayers.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29trdx-nv-binaries: download binary blobsMax Krummenacher
With the split of meta-toradex we removed the binary blobs of the Tegra driver- and codec packages. This changes the recipe to download the files. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29trdx-nv-binaries: mv all files into recipes-bsp/trdx-nv-binariesMax Krummenacher
2016-09-29tegrastats: mv all files into recipes-bsp/tegrastatsMax Krummenacher
2016-08-17u-boot-toradex-fw-utils: fix bashismmeta-toradex_splitStefan Agner
Do not use the function keyword, then the script works fine with with Busybox' shell implementation. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17u-boot-fw-utils: use negative offset for environmentStefan Agner
Rely on newly implemented configuration functionality to locate the environment at the end of the boot partition. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30tegrarcm: build with static libstdc++Marcel Ziswiler
