Bump SRCREV hashes as used in build of Sun Oct 23 09:58:29 UTC 2022
Matrix Build: image-torizoncore-kirkstone-6.x.y-nightly-matrix 74
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-nightly-matrix/74
Signed-off-by: ci.toradex <cicd@toradex.com>
(cherry picked from commit c0e40951656f06b6691448eb3b9041a5ac827d47)
The changes in this bbappend file are deprecated since the following
commit merged in meta-freescale:
commit c59f817b0d1ee70ef224405ff8acd31e0743ed91
Author: Andrey Zhizhikin <andrey.z@gmail.com>
Date: Thu Oct 21 10:01:01 2021 +0000
imx-mkimage: use mkimage tool from sysroot
mkimage tool is provided as a part of sysroot and should not be used as
a local copy, since it contains runtime dependencies which local copy
does not account for.
Drop the local copy on mkimage, introduce the patch that fixes mkimage
invocations in build system.
Signed-off-by: Andrey Zhizhikin <andrey.z@gmail.com>
let's delete the bbappend recipe.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 9e006dccef9e22a430ab56b765420b13f532c56a)
Set mixer audio level to default, this prevents audio distortions and
fixes our automated test execution.
Related-to: ELB-4829
Fixes: 5f920cd5b4b2 ("alsa-state:apalis-imx6: fix sound device name in asound.conf/asound.state")
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
(cherry picked from commit 9f9bd44f739697448a03c19534fa079e6445377f)
The sound device name in asound.conf of apalis-imx6 machine does not
match the sound driver of kernel 5.15 and upper, fix that. Also
regenerate asound.state according to the new asound.conf.
(cherry picked from commit 5f920cd5b4b202b277eeae945fbda6c206672005)
Related-to: ELB-4838
(cherry picked from commit 91f253942aef769901bc5e5058851fdc4d49a64c)
Update linux-firmware to NXP's 5.15.52-2.1.0 BSP.
This updates the SDIO-UART W8997 Wi-Fi and Bluetooth/Bluetooth LE
firmware used on the Verdin iMX8M Plus V1.1A and later to version
16.92.21.p55.3 comming from NXP's downstream Linux BSP L5.15.52_2.1.0
paired with NXP's proprietary wireless chipset driver MM5X16344.p3-GPL.
On their GitHub NXP calls this firmware version mxm5x17344.p3.
Related-to: ELB-4845
(cherry picked from commit 420d0d26cdc92c767fd78a95746576faf60f3e4b)
Turns out that somehow we still have some old override syntax stuff
laying around!
(cherry picked from commit 70bc6c6d11a0d1c693fa63bdcbcafee8cd793bdf)
laying around!
This resulted in the following build error:
ERROR: btuart-1.0-r0 do_package: QA Issue: btuart: Files/directories
were installed but not shipped in any package:
/usr
/lib
/usr/sbin
/usr/sbin/btuart.sh
/lib/systemd
/lib/systemd/system
/lib/systemd/system/btuart.service
Please set FILES such that these items are packaged. Alternatively if
they are unneeded, avoid installing them or delete them within
do_install.
btuart: 7 installed and not shipped files. [installed-vs-shipped]
(cherry picked from commit 4155ae8d8eef233773c13749807c0b6c7c91a133)
Lower PCM volume from 192 (100%) to 144 (75%).
At 100% there are signal distortion that are not nice to hear and this
also prevent some automated test to succeed.
Related-to: ELB-4722
(cherry picked from commit 9ac70bc5e4182c2b8972c6b495892cdfbbfc75c4)
Bump SRCREV hashes as used in build of Wed Oct 5 14:55:28 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 76
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/76
(cherry picked from commit a80de26deaaf94fd735bf00ce724ed568f965b04)
And remove the outdated 'hardknott honister'.
Related-to: ELB-4810
(cherry picked from commit ea0f4ff2de1be789e2b4e59df7f35fcb683e940d)
Get to a readable and editable format how the overlays in
TEZI_EXTERNAL_KERNEL_DEVICETREE_BOOT are written.
This commit intends no functional changes, only formatting.
(cherry picked from commit d4173d61af40f4eec3b6c95059119323378c30a1)
Adapt to new U-Boot env memory layout:
UBOOT_DTB_LOADADDRESS = "0x50200000"
UBOOT_DTBO_LOADADDRESS = "0x50240000" (using $fdt_addr_r + 256k)
UBOOT_ENTRYPOINT = "0x48200000"
UBOOT_RD_LOADADDRESS = "0x50300000" (not used in regular BSP)
(cherry picked from commit d319cae50f2e18f696c4a2aac5b2d22b9b21e1e7)
Restructure machine configuration files slightly to ease future
maintenance. Just cosmetic, no functional change at all.
(cherry picked from commit 6c823e67ef91b8d25e6b2c06e3cff6ce3af9ba04)
First load complete FIT image to $loadaddr instead of ramdisk_addr_r.
Then load script to $scriptaddr instead of $loadaddr and jump to it.
loadaddr = 0x84200000
scriptaddr = 0x88280000
(cherry picked from commit b2ff46d7d241df4dbfceaf498c662fdd92e0a0be)
UBOOT_DTB_LOADADDRESS = "0x88200000"
UBOOT_DTBO_LOADADDRESS = "0x88300000" (using $pxefile_addr_r)
UBOOT_ENTRYPOINT = "0x84200000"
UBOOT_RD_LOADADDRESS = "0x88400000" (not used in regular BSP)
(cherry picked from commit 258f608b216d8d9d8adc50900a19454b6f73174e)
(cherry picked from commit 1c21865e978d1a9d9c48123f4d0c34502ca7537f)
meta-freescale now does remove these packageconfigs too, so drop it here.
Related-to: ELB-4665
(cherry picked from commit b6dfe9cab23d23cb5ce6d9b4d54e9dcb14af8803)
The code the patch removes is still present, keep the patch also
with the new version.
(cherry picked from commit bd7f3d8596e984d42afa1c9b30fd635fb02fc040)
This overlay enables the spidev driver on the apalis imx6 spi interface.
Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
This overlay enables the spidev driver on the colibri imx6ull spi interface.
This overlay enables the spidev driver on the colibri imx6 spi interface.
This overlay enables the spidev driver on the colibri imx7 spi interface.
Bump SRCREV hashes as used in build of Thu Sep 1 21:40:51 UTC 2022
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 48
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/48
meta-toradex-bsp changed to build U-Boot from our own recipe rather
than bbappending to what openembedded-core provides. Change the
machines to use the new recipe.
Relates-to: ELB-4680
This overlay enables spidev by default.
This reverts commit 7ea89843ca570a664b8052dfcb007cb50573b00c.
imx-seco in meta-freescale kirkstone is updated to 3.8.6, drop
the backport here.
meta-freescale updated to weston_10.0.0.imx.
The packageconfig fixes are for some time in the meta-freescale
recipe and thus no longer needed.
The patches address hickups seen with machines without a GPU which
we now only support with imx-mainline-bsp, i.e. with upstream weston..
imx-atf 2.6 landed in meta-freescale master and kirkstone.
On BSP 6 the new overlays branch toradex_5.15-2.3.x-imx will be used for
overlays.
Do comment out the device-trees that are not yet ported to the 5.15
kernel. Just give it the eval device-tree that came in through mainline
so that it builds.
This commit is intended to be reverted once the device-trees are back in
5.15.
kernel. Just give it no device-tree so that at least the machine does
build for now.
5.15.
Delete stray ':' in SRC_URI entry.
Fixes d4c628a ("linux-toradex_5.15-2.0.x.bb: make rt patch apply")
Revert conflicting downstream changes before applying the RT-Patch
and reapply those changes afterwards.
Related-to: ELB-4597
With the downstream kernel based on NXPs 5.15.35-2.0.0 BSP the
linux-imx-headers mustn't no longer be downgraded.
Keep using the bbappend to checkout the kernel from git.toradex.com.
After v2022.07 the device tree files were unified with the kernel
ones including using their file names.
Follow that if building with use-head-next override.
Related-to: ELB-4315
We now use the openembedded-core u-boot recipe with a bbappend
in meta-toradex-bsp-common.
Related-to: ELB-4581
Currently the VGA overlay does not work with mainline kernel,
disable it till a better solution is implemented to allow
booting/testing the current image.
Related-to: ELB-4649
It's already in meta-freescale-3rdparty layer.
We dont support VF machines, let's drop its references.
Related-to: ELB-4471
Copied from u-boot-fslc_2022.04
Fixes: commit 0096007 ("Switch U-Boot to toradex_imx_lf_v2022.04")
Currently we have downstream/upstream Toradex uboot recipes and we dont
want to add fw_env.config for both of them to avoid code redundant.
Let's move fw_env.config to libubootenv, which will be installed for
both donwstream/upstream distros.
Related-to: ELB-4536
- Adjust hashes
- Take in new corresponding RT-patch
- Delete machines we won't support
- Drop already commented out patches
The following sentence was added at the end of the COPYING file:
All contributions to the Linux Kernel are subject to this COPYING file.
Do no changes in this commit else than renaming the recipe.
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Add the two patches from our imx-atf fork that are not yet upstreamed
and are not upstreamable.
Related-to: ELB-4586
[ Backported from
https://source.codeaurora.org/external/imx/meta-imx/tree/meta-bsp/recipes-bsp/imx-atf/imx-atf_2.6.bb?h=kirkstone-5.15.32-2.0.0 ]
Copy the recipe for imx-atf on v2.6 which is needed for the NXP release
LF5.15.32_2.0.0.
[ps: do not deploy inside ${BOOT_TOOLS}]
