The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
SCSI lock device disk support is required for USB mass storage to
work. Also enable asynchronous SCSI scanning by default.
Use a fixed revision of the MCC kernel module which makes sure it
builds with the corresponding Vybrid Linux kernel, which also uses
a fixed git hash.
And use 2015.04-toradex branch
OpenMAX-IL implementation library aka libgstomx, evaluation version
with fix to validate input frame rate.
Angstom Dizzy now uses systemd V218 so there is no need to build
a component seperately anymore.
This reverts commit 16b8b392ad048566729f30d7c3887d1bfdf21bd4.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
This changes the minimum required Linux version from 3.7 back to 3.0.
[YOCTO #7409]
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
backported from openembedded-core,
commit 31163abc7bedd477c1aad10e6d1f47dbee194513
This reverts commit 3cf2edb10f5e8ac60db7ca2e71d1e754a177d08c.
recipes-core/systemd/systemd_%.bbappend
We need libcryptopp only for a 32bit x86 target for tegrarcm.
However linking libcryptopp dynamically and using the distro supplied 32bit
compatibility libcryptopp raises an assertion:
tegrarcm: secblock.h:145: CryptoPP::NullAllocator<T>::pointer CryptoPP::NullAllocator<T>::allocate(CryptoPP::NullAllocator<T>::size_type, const void*) [with T = unsigned int; CryptoPP::NullAllocator<T>::pointer = unsigned int*; CryptoPP::NullAllocator<T>::size_type = unsigned int]: Assertion `false' failed.
Building only a static library with OE, (if native build forcing 32bit)
fixes the issue.
This fixes:
WARNING: QA Issue: tegrastats-gtk requires libpangocairo-1.0.so.0, libpango-1.0.so.0,
libcairo.so.2, libpangoft2-1.0.so.0, libgtk-x11-2.0.so.0, libgdk-x11-2.0.so.0,
but no providers in its RDEPENDS [file-rdeps]
While at it remove warning about stripped fw_printenv binary
when building u-boot-toradex-fsl-fw-utils.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
When the link goes down, the DHCP service has been disabled, while
there is no corresponding functionality which enables the service
when the link goes up again. This fix is taken from systemd 217.
This removes the 3.0.15 based Kernel for Colibri VFxx.
Since some time now we use a more recent Kernel provided from the
linux-toradex-vf_3.18.bb recipe.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
With dizzy we got compiler errors when compiling with the new 4.9 gcc.
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
build-deps: add the following to DEPENDS which are referenced by the binaries:
libxv gstreamer libpcre alsa-lib gst-plugins-base
Don't check for file-rdeps
Without this the compiler tries to use a soft abi and stops with an error.
fatal error: gnu/stubs-soft.h: No such file or directory # include <gnu/stubs-soft.h>
While at it unpack sources in standard S directory
While at it it replace version with % wildcard
Update to top of -next branch which also includes FEC unbind
fixes.
This contains some eMMC fixes for Apalis/Colibri T30 as well as a CSI-2
fix for Apalis T30 and an ACM fix.
meta-angstrom now overrides the effect of the patch and provides the
journald.conffile in full.
To override a setting either create the file with your settings in
meta-toradex/recipes-core/systemd/systemd/journald.conf or
edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
