Enable driver for the e-con Systems e-CAM50_CUIMX8.
Related-to: ELB-2793
(cherry picked from commit 0ce993555498905d94f1470b31a9cd6aa2536579)
Older iMX8X modules have the old PMIC deployed that do not support
proper 1.8V switching in SD cards. This commit adds patches to revert
the no-1-8-v removal.
(cherry picked from commit acbfe83716e6a045d9290d932eec29a9afb468f1)
Enable GPIO and serial-port (CD-signal) sources for
the PPS (pulse-per-second) module.
Sync with linux-toradex defconfigs:
b50c1173688fce04eaaa396d23741859e4980326 ("arm64: defconfig: enable GPIO/serial sources for PPS")
70ce76a3d11112c72666ec8481dbe620b722a508 ("ARM: defconfig: apalis/colibri-imx*: enable GPIO/serial sources for PPS")
Related-to: ELB-2837
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit a254a3106a5f37dc8c3f78cfa2ae38ebd4e054c3)
kernel-yocto.bbclass currently, in the case of no patches or configure
fragments does not create kernel-sources/${meta_dir}/config.queue in
do_kernel_metadata. Later do_kernel_configme failes due to the missing file.
| ERROR: Execution of 'run.do_kernel_configme.24874' failed with exit code 1:
| exit 1 from 'configs="$(scc --configs -o ${meta_dir})"'
(cherry picked from commit 926d09720bb3d6388b32736ab7fd63d71f443edc)
linux-imx.inc uses this variable and fails if it is not set.
Vivante 6.4.0.p2.0 is not compatible with 4.14.98 2.3.0.
Add bluetooth drivers useful for the Gumstix AutoBSP as kernel modules.
Related-to: TOR-1068
(cherry picked from commit 66cd4586a396703c9c9ee4580743facffbd15d58)
Add iio/hwmon sensor drivers useful for the Gumstix AutoBSP as kernel
modules.
(cherry picked from commit 21309924e76b931069f8bda00a568e5be54689f3)
Add sound drivers useful for the Gumstix AutoBSP as kernel modules.
(cherry picked from commit 7a1a1ef0da1f7e8c4be18614f1a0d0b1e66ea508)
Compare with device-tree-overlays-mainline in meta-toradex-bsp for the
corresponding recipe for the mainlinish kernel.
(cherry picked from commit 9b4ddb34bae964a229cf04e6e90cae434a619df8)
(cherry picked from commit a815b49cfaf96b7b68d3effe67b2cdd4ebdf96a2)
(cherry picked from commit 418f948282e5fec815f9b1b46337a1d8de431f1c)
(cherry picked from commit 93d0d0eb6d23d1e1a65b556b296c7040f672029c)
(cherry picked from commit b90bae51447483516018b39e9e25e0e141a479ba)
Fixes: 3560660 linux-toradex: synchronise defconfigs
(cherry picked from commit 53a413ee7853ca6430f6eadba4c81e0bfe8aa5b9)
(cherry picked from commit b6b22f90be27868a4e529287ec21d3a8337574bd)
Related-to: ELB-2510
(cherry picked from commit c21550db2958b33f5787828636b7fffcc5545fa5)
(cherry picked from commit 8782c3f3597fff57a511d279da26c4545c735dd8)
(cherry picked from commit 7fa05957ec93243515bac8bd0ffcca70ddafbf69)
(cherry picked from commit b356909a2fd73a885225cfde9e955bf81475da69)
(cherry picked from commit 59f7440d61253fff06fac123f4cb1e6a7d7790a4)
Basically, as per the following commit from the toradex_4.14-2.3.x-imx
branch on git://git.toradex.com/linux-toradex.git:
linux-toradex-rt: synchronise defconfigs
25c008952d3a61c9c402126d4ba7424ef8132f90
arm64: defconfig: further config clean-up
toradex_4.14-2.3.x-imx branch on git://git.toradex.com/linux-toradex.git
b1df9c77a53e92dc6b993007e3d8bb1f3cc61bf6:
colibri imx6ull: defconfig: enable building backports-5.4
Final synchronization with the commit from the toradex_4.14-2.3.x-imx
Resync with latest configs in the kernel, but switch on PREEMPT_RT_FULL.
19a90652d70208c755d3339e21f6bfc8cae04b82:
ARM: apalis/colibri: defconfig: remove backported drivers
76b17e9c0b6f0245dc76c59062257bea2d0d6a0f:
arm64: apalis/colibri: defconfig: remove backported drivers
ab66d6c48c8e78e74ebbf41505db65b0830e6fd7
ARM: apalis/colibri-imx6/7/6ull: enable options for backports
8d6cc5a3e9a2cf349c4d42e13c4449f16512651e
ARM: apalis/colibri-imx6/7/6ull: disable wireless drivers
c666f52447fa426fdc414bb1c922d89969f25385
arm64: defconfig: enable options required for backports
d55c4e1ff7f1a6b23908d45bfec48b2c717d13fe
arm64: defconfig: disable wireless drivers
Related-to: ELB-2687
Related-to: ELB-2388
(cherry picked from commit 971f6133ad0d4ce1560d5e4757e1e9b67803fcad)
(cherry picked from commit c5390eef98c42305cf634862cbd335d493921d73)
(cherry picked from commit a9a49c4d7239a41ccd8b5a03c88d5bd7ed09c1b6)
(cherry picked from commit 26e826cc18b670c28b31d799fdb12a979b7276d1)
(cherry picked from commit 5a12a600be5b7aa85aba72caa2e3840c687df1dd)
(cherry picked from commit 1ac3573c23fc53bcbcb88309eacfb5e5619a7a2d)
(cherry picked from commit 9cbe30427c7d41cb4532a6e85bb7b6a68c65c967)
Basically, as per the following two commits from the
ad4d419f1b24e1d986e2fe956c1f3ca7d1eab93f:
apalis/colibri_imx6/-imx6ull/_imx7/-imx8/8x_defconfig: config refresh
(cherry picked from commit 7c9d1e7c6dca21d622cd7882ffd350017b4a1e1b)
(cherry picked from commit 9196f055af34af3b677de256f2034f0776c165a0)
(cherry picked from commit 634b01a87213f7cdb3f7bc7aa6219a516b0f9923)
(cherry picked from commit 356066099ee58c3e260105e7072230c774b334a4)
(cherry picked from commit b489e2378645151175a6cb34b355157f3e7fc1b4)
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 7bf4461415b013f3ac83cfc41f0a45b46c6076ca)
Related-to: ELB-2351
(cherry picked from commit 97acbfce115572ab2602b0f271c7c6a03687d001)
(cherry picked from commit e1576343bc636ee98b4302e8b82f73014736575d)
(cherry picked from commit 42fff3aa14e1a60ea5b6f78c97d36ea0c2d57f7b)
(cherry picked from commit 4ef23ecfc44e0ef1c6ee2be85a84166cdbfa9408)
This provides headers unique to the NXP downstream kernel.
Since linux-toradex is rebased onto NXP's downstream kernel the needed
git hash is also part of our linux-toradex git and we can save the
download of a second kernel git repo.
(cherry picked from commit afafa08ad3ced8d3baad1196c7b5787756eea853)
(cherry picked from commit 36425ee621438b2aac41f6a8c884c2c7566c93f8)
u-boot-toradex-common.inc: all but below
u-boot-toradex-common_2018.03.inc: i.MX 8 series based modules
u-boot-toradex_2016.11.bbappend: Toradex Easy Installer 2.0
linux-toradex_4.14-2.0.x.bb: all NXP based modules
(cherry picked from commit 7d996d197ad3185838103da3229e01f1b00285c4)
recipes-bsp/u-boot/u-boot-toradex-fw-utils_2016.11.bbappend
recipes-bsp/u-boot/u-boot-toradex_2016.11.bbappend
Resync with the defconfigs from the kernel repository. This adds:
- fix ip firewall (bpf/cgroup)
- Revert "arm64: defconfig: Choose the newer version of the ov5640 driver"
(cherry picked from commit 5bc8b1f2eaecab038635d8218a125abd52b461f0)
Use toradex-kernel-localversion class to implement the new versioning
scheme for U-Boot.
- enable USB WiFi adapter.
Related-to: #58517
(cherry picked from commit fab92d1030fdc4e89cb8e811d5c023fe3abdb181)
Resync with the defconfig from the kernel repository. This adds:
Related-to: #32198
(cherry picked from commit 3bd92089460b412e2caa76ae0d3a8d7eb362ae2f)
(cherry picked from commit e796284434b0f2abae7d56cf734caef176a2c9fc)
(cherry picked from commit 8049ce54e8bd5ccf7570b9c181877ad071533659)
(cherry picked from commit f787738c9364d8b4de44120db3f7a1deb2943082)
Synchronise with kernel defconfig
- add USB HID raw support
- enable ext4 file system security support
- enable USB-to-serial adapters
- add load edid support
Related-to: #57567
meta-freescale master (for zeus) now updates to these recipes versions.
Drop these here.
Enable zram which is useful for compressed swap space in memory. This is
especially useful on embedded devices where swap space on a block device
is not typically enabled (to avoid flash wear).
Resync with kernel defconfig, this includes:
- defconfig: fix delayed mxt loading
- defconfig: fix ip firewall (bpf/cgroup)
The RT project moves the patches into an 'older' directory once superseeded
by a newer patch.
Provide both download paths to cope with the changing location.
While at it use the OE maintained KERNELORG_MIRROR variable to specify the path.
Update rt kernel recipe to use the linux-toradex_4.14-2.0.x kernel.
Re-sync defconfig which enables emulation for deprecated instructions
in ARMv8 for AArch32, enables CAN MCP251X driver, enables a generic
LVDS panel driver and disables CAAM Keystore test driver.
Re-sync defconfig e.g. taking the following dumb-vga-dac idrm bridge
enablement into account:
http://git.toradex.com/cgit/linux-toradex.git/commit/?id=551ce056fd0cd91ae8237d1517469bc1b0f4366f
Remove firmware kobject uevent fallback mechanism and make imx_sdma
a module so it gets loaded when rootfs is mounted.
This prevents the error, that firmware can't be loaded from rootfs
