path: root/recipes-bsp/lvds-ctrl
2017-04-07meta-toradex-tegra: cleanup whitespace useMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29apalis-tk1: lvds-tegra124: configure lvds in extended mode by defaultBhuvanchandra DV
Disabling LVDS output by default has issue with pcmanfm consuming 100% CPU if HDMI is inactive. So to make sure HDMI is set as primiary display and to address the issue with pcmanfm, configure LVDS in extended mode by default so that if HDMI is not active LVDS will be on atleast. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30apalis-tk1: lvds-tegra124: disable lvds by defaultMarcel Ziswiler
Disable LVDS output in favour of primary HDMI one on Apalis TK1. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30lvds-ctrl: fix pkg_postrmMarcel Ziswiler
Fix pkg_postrm by renaming from previous erroneous pkg_postremove and remove /${bindir}/ which would need escaping. And while at it replace Apalis-T30 in summary with Apalis T30 and get rid of PR and empty do_compile. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2015-05-12licenses: fix license string to known values or formatMax Krummenacher
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2013-07-02lvds-ctrl: replace hi with the correct high in the scriptsMax Krummenacher
2013-04-15Apalis: make the lvds configuration glitch freeMax Krummenacher
2013-03-20lvds: autostart the dual lane scriptMax Krummenacher
2013-02-06Apalis-T30: add lvds setup scriptsMax Krummenacher
