Use separate variables for version components. This is useful to form
the new OSTree branch names which use the major version only.
Related-to: TOR-1107
Define PREFERRED_PROVIDER_virtual/dtb to device-tree-overlays.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
NXP's 2.3.1. BSP is based on the following version.
wayland-protocols: "1.17.imx"
weston: "5.0.0.imx"
Related-to: ELB-2303
(cherry picked from commit be3bebbc165727418f261d29bd75dd413527fd97)
'DISTRO' is in DISTROOVERRIDES by default, we should not use "=" to
override that when adding 'tdx' to DISTROOVERRIDES, use ".=" to append
to it.
With the above change, we do not need to append 'tdx-x11' and
'tdx-xwayland' to DISTROOVERRIDES, drop them.
It should be moved to meta-toradex-torizon layer.
Currently the generated image file names do not change with a change
of the distro flavour.
Related-to: ELB-1424
Add TDX_VERSION which can be used by Toradex customized software
artifacts like U-Boot or the Linux kernel. This version number does
not contain a date timestamp to prevent unnecessary rebuilds. It is
assumed that the software artifact adds a build number (e.g. git
hash).
Implement new version number scheme. This has been tested recently in
meta-toradex-torizon and proven to work reliably. Lets move it to
meta-toradex-distro so all Toradex distribution can make use of it.
Most of the desktop like images require polkit.
E.g. liblxqt depends on it.
oe-core commit ac83d22eb removed armv7a or armv7ve from the TUNE_FEATURES.
This made the python logic no longer kicking in and reverted to have
CPU specific package feeds.
This is used in generating the image name, so that one sees in the
Toradex Easy Installer which is which.
This defines preempt-rt in distro overrides. The individual machine
configuration then needs to choose the RT kernel flavour.
While at it, unify comment.
The distro layer seems to work fine with newer OpenEmbedded releases,
add warrior to supported series.
This mutes a following QA warning:
| WARNING: No bb files matched BBFILE_PATTERN_meta-toradex-distro
| '^/mnt/toradex/toradex-build/build/../layers/meta-toradex-distro/'
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Using python to conditionally set PREFERRED_VERSION_xxx does work, however
bitbake evaluates the value of PREFERRED_VERSION_xxx before set in the
python function.
Reverting the conditional assignment in favour of a hard coded upstream value.
fixes: 1e400c68e
The recipes for gstreamer* with version 1.14.imx set compatible version to
mx6, mx7, mx8. So for machines which use use-mainline-bsp we get a lot of
OE warnings during build, e.g.:
| NOTE: preferred version 1.14.imx of gstreamer1.0 not available (for item gstreamer1.0)
| NOTE: versions of gstreamer1.0 available: 1.14.4
build is actually a file not a directory.
If a derived distro does not want /etc/hostname then that should be added
for that distro only.
Only adds a tdx-x11 distro. Additional flavours to follow.
