Follow meta-freescale commit 30f5ce1d ("Generalize overrides subsystem for
NXP and Mainline support").
TEZI_SHOW_EULA_LICENSE shall be a machine global variable but not image
specific, move it to tdx-base.inc in meta-toradex-distro layer.
Torizoncore/Tezi/BSP now use the same setting of
TEZI_SHOW_EULA_LICENSE.
Related-to: TOR-2102
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit a991a45459b7f3c0870ef94da6e48c279eaa97f0)
These versions were pinned when backporting a newer NXP BSP to dunfell.
In master these versions were bumped in meta-freescale and the new versions
are set to preferred there. The override here interferes and instead of
the i.MX specific recipe the upstream recipe from OE-Core is built.
This among other thing drops including image-prelink.bbclass which
is now dropped in openembedded-core.
All other changes only affect comments.
Uprev all recipes used by the Toradex Easy Installer.
Do this by refactoring the list of recipes in a bsp list used for all
builds and add the additional ones for TEZI and Torizon.
Related-to: AUT-932
(cherry picked from commit e835edf3bc368fc6beb64acefa96a349ec6da281)
scripts/uprev-srcrev
Fix wrong new override syntax conversion
apalis-imx8x is no longer supported
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
(cherry picked from commit 3f6705ce88f7a8dd1f026334743d6b6bf8747965)
Since commit c9c9679 ("buildconf/local.conf: don't set any machine by
default") calling scripts/uprev-srcrev creates a python crash unless
one makes sure a MACHINE is set.
Just reading PV from the datastore before continuing with doing the
uprev fixes the issue.
Fixes:
| Traceback (most recent call last):
| File "/home/krm/bla/dunfell/layers/openembedded-core/bitbake/lib/bb/fetch2/__init__.py", line 1585, in latest_revision
| return revs[key]
| File "/home/krm/bla/dunfell/layers/openembedded-core/bitbake/lib/bb/persist_data.py", line 50, in wrap_func
| return f(self, *args, **kwargs)
| File "/home/krm/bla/dunfell/layers/openembedded-core/bitbake/lib/bb/persist_data.py", line 79, in wrap_func
| return f(self, cursor, *args, **kwargs)
| File "/home/krm/bla/dunfell/layers/openembedded-core/bitbake/lib/bb/persist_data.py", line 167, in __getitem__
| raise KeyError(key)
| KeyError: 'git:git.toradex.com.u-boot-toradex.gittoradex_2020.07'
| During handling of the above exception, another exception occurred:
| The above exception was the direct cause of the following exception:
| File "/home/krm/bla/dunfell/layers/openembedded-core/bitbake/lib/bb/fetch2/__init__.py", line 1587, in latest_revision
| revs[key] = rev = self._latest_revision(ud, d, name)
| File "/home/krm/bla/dunfell/layers/openembedded-core/bitbake/lib/bb/fetch2/git.py", line 689, in _latest_revision
| sha1, ref = l.split()
| bb.data_smart.ExpansionError: Failure expanding variable SRCPV, expression was ${@bb.fetch2.get_srcrev(d)} which triggered exception ValueError: not enough values to unpack (expected 2, got 0)
(cherry picked from commit b78d9de8e585f5071f62bab7362c8e69affe4102)
Don't set a default machine so that a user has to explicitly choose
what machine one builds for.
Add a warning to not set MACHINE after the include ${MACHINE}.inc line.
Related-to: ELB-4179
(cherry picked from commit c9c96799dbb030262ac03f44067ee61ada93d93d)
(cherry picked from commit 9f52ce166e8e3c10fa0935f55b3f403085f64fa2)
Relates-to: ELB-4127
(cherry picked from commit e73336f9ff769414c5090640b6f33dc7b3169afb)
Related-to: ELB-4065
Signed-off-by: Oleksii Bidnichenko <oleksii.bidnichenko@toradex.com>
(cherry picked from commit e1ede4ecd59e23f29f19dc9729f0a3b89f1f69af)
NXP's gstreamer fork is updated to 1.18.0.imx.
The usage of the default value operator makes it easier to overwrite the
DISTRO variable in other configuration files (e.g., for continuous
integration).
Signed-off-by: Tomas Novotny <tomas@novotny.cz>
Currently the preferred version for the gstreamer components is
assigned with '='. Relax that to '?=' to allow for a easier override
in other configuration files.
Proposed-by: Carlos Rafael Giani <crg7475@mailbox.org>
With the override syntax change oe bumped the needed version.
See commit 5452f1ba33 ("local.conf.sample: Bump version so users
update their config")
This is the result of automated script (0.9.3) conversion:
../openembedded-core/scripts/contrib/convert-overrides.py .
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
converting the metadata to use ":" as the override character instead of "_".
(cherry picked from commit 390fb8af9c4b2b13b891df6907b96ee53d201e5f)
Openembedded core no longer provides the class. Remove it.
See commit 908df863b4 ("mklibs: remove recipes and class")
To involve in basic sanity check for Toradex builds.
Related-to: ELB-3944
(cherry picked from commit a12eef0d00f2dce08e65ac3b70075a21abc5c5dc)
So far exceptions have been catched in the python script and
have not been reported back to caller. The status code of the script
was always 0. This makes it impossible to the build scripts to react
on failed runs of uprev-srcrev tool.
In case a recipe can not be found, patching further recipes
gets skipped and a status code not equal to 0 is returned.
Signed-off-by: samuel.bissig <samuel.bissig@toradex.com>
(cherry picked from commit a5fcc0566de94d92f78ab156f641ac5dc58855fc)
On the build server the three output lines produced by a single recipe
are not together which makes it hard to check which recipe got updated
to which source revision.
Print the recipe file name together with the git hash makes it all clear.
Changes
| [krm@linuxdev2 build]$ ../layers/meta-toradex-distro/scripts/uprev-srcrev
| INFO: Processing recipe ../layers/meta-toradex-bsp-common/recipes-kernel/backports/backports_5.4.bb
| NOTE: Starting bitbake server...
| INFO: Update SRCREV to 4cb81c29dde242744eccf9f37f2014ea3b37ade2.
| INFO: Processing recipe ../layers/meta-toradex-bsp-common/recipes-kernel/linux/linux-toradex-mainline_5.4.bb
| INFO: Update SRCREV_machine to db57a7415fa94e0d5a7f23908be15d5d6e72a891.
to
| INFO: backports_5.4.bb: Update SRCREV to 4cb81c29dde242744eccf9f37f2014ea3b37ade2.
| INFO: linux-toradex-mainline_5.4.bb: Update SRCREV_machine to db57a7415fa94e0d5a7f23908be15d5d6e72a891.
(cherry picked from commit 213eb8b0826eb8f33c3a87518762dca480c85354)
(cherry picked from commit 632db61f177acf18df79d40fefdf1c662c6233a8)
It's by default disabled, the end users could choose to enable them by
uncommenting two lines.
Related-to: TOR-1700
(cherry picked from commit ff7025a26e13326eb12444fb853de655629378e0)
Some Toradex recipes like linux-toradex, u-boot-toradex,
device-tree-overlays are appending SCM hashes to PV, version numbers
going backwards are not a problem as we don't provide binary feeds.
This avoids some annoying errors as follows:
| QA Issue: Package version went backwards which would break package feeds
Related-to: ELB-3583
(cherry picked from commit 3c1f97ef5bbea7f6afaaea5b58ce1b8baa4ce82f)
meta-freescale added the revision part of the gstreamer imx forks to the version,
i.e. 1.16.imx -> 1.16.2.imx. Rework the preferred versions.
NXP release imx_5.4.70_2.3.0.
Related-to: ELB-3327
(cherry picked from commit 2561e4a6cc6d5a8f6badb32ed3ead6eb4b536519)
Use two lists of recipes which should be upreved, one for tdxref and one
for Torizon builds.
Currently Torizon has additionally the linux kmeta repo but lacks the
Apalis TK1 U-Boot.
Relates-to: AUT-507
Force BB_SRCREV_POLICY to 'clear'. Thus the fetcher queries the remote
git repo for the latest HEAD and does not rely on the copy in the local
download directory.
With this, we can change CI to run uprev-srcrev before building the
images if we want to build latest HEAD of our components rather than
using AUTOREV through use-head-next.
This prevents that a push to the repos during a build might cause
build errors.
Related-to: AUT-528
So far the graphical backend (X11 / Wayland) did not show in the created
image names or the Toradex Easy Installer meta data at all.
As we now build by default only Wayland, leave those alone. If one builds
for X11 then add this to the file name and the descriptive meta data.
We dont really need 'ptest' and that would invovle in a lot of recipes
to be built which could be very time consuming.
Related-to: ELB-3195
(cherry picked from commit 27000bd0282b681ab083430b5e49d81e42ce1f71)
Related-to: ELB-2303
(cherry picked from commit 1e0d10b2851ac455618ab7e4c7db86c9ad1227a0)
Add imx-sc-firmware to the list of recipes to update src rev. This
recipe is now a regular recipe (not a bbappend) and hence can be used
uprev'ed using recipetool.
Related-to: AUT-355
(cherry picked from commit e3c9f089b2dd3b807d97dec80fa15a5d13f86cea)
Create a Toradex specific script which loops through all recipes using
AUTOREV and updates them to the current git hash.
Related-to: AUT-355
(cherry picked from commit 35fd1b9ead35b45a590b0a478f9ca11512d05921)
Use the recipetool plugin mechanism to add a updatesrcrev command. This
allows to update the SRCREV variable to point to the current git hash
the references git branch is pointing to. A OpenEmbedded build
environment needs to be initialized. Then use the following command to
update SRCREV of a particular recipe:
recipetool updatesrcrev <path-to-recipe>
Related-to: AUT-354
(cherry picked from commit f80b1846113635ec84177f0020efab02f6679d1a)
SDK_VERSION is used as a path element for the nativesdk packages. Thus,
if variables are used to form it which are excluded to force a rebuild,
when using sstate or previous build artefacts paths stay not the same
resulting in various build failures.
So drop all elements which are marked with "vardepsexclude".
E.e.:
Dependencies not found in compile/configure as the search paths don't match.
Build output not found:
| rm: cannot remove '.../image/opt/tdx-xwayland/5.0.0-devel-20200821220610+build.0/sysroots/x86_64-tdxsdk-linux/usr/lib/aarch64-tdx-linux/gcc/aarch64-tdx-linux/9.3.0/install-tools': No such file or directory
'upstream' has already been appended in tdx-xwayland-upstream.conf.
Don't add a second one. I.e. don't create an image file name like this:
Apalis-iMX6_Reference-Minimal-Image-upstream-rt-upstream-Tezi_5.0.0-devel-20200817071112+build.0
Related-to: ELB-2758
Related-to: ELB-2552
Related-to: ELB-2838
meta-freescale handles use-mainline-bsp in the common imx-base.inc
file. Follow that change.
While at it, simplify the upstream-rt distros by including the
corresponding upstream distro.
(cherry picked from commit 276c966a04bbe4d19866becb3b8fc147d1079049)
Use separate variables for version components. This is useful to form
the new OSTree branch names which use the major version only.
Related-to: TOR-1107
(cherry picked from commit 3f69c5d786d0677ff1f1d959e5e8e482a4e4148b)
