Change the compression method for the rootfs from bz2 to xz.
This unifies the Toradex bsp with the same change done to NXP
based machines when we added the Toradex Easy Installer.
In our images this has been done during do_rootfs and friends,
do it the oe-core way.
Unsetting KEEPUIMAGE requests that vmlinux is built and later manually
packed into a uImage.
The resulting uImage in morty now packeges a gz compressed kernel in favour of
the uImage compression. Our U-Boot is not configured to boot such a uImage.
So keep the default setting for KEEPUIMAGE.
This is only used for choosing a custom logo size. Not needed in our
use case.
meta-openembedded/meta-oe/recipes-kernel/linux/linux.inc
Change DEFAULTTUNE in machine configurations to Thumb-2.
Consolidate Tegra specific machine configuration in a common
tegra-base.inc file.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
Use latest U-Boot from git.
Migrate to using cbootimage and tegrarcm.
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
Angstrom default on armv7a would be thumb2, however there are some
recipes around with arm assembler which fails.
If the package manager finds a version newer than the prefered-version that one
gets installed. As we need a specific one for the tegras and for imx6 we
change the 'epoch' to something very high.
unify the features between machines
kernel26 is deprecated and unused
apm does not make sense on ARM
While at it remove some commented stuff
EGL, OpenGL ES1.1 and OpenGL ES2.0 provided in binary form.
virtual/bootloader is a commonly used target. This patch
adds it for meta-fsl-arm machines.
Other BSP layers have this provider and when using a mutli-machine
distro setup bitbake virtual/bootloader
builds a wrong u-boot for fsl machines
The patch was imported from the meta-arm-fsl git server
(https://github.com/Freescale/meta-fsl-arm/commit/93b3d7dd7cdbbc0a49394cc32d335fb85fd2da74)
and adapted to our machines.
- Colibri T30 and Apalis T30 changed to NEON
- Colibri VF50 changed to hard float
This makes packages built for T30 incompatible with Colibri T20
(but Colibri T20 packages can still be used on T30)
- the binary only x-server driver only supports
API for 1.13 at the moment
- remove a backup file
