Deploy device trees for the e-con Systems e-CAM50_CUIMX8.
Related-to: ELB-2793
(cherry picked from commit ce40f8cb4740fb8c4f825b0fab57a365f3f8a69d)
The package name change is now in imx-base.inc in meta-freescale, drop
the override. This prevents a build error if using use-mainline-bsp:
| ERROR: Nothing RPROVIDES 'xf86-video-imx-vivante' (but ...packagegroup-core-x11-xserver.bb RDEPENDS on or otherwise requires it)
| xf86-video-imx-vivante was skipped: incompatible with machine apalis-imx6 (not in COMPATIBLE_MACHINE)
IMX_DEFAULT_BSP set in the distro decides on use-mainline-bsp and sets
the override in imx-base.conf.
Set PREFERRED_PROVIDER_virtual/kernel accordingly.
Drop MACHINE_BOOT_FILES and use the boot file directly, following the
rename of the source file to boot.scr-${MACHINE}.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Use the one in meta-freescale-3rdparty layer, and append toradex
specific definitions to conf/machine/include/colibri-imx6ull.inc.
Set PREFERRED_PROVIDER_virtual/kernel accordingly in apalis-imx6.inc.
Also drop a redundant KERNEL_IMAGETYPE definition.
IMX_DEFAULT_BSP is set to 'mainline' by default, we should change it to
nxp for apalis-imx8x.
Also add PREFERRED_PROVIDER_virtual/kernel_preempt-rt to
linux-toradex-rt.
nxp for apalis-imx8.
nxp for verdin-imx8mm.
- Drop use-mainline-bsp from MACHINEOVERRIDES for upstream, it's
already being handled by IMX_DEFAULT_BSP, we should use that to avoid
multiple use-mainline-bsp in MACHINEOVERRIDES.
(cherry picked from commit f7ebd294c81285a6579b10a09e49a3d635ac4b70)
The prefered provider matching a downstream kernel is set in the distro.
(cherry picked from commit 17d3d131d2d8f8a0bd68f639fdac6b2873c2dde8)
U-Boot used to be configured by 'make <board>_config', however with the
move integration of the Kconfig system that changed to use a config file
ending in _defconfig. Usually those names are <board>_defconfig.
So nowadays one configures with 'make <whatever>_defconfig'.
If make is called with <whatever>_config that is silently changed to
<whatever>_defconfig.
Change our config targets to the new name to prevent confusion.
(cherry picked from commit 30b49e9696e82869cffc9994d7b5391d75c13dec)
MACHINE_NAME must be set after including the apalis-imx8x.conf file or
it will be reset back to the standard Apalis-iMX8X value.
Use DISTRO_FLAVOUR to get a different string into the TEZI image list.
Related-to: ELB-2729
(cherry picked from commit e914e84d24d99ddbd2b33d92e0fa5c913bb78ee4)
MACHINE_NAME must be set after including the colibri-imx8x.conf file or
it will be reset back to the standard Colibri-iMX8X value.
(cherry picked from commit 2bc9708307b480e80b2dbd88921eb24e44fedcfd)
Change the machine 'apalis-imx8x' to build for the C0 silicon SoC version.
Add an additional machine 'apalis-imx8x-v11a' which builds for the
B0 SoC version.
(cherry picked from commit efcc1988ef0bc0d7d6f6651f20cda7c36afa9f8c)
Change the machine 'colibri-imx8x' to build for the C0 silicon SoC version.
Add an additional machine 'colibri-imx8x-v10b' which builds for the
B0 SoC version.
(cherry picked from commit 0911ad890d40dfc9bd7df886c0dcde74a1b41fa7)
(cherry picked from commit 77e97f0d6e1c131b8039cd62937177b8f9688411)
linux-toradex-mainline with prempt-rt in overrides now builds a kernel
with the RT patch applied. Change PREFERRED_PROVIDER to use
linux-toradex-mainline when use-mainline-bsp and prempt-rt are in
overrides.
Related-to: ELB-2631
(cherry picked from commit ac5028651745ea2b541dbc0a847ffd737fc5ef76)
There is a little bit messing with the usages of upstream and
use-mainline-bsp overrides, let's change to use use-mainline-bsp for
kernel and devicetree choosing, upstream would be used to set
(cherry picked from commit 06e21ad7f07f03604c405a6ef0ca119f1d9aabc5)
PREFERRED_PROVIDER_virtual/kernel_upstream_preempt-rt
So far colibri-imx8x is not supported yet in linux-toradex-mainline-rt
source, we need spin it to linux-toradex-mainline temporarily, add note
for this to not confuse developers.
(cherry picked from commit f22d1f900a27ec90660f3dd3f4993c604e59006b)
Note that currently the Toradex Easy Installer does nothing with the
TORADEX_PRODUCT_IDS[0055] setting on eMMC machines.
Related-to: ELB-2322
(cherry picked from commit bdde1ace3087c72ee7129623546c240b905df50c)
Drop the upstreamed machine configuration file and move all differences
into conf/machine/include/colibri-imx6ull.inc.
Deploy additional device trees.
Related-to: ELB-2593
(cherry picked from commit f2f7e066e25c02da2f6448a015b38449c77b0b21)
Corrected with changes to the machine conf files in meta-freescale-3rdparty.
(cherry picked from commit 29126c67d573f446f837b11a5d911cd0b00a13ea)
(cherry picked from commit a840715b5902b03f4ce62376985e19459f88d4e6)
(cherry picked from commit 28e901b9884286420810af7c5e9339b0bf132975)
(cherry picked from commit 20a52efb4a09b37cc4ce76fc0d1b57702997e3ac)
(cherry picked from commit 82f885af14e9dfd5f27a6b8b6f7237d065f542be)
Wi-Fi firmware may help (;-p).
(cherry picked from commit 5ee38688543f6f135774ac9454abf02bcabf6501)
We now have distos which set everything up to build a mainlinsh kernel
where possible. Drop the machines which did choose the meta-freescale
mainlinish kernel and userspace.
Releated-to: ELB-2311
(cherry picked from commit dc3a9bdf8b7871385989b26f490ea63c3185f499)
Related-to: ELB-1254
(cherry picked from commit ad827347548201612eee97129b63db07b3e9a884)
(cherry picked from commit e64e8892ddc0527ec157ed82bf917929774f0916)
The seco firmware is now split out of firmware-imx.
The seco firmware has now a i.MX8X B0 and C0 silicon version.
Related-to: ELB-2351
(cherry picked from commit 78802e3ecd139a5031c06821526f249e060894c1)
(cherry picked from commit 264c9e55a59849b1370e4638020cb364662357b0)
(cherry picked from commit 3d68713e7e28fae312fa869f0742a13edf1700c9)
The changes include:
- Set PREFERRED_PROVIDER_u-boot-default-script to u-boot-distro-boot.
- Drop MACHINE_BOOT_FILES, we dont have to maintain a extra variable.
- Drop colibri-imx7-emmc.conf file, it's already in
meta-freescale-3rdparty layer, move Toradex related definitions to
colibri-imx7-emmc.inc file.
- Drop u-boot-distro-boot from WKS_FILE_DEPENDS, to avoid multiple boot
scripts in it.
This fixes a problem of tezi fitimage not boot issue.
Related-to: TEI-498
(cherry picked from commit 6eaffd7923d9f5905bbeb8db3cfc8071da993cbf)
(cherry picked from commit aa92a5f987267f557aecf5d312fd7f99554a9515)
React on the upstream override and then use a mainlinish kernel.
Use the same kernel also for upstream-rt as we currently don't have
a mainlinish rt flavour ready for i.MX8 X.
(cherry picked from commit f513116f29ee1533af9d51e72526acd3f00893d7)
The machine got renamed in meta-freescale-3rdparty to colibri-imx7-nand.
To keep documentation and scripts working keep the old machine name as
an alias of the new one.
meta-freescale started to set specialised tunes for the i.MX8 based
machines. Override that in our machine specific files so that the
user space packages all have the same ARCH 'aarch64' and need not be
built for each CPU flavour individually.
However change the tune include file so that one could change to one of
the more speciallized tune if one wants to do so at the expense of
additional compile time.
Move from the meta-freescale provided mainline kernel to the
linux-toradex-mainline kernel.
Use the sdma firmware from the linux-firmware recipe.
The firmware-imx recipe no longer provides it: meta-freescale commit
'abc7fdf4cefc firmware-imx: remove sdma-imx6q.bin and sdma-imx7d.bin'
Add UBOOT_ENTRYPOINT and UBOOT_RD_LOADADDRESS which are needed by
fitimage.
(cherry picked from commit 3371f4972842fedb804d2a350e877ab51b5db6e6)
(cherry picked from commit 64f948358c954682cec75b1e76ac66e0cb93c660)
That's already handled by WKS_FILE_DEPENDS, drop the redundant
dependencies.
Without this a getty on the non existing ttyS0 gets additionally started
which then fails and gets continously restarted.
(cherry picked from commit 271c46d3c0202a3cfde6d595d667a97a6b6b84ce)
Currently we do not have device trees for the Aster Carrier board in
upstream kernels. Remove them from the list of device trees when
building mainline kernels.
The preferred versions for weston/wayland-protocols are correctly set
in meta-freescale. Do not pin to an unavailable old version.
Use the same tune for all i.MX8/8X/8MM members.
They are already in meta-freescale layer, we could drop them.
