2016-11-22linux: tk1: update to include changes for v1.1 modulesApalis_TK1_LinuxImageV2.6.1Beta2_20161122jethroMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-11-22u-boot: tk1: update to include changes for v1.1 modulesMax Krummenacher
2016-11-22alsa: apalis-tk1: add initial asound.stateMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-11-22linux-driver-package: fix buildtime warningsMax Krummenacher
The gstreamer based package rdepend on gstreamer components so add the relevant RDEPEND for these packages. Silence warnings which can not be avoided with the binary distibuted files. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29xorg-server: remove Vybrid xorg.confColibri_T30_LinuxImageV2.6.1Beta1_20160929Colibri_T20_LinuxImageV2.6.1Beta1_20160929Apalis_TK1_LinuxImageV2.6.1Beta1_20160929Apalis_T30_LinuxImageV2.6.1Beta1_20160929Stefan Agner
The Vybrid xorg.conf should not be part of the Tegra BSP. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29opencv4tegra: update to 2.4.12.3Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29linux-driver-package: deploy additional gst componentsMax Krummenacher
While at it move the bbappend and xorg.conf under jetson-tk1 so that one only needs meta-jetson-tk1 when one builds for tk1. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29apalis-tk1: disable nvidia logo shown exlusively on lvdsMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29apalis-tk1: hdmi: add udev rule to start an X output on hotplugMarcel Ziswiler
2016-09-29apalis-tk1: lvds-tegra124: configure lvds in extended mode by defaultBhuvanchandra DV
Disabling LVDS output by default has issue with pcmanfm consuming 100% CPU if HDMI is inactive. So to make sure HDMI is set as primiary display and to address the issue with pcmanfm, configure LVDS in extended mode by default so that if HDMI is not active LVDS will be on atleast. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29linux t20/t30: update to latestMax Krummenacher
2016-09-29linux tk1: update to latestMax Krummenacher
2016-09-29u-boot: update to latestMax Krummenacher
2016-09-29recipes: stop using base_containsMax Krummenacher
The base_contains function is deprecated and we ought to use bb.utils.contains instead. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29meta-openembedded layer bbappendsMax Krummenacher
Move the appends on recipe's which are not in an essential required layer into a target layer specific directory and add them only if said layer is active in build/conf/bblayers.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29lxde layer bbappendsMax Krummenacher
2016-09-29jetson-tk1 layer bbappendsMax Krummenacher
2016-09-29trdx-nv-binaries: download binary blobsMax Krummenacher
With the split of meta-toradex we removed the binary blobs of the Tegra driver- and codec packages. This changes the recipe to download the files. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29trdx-nv-binaries: mv all files into recipes-bsp/trdx-nv-binariesMax Krummenacher
2016-09-29tegrastats: mv all files into recipes-bsp/tegrastatsMax Krummenacher
2016-09-29xorg-xserver: mv all files into recipes-graphics/xorg-xserver/Max Krummenacher
2016-09-29update readme and copying.mitMax Krummenacher
2016-09-29layer.conf: add initialMax Krummenacher
2016-08-17u-boot-toradex-fw-utils: fix bashismmeta-toradex_splitStefan Agner
Do not use the function keyword, then the script works fine with with Busybox' shell implementation. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17u-boot-fw-utils: use negative offset for environmentStefan Agner
Rely on newly implemented configuration functionality to locate the environment at the end of the boot partition. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30tegrarcm: build with static libstdc++Marcel Ziswiler
2016-06-30apalis-tk1: lvds-tegra124: disable lvds by defaultMarcel Ziswiler
Disable LVDS output in favour of primary HDMI one on Apalis TK1. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30lvds-ctrl: fix pkg_postrmMarcel Ziswiler
Fix pkg_postrm by renaming from previous erroneous pkg_postremove and remove /${bindir}/ which would need escaping. And while at it replace Apalis-T30 in summary with Apalis T30 and get rid of PR and empty do_compile. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30glmark2: tk1: build gles2 and gl for x11Max Krummenacher
while at it move both to machine arch to reduce rebuilds. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30linux-toradex: update to latestMax Krummenacher
2016-06-30apalis-tk1: add machine configurationMarcel Ziswiler
2016-06-30recipes/xorg-xserver/xserver-xf86-config: integrate apalis-tk1Marcel Ziswiler
2016-06-30linux: integrate apalis-tk1 and clean-up obsolete device treesMarcel Ziswiler
linux-toradex.inc's functionality is provided with linux-dtb.inc for current device tree enabled kernels. So don't include both include files. Prevents ERROR: QA Issue: kernel-devicetree is listed in PACKAGES multiple times, this leads to packaging errors. [packages-list] Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30u-boot: integrate apalis-tk1Marcel Ziswiler
2016-06-30mesa: integrate apalis-tk1, work around watatuki's meta-jetson-tk1 flawMarcel Ziswiler
2016-06-30recipes-bsp/binary-drivers: fix building cudatoolkit6.5 & opencv4tegraMarcel Ziswiler
2016-06-30tegrastats: integrate tk1 binary from l4t r21.4Marcel Ziswiler
2016-06-30mesa-glut: fix building on armMarcel Ziswiler
2016-06-30machine conf: remove setting of MACHINE_GUI_CLASSMax Krummenacher
This is only used for choosing a custom logo size. Not needed in our use case. meta-openembedded/meta-oe/recipes-kernel/linux/linux.inc Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30tegrarcm: update to latest 1.7Marcel Ziswiler
Note: Currently only compiles -native but fails compiling for target! Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30cbootimage: update to latest 1.7Marcel Ziswiler
2016-06-30libcryptopp: update to latest 5.6.3Marcel Ziswiler
2016-06-30linux-toradex: update to latest -nextMax Krummenacher
2016-06-30u-boot: get rid of obsolete patchesMarcel Ziswiler
2016-06-30u-boot, u-boot-fw-utils: update to latestStefan Agner
The upgrade is required to match to the latest update scripts which deploy the kernel and device tree into static UBI volumes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-31u-boot: update to latest from 2015.04-toradex-nextMarcel Ziswiler
2016-03-30psplash-angstrom_git.bbappend: removed, *.bb no longer existsMax Krummenacher
2016-03-30nvsamples: fix build QA warningMax Krummenacher
Address the following warnings: WARNING: QA Issue: nvsamples rdepends on libice, but it isn't a build dependency? [build-deps] WARNING: QA Issue: nvsamples rdepends on libsm, but it isn't a build dependency? [build-deps] Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30overrides: use append instead of +=Max Krummenacher
We want to append to the generic VAR when we build for a tegra machine. Using VAR_tegra += "" creates a machine specific VAR. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30u-boot tegra: update to latest -nextMax Krummenacher
