NXP's 2.3.1. BSP is based on the following version.
wayland-protocols: "1.17.imx"
weston: "5.0.0.imx"
Related-to: ELB-2303
(cherry picked from commit be3bebbc165727418f261d29bd75dd413527fd97)
(cherry picked from commit f0fd9dc7da066aa5d49903b518f01e6bce4cafaa)
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit b41d325b2650724e0645acbeddcbc72e6af52747)
'DISTRO' is in DISTROOVERRIDES by default, we should not use "=" to
override that when adding 'tdx' to DISTROOVERRIDES, use ".=" to append
to it.
With the above change, we do not need to append 'tdx-x11' and
'tdx-xwayland' to DISTROOVERRIDES, drop them.
(cherry picked from commit 9a93acdeda3fed168b74c33788f385ac42702ed4)
(cherry picked from commit 32d4cdf84966fd20d7dcd58c25d574f3e1ff947f)
Currently the generated image file names do not change with a change
of the distro flavour.
Related-to: ELB-1424
(cherry picked from commit ab0bca582337022fbc6763ce43013ce3baa96208)
(cherry picked from commit 74a602aa995bf0331e6aa0619874487dd14ba49c)
tdx overrides should be used by both tdx and torizon distros, torizon
overrides should not be in this layer.
The imx gstreamer update is updated to 1.16.imx.
Add TDX_VERSION which can be used by Toradex customized software
artifacts like U-Boot or the Linux kernel. This version number does
not contain a date timestamp to prevent unnecessary rebuilds. It is
assumed that the software artifact adds a build number (e.g. git
hash).
Implement new version number scheme. This has been tested recently in
meta-toradex-torizon and proven to work reliably. Lets move it to
meta-toradex-distro so all Toradex distribution can make use of it.
Most of the desktop like images require polkit.
E.g. liblxqt depends on it.
oe-core commit ac83d22eb removed armv7a or armv7ve from the TUNE_FEATURES.
This made the python logic no longer kicking in and reverted to have
CPU specific package feeds.
This is used in generating the image name, so that one sees in the
Toradex Easy Installer which is which.
This defines preempt-rt in distro overrides. The individual machine
configuration then needs to choose the RT kernel flavour.
While at it, unify comment.
The distro layer seems to work fine with newer OpenEmbedded releases,
add warrior to supported series.
This mutes a following QA warning:
| WARNING: No bb files matched BBFILE_PATTERN_meta-toradex-distro
| '^/mnt/toradex/toradex-build/build/../layers/meta-toradex-distro/'
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Using python to conditionally set PREFERRED_VERSION_xxx does work, however
bitbake evaluates the value of PREFERRED_VERSION_xxx before set in the
python function.
Reverting the conditional assignment in favour of a hard coded upstream value.
fixes: 1e400c68e
The recipes for gstreamer* with version 1.14.imx set compatible version to
mx6, mx7, mx8. So for machines which use use-mainline-bsp we get a lot of
OE warnings during build, e.g.:
| NOTE: preferred version 1.14.imx of gstreamer1.0 not available (for item gstreamer1.0)
| NOTE: versions of gstreamer1.0 available: 1.14.4
build is actually a file not a directory.
If a derived distro does not want /etc/hostname then that should be added
for that distro only.
Only adds a tdx-x11 distro. Additional flavours to follow.
