path: root/recipes-bsp/tegrarcm/tegrarcm
2017-06-30tegrarcm: allow target and native build, work with rssMax Krummenacher
- adapt to the changes introduced with recipe specific sysroots - tegrarcm can now also be built for a target - tegrarcm can now also be built for nativesdk Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-05-12tegrarcm/cryptopp: build and use as a static libraryMax Krummenacher
We need libcryptopp only for a 32bit x86 target for tegrarcm. However linking libcryptopp dynamically and using the distro supplied 32bit compatibility libcryptopp raises an assertion: tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed. Building only a static library with OE, (if native build forcing 32bit) fixes the issue.
