(cherry picked from commit cc99b62c767130adc2e005470a243853a1476f24)
I.e. reset the whole SoC rather than just the AP partition.
Related-to: ELB-2702
(cherry picked from commit 3be41c0a042994079bdf1577d6062ac0df46fc0a)
(cherry picked from commit ea642448ff0e879429b451b8da5e36f9c0b487eb)
With this commit the new Apalis iMX8QM V1.1B modules are supported
Related-to: ELB-2832
(cherry picked from commit 2545b1f52803e9b4f2f27cb750264d9193e12fbb)
(cherry picked from commit bd2a8c344695e2ffc489e6084991201edf304403)
(cherry picked from commit e68d1621295e27fc17be00c0d696513d1e23ef6a)
(cherry picked from commit c047dd211b39346f7123ac6af0261d0d29508aeb)
Drop variable assignments done in the imx-boot_*.bb file.
Drop firmware-imx8x dependency which is no longer needed with the
split out of SECO in its own package.
With use-mainline-bsp the SoC overrides mx6/mx6q/mx6ull... are filtered out of
the overrides. Replace them with the specific machine name.
Related-to: ELB-2805
(cherry picked from commit 5b0bdea54a34e872a707a3e35d97a157f4c00240)
- Inherit toradex-u-boot-localversion instead of
fsl-u-boot-localversion in u-boot-toradex-common_2018.03.inc.
- Drop LOCALVERSION which has already been defined in
toradex-u-boot-localversion.bbclass.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit aa6434d4d61ad84fe22b91adf2e380a3a63011f5)
- Add HOMEPAGE, SECTION variables which are currently missing.
- Move SUMMARY after including recipes-bsp/u-boot/u-boot.inc, or else
it will be overridden in that file.
(cherry picked from commit c86b878b7ea8ebe1d384d0549cdd14e7a2834705)
They are being referred nowhere in u-boot-toradex_2018.03 recipe, drop
them.
(cherry picked from commit 3b510976a511c90cbd8a814c33d2f99a9b7f60e9)
BOOT_TOOLS is being referred in do_deploy, but the definition is
missing, add it in.
(cherry picked from commit f09feb0bdc196918d3a32a926644e428e59aab3b)
u-boot-toradex_2019.07 shall provide u-boot, add it in.
(cherry picked from commit 7887fbe88a6cf6fc8cfcd27e0a7bada96b750e99)
This reverts commit ff1c822b4facb497dd22f15d40db58f504541c7a.
We need such recipe to be more generic e.g. to apply for apalis-tk1 as
well. Move it to meta-toradex-bsp-common instead.
(cherry picked from commit dbd107b3de14aef44ab1117ca32c7d8d91f08ddc)
Add external device tree overlays to be build outside of the main
linux kernel recipe.
Relates-to: ELB-2723
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
(cherry picked from commit ff1c822b4facb497dd22f15d40db58f504541c7a)
(cherry picked from commit a815b49cfaf96b7b68d3effe67b2cdd4ebdf96a2)
(cherry picked from commit f6859a5d4c7540ae0ffae42e204c0ae532ef04f0)
U-boot recipe supports .cfg files in SRC_URI, but they would be merged
to .config during do_configure only when UBOOT_MACHINE is set, we
should also support merging .cfg files for UBOOT_CONFIG.
Related to: TOR-587, TOR-589, TOR-701, 50811
(cherry picked from commit 24a91ebe7f1472d1d4ce101a56cf81f21b30ba85)
This reverts commit 6a74de45bfed1842912b580488f5d82baf4a5621.
Prepare to cherry-pick to reworked commit from zeus.
Related-to: ELB-2510
(cherry picked from commit c21550db2958b33f5787828636b7fffcc5545fa5)
(cherry picked from commit 8782c3f3597fff57a511d279da26c4545c735dd8)
(cherry picked from commit 7fa05957ec93243515bac8bd0ffcca70ddafbf69)
(cherry picked from commit b356909a2fd73a885225cfde9e955bf81475da69)
(cherry picked from commit 59f7440d61253fff06fac123f4cb1e6a7d7790a4)
Use the latest binaries provided for Toradex boards.
(cherry picked from commit d65873ad2f7a117847c641011a9f9dde74b9462f)
(cherry picked from commit 42628ff8f3b199f3acc837ea9efd8df0931bbd68)
(cherry picked from commit 0e9ae3f78e3c6db243331662072487b295260b51)
This fixes a following compiling error on verdin-imx8mm machine:
+| plat/imx/common/imx8m/imx_rdc.c: In function 'imx_rdc_set_masters':
+| plat/imx/common/imx8m/imx_rdc.c:146:9: error: 'ret' may be used uninitialized in this function [-Werror=maybe-uninitialized]
(cherry picked from commit af3c4735e6f2bfd3c1166a434832286a281a7d65)
(cherry picked from commit 18dd83cc2ef97b664030192cede06ca5f071dfa9)
Related-to: ELB-2351
(cherry picked from commit 0af8ff74ed3106baca390959394c5486d2df4a7e)
(cherry picked from commit 4f5057328843300d9ce1d86e9cb285655112ce42)
(cherry picked from commit a8a8e3ffb13eab296a9f064296a28c74d40eefb1)
This updates to the NXP BSP 2.3.0 at tag rel_imx_4.14.98_2.3.1_patch.
(cherry picked from commit 1d43c7a496efd435c8493afe583864fc4192deb5)
(cherry picked from commit eb1a0e84c8f5732264d4784405ed5a1756964fd7)
(cherry picked from commit 4be26a02083ee3329ba037ea7ec60f153c2a3067)
(cherry picked from commit ce8aca76b97a2238e3bff8c09cc4c1f4dfc40e04)
The seco firmware is now split out of firmware-imx.
The seco firmware has now a i.MX8X B0 and C0 silicon version.
(cherry picked from commit 78802e3ecd139a5031c06821526f249e060894c1)
(cherry picked from commit 264c9e55a59849b1370e4638020cb364662357b0)
Update to version based on NXP SCFW 1.3.1.
Branch name: imx_4.14.98_2.3.0
Build version: 4124
Commit ID: 0x0b929edfe
Build date: Jan 31 2020
Build time: 21:06:48
(cherry picked from commit b4a20babea319d117614e3885d1d28a3b1a5766f)
(cherry picked from commit 99c22a9fc70456d18b2a6b86e643a8aa83b0f9af)
U-boot recipe support .cfg files in SRC_URI, they would be merged to
.config during do_configure, but this is only supported for single
config case (when UBOOT_MACHINE is set), but not supported for multiple
configs case (when UBOOT_CONFIG is set), we shall also support that.
In order to build the scfw recipe the NXP EULA must be accepted.
Enforce acceptence with the fsl-eula-unpack class mechanisms.
Related-to: ELB-1252
(cherry picked from commit 555fad51465ee571c4b565d6615736a0f7acb0ae)
(cherry picked from commit e5049a9c1bf8575beec0d7aab06f5d9cc7093283)
- Set git hash to latest binary build.
- With use-head-next override, now take latest HEAD of the imx-sc-firmware.
Related-to: ELB-2333
(cherry picked from commit 01af70cbb707b01e5f7885711ac32b1eddaf91cd)
(cherry picked from commit bea6c8f39e84010d858ac8978fec31f873820b9a)
Relates-to: TOR-519
Signed-off-by: simon.bueler <simon.bueler@toradex.com>
(cherry picked from commit e5d26e3336ada73c15fc42da6c6dd1ef171ea116)
OE dropped python2 support.
Unify u-boot.inc with openembedded-core which now uses python3 for the build.
u-boot-toradex-common.inc: all but below
u-boot-toradex-common_2018.03.inc: i.MX 8 series based modules
u-boot-toradex_2016.11.bbappend: Toradex Easy Installer 2.0
linux-toradex_4.14-2.0.x.bb: all NXP based modules
(cherry picked from commit 7d996d197ad3185838103da3229e01f1b00285c4)
recipes-bsp/u-boot/u-boot-toradex-fw-utils_2016.11.bbappend
recipes-bsp/u-boot/u-boot-toradex_2016.11.bbappend
This gives the codec reasonable mixer defaults.
(cherry picked from commit c892c94b622c8362cf5092345b93325addd234f1)
Use toradex-u-boot-localversion class to implement the new versioning
scheme for U-Boot.
Taken from meta-freescale, commit eb2b9bf4cefa47175e76eaa50d4a58b5117bdc72
(cherry picked from commit 0cfcc92ee31ecf66167bfc0a48f5a10f87605497)
Now that U-Boot 2019.07 works reliably lets remove the U-Boot 2016.11
recipe.
Without this change, I could not boot a colibri-imx8x board, seems the
imx_4.14.98_2.0.0_ga branch being used in meta-freescale does not work.
This lives now in meta-freescale.
This reverts commit 6dff21d2abbc958b917b94f16762a72fdb207090.
This reverts commit 570e9d521cece6eaa5e52aeb37e2e14d939a98b7.
This reverts commit 2bbb8289258ca3f9d491de0bb861fab21a9e566d.
This reverts commit 9644f8c076d677d6c74674e889eb1dc66d36f827.
Delete binary firmware that is no longer used.
This adds a SCFW that was created with:
./create_and_deploy.sh
scfw_export_mx8qx_b0/platform/main/build_info.h:
SCFW_BRANCH imx_4.14.98_2.0.5_ga
SCFW_BUILD 3353UL
SCFW_COMMIT 0x494c97f3UL
SCFW_DATE "Aug 15 2019"
SCFW_DATE2 Aug_15_2019
SCFW_TIME "18:06:25"
Our SCFW git hash: a5af9ce
The python dependency has been handled properly in OE by the following
commit 3b0b1630:
[ u-boot: Fix pylibfdt generation ]
Drop the redundant python dependency here, they would slow down u-boot
build.
