Related-to: ELB-2351
The seco firmware is now split out of firmware-imx.
The seco firmware has now a i.MX8X B0 and C0 silicon version.
Update to version based on NXP SCFW 1.3.1.
Branch name: imx_4.14.98_2.3.0
Build version: 4124
Commit ID: 0x0b929edfe
Build date: Jan 31 2020
Build time: 21:06:48
This fixes a problem of tezi fitimage not boot issue.
Related-to: TEI-498
Signed-off-by: Ming Liu <ming.liu@toradex.com>
In order to build the scfw recipe the NXP EULA must be accepted.
Enforce acceptence with the fsl-eula-unpack class mechanisms.
Related-to: ELB-1252
- Set git hash to latest binary build.
- With use-head-next override, now take latest HEAD of the imx-sc-firmware.
Related-to: ELB-2333
Add UBOOT_ENTRYPOINT and UBOOT_RD_LOADADDRESS which are needed by
fitimage.
That's already handled by WKS_FILE_DEPENDS, drop the redundant
dependencies.
u-boot-toradex-common.inc: all but below
u-boot-toradex-common_2018.03.inc: i.MX 8 series based modules
u-boot-toradex_2016.11.bbappend: Toradex Easy Installer 2.0
linux-toradex_4.14-2.0.x.bb: all NXP based modules
Resync with the defconfigs from the kernel repository. This adds:
- fix ip firewall (bpf/cgroup)
- Revert "arm64: defconfig: Choose the newer version of the ov5640 driver"
This gives the codec reasonable mixer defaults.
Without this a getty on the non existing ttyS0 gets additionally started
which then fails and gets continously restarted.
- enable USB WiFi adapter.
Related-to: #58517
Resync with the defconfig from the kernel repository. This adds:
Related-to: #32198
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Taken from meta-freescale, commit eb2b9bf4cefa47175e76eaa50d4a58b5117bdc72
The U-Boot recipe decorates u-boot-nodtb.bin with machine and configuration.
The device-trees search the sdma firmware in /lib/firmware/imx/sdma/ so
actually deploy it there.
Synchronise with kernel defconfig
- add USB HID raw support
- enable ext4 file system security support
(cherry picked from commit 557a0e42badba143a8c0b3b0ef0eb1d4ebb5ee10)
- enable USB-to-serial adapters
- add load edid support
Related-to: #57567
(cherry picked from commit b103c379c216b5e370e7702b3e586e81c38625bb)
This reverts commit e3e5aba1c725ad3ff4daf128ad525625923a653d.
Enable zram which is useful for compressed swap space in memory. This is
especially useful on embedded devices where swap space on a block device
is not typically enabled (to avoid flash wear).
Resync with kernel defconfig, this includes:
- defconfig: fix delayed mxt loading
- defconfig: fix ip firewall (bpf/cgroup)
Fix QA issue: SRC_URI uses PN not BPN [src-uri-bad]
The UBOOT_MAKE_TARGET is being overridden in imx-base.inc by
UBOOT_MAKE_TARGET_mx8, so the setting here is useless.
This commit makes sure the new devicetree naming is only used when
use-head-next is given in local.conf. This is necessary so one is
able to build thud-next without use-head-next.
Delete binary firmware that is no longer used.
The RT project moves the patches into an 'older' directory once superseeded
by a newer patch.
Provide both download paths to cope with the changing location.
While at it use the OE maintained KERNELORG_MIRROR variable to specify the path.
This adds a SCFW that was created with:
./create_and_deploy.sh
scfw_export_mx8qx_b0/platform/main/build_info.h:
SCFW_BRANCH imx_4.14.98_2.0.5_ga
SCFW_BUILD 3353UL
SCFW_COMMIT 0x494c97f3UL
SCFW_DATE "Aug 15 2019"
SCFW_DATE2 Aug_15_2019
SCFW_TIME "18:06:25"
Our SCFW git hash: a5af9ce
Update rt kernel recipe to use the linux-toradex_4.14-2.0.x kernel.
These files should have been deleted with commit
'bac2ba colibri-vf: drop machine'.
To support Aster carrier board.
