The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
Add the new machine now available from meta-toradex-nxp.
Since apalis-imx8x has been supported in meta-toradex-nxp layer, add it
into local.conf.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
NXP dropped X11 support for i.MX8 and i.MX8X.
Thus build our images with the tdx-xwayland distro configuration.
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
There is a resonable default in bitbake.conf. For all our machines it is also
set explicitely so there is no need to carry this in local.conf.
Move the DEPLOY_DIR directory to be inside the build directory.
Using the same layer metadata to create two independent build directories
(e.g. for two builds of the same machine but with different kernels)
now has the deploy directory name no longer clash.
Move DL_DIR and SSTATE_DIR to the root of the oe installation.
This then automatically shares downloads and sstate between different build
directories.
Also adapted to use the now available tdx-x11 distro.
