meta-freescale handles use-mainline-bsp in the common imx-base.inc
file. Follow that change.
While at it, simplify the upstream-rt distros by including the
corresponding upstream distro.
(cherry picked from commit 276c966a04bbe4d19866becb3b8fc147d1079049)
Use separate variables for version components. This is useful to form
the new OSTree branch names which use the major version only.
Related-to: TOR-1107
(cherry picked from commit 3f69c5d786d0677ff1f1d959e5e8e482a4e4148b)
Define PREFERRED_PROVIDER_virtual/dtb to device-tree-overlays.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
(cherry picked from commit c4b1a3d10e0245ff7ac9e4c11ad135f8488f8409)
The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
(cherry picked from commit 7f8cd66bb84f32c3b7dd4eea95ba9482786770c0)
(cherry picked from commit adb62ac9dfeed9827e0a706a5c2c2a64ebb95b06)
NXP's 2.3.1. BSP is based on the following version.
wayland-protocols: "1.17.imx"
weston: "5.0.0.imx"
Related-to: ELB-2303
(cherry picked from commit be3bebbc165727418f261d29bd75dd413527fd97)
(cherry picked from commit f0fd9dc7da066aa5d49903b518f01e6bce4cafaa)
(cherry picked from commit b41d325b2650724e0645acbeddcbc72e6af52747)
'DISTRO' is in DISTROOVERRIDES by default, we should not use "=" to
override that when adding 'tdx' to DISTROOVERRIDES, use ".=" to append
to it.
With the above change, we do not need to append 'tdx-x11' and
'tdx-xwayland' to DISTROOVERRIDES, drop them.
(cherry picked from commit 9a93acdeda3fed168b74c33788f385ac42702ed4)
This addition checks if one is using the integration branch with repo
if that is true it will automatically append the correct use-head-next
setting. If this is for whatever reason not set it will tell the user
to not forget setting use-head-next on integration branch.
(cherry picked from commit 045a6a34c51a436e864267f60501702ad6fdbcea)
zsh has which built-in. Therefore calling which echo is resulting
in something unexpected:
$ which echo
echo: shell built-in command
use $(env which echo), that is using a which command from the PATH
variable. Also use $() instead of the deprecated ``.
(cherry picked from commit a4fa7bb1fb198fac82db91576994c98fc1014c71)
(cherry picked from commit 32d4cdf84966fd20d7dcd58c25d574f3e1ff947f)
The 'Parallelism Options' are now set in bitbake.conf to a sensible default.
Some options are now set with ?= to allow for easier overrides.
A lot of trailing whitspace has been removed.
Currently the generated image file names do not change with a change
of the distro flavour.
Related-to: ELB-1424
(cherry picked from commit ab0bca582337022fbc6763ce43013ce3baa96208)
(cherry picked from commit 74a602aa995bf0331e6aa0619874487dd14ba49c)
tdx overrides should be used by both tdx and torizon distros, torizon
overrides should not be in this layer.
The imx gstreamer update is updated to 1.16.imx.
The dropped lxqt-image and qt5-x11-image were the only users of meta-qt5
and meta-qt5-extra.
Remove those layers from our sample bblayers.conf.
The dropped lxde-image was the only user of meta-browser and meta-lxde.
Remove those layers from our sample bblayer.conf.
This also allows to drop meta-clang and meta-rust which are required
only by meta-browser.
Add TDX_VERSION which can be used by Toradex customized software
artifacts like U-Boot or the Linux kernel. This version number does
not contain a date timestamp to prevent unnecessary rebuilds. It is
assumed that the software artifact adds a build number (e.g. git
hash).
Implement new version number scheme. This has been tested recently in
meta-toradex-torizon and proven to work reliably. Lets move it to
meta-toradex-distro so all Toradex distribution can make use of it.
Add the new machine now available from meta-toradex-nxp.
Most of the desktop like images require polkit.
E.g. liblxqt depends on it.
meta-browser now depends on meta-clang.
oe-core commit ac83d22eb removed armv7a or armv7ve from the TUNE_FEATURES.
This made the python logic no longer kicking in and reverted to have
CPU specific package feeds.
This is used in generating the image name, so that one sees in the
Toradex Easy Installer which is which.
Since apalis-imx8x has been supported in meta-toradex-nxp layer, add it
into local.conf.
This defines preempt-rt in distro overrides. The individual machine
configuration then needs to choose the RT kernel flavour.
While at it, unify comment.
The distro layer seems to work fine with newer OpenEmbedded releases,
add warrior to supported series.
This mutes a following QA warning:
| WARNING: No bb files matched BBFILE_PATTERN_meta-toradex-distro
| '^/mnt/toradex/toradex-build/build/../layers/meta-toradex-distro/'
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Using python to conditionally set PREFERRED_VERSION_xxx does work, however
bitbake evaluates the value of PREFERRED_VERSION_xxx before set in the
python function.
Reverting the conditional assignment in favour of a hard coded upstream value.
fixes: 1e400c68e
The recipes for gstreamer* with version 1.14.imx set compatible version to
mx6, mx7, mx8. So for machines which use use-mainline-bsp we get a lot of
OE warnings during build, e.g.:
| NOTE: preferred version 1.14.imx of gstreamer1.0 not available (for item gstreamer1.0)
| NOTE: versions of gstreamer1.0 available: 1.14.4
Qt 4 was first released in 2005 and has been unsupported since 2015.
Drop it from what we regularly install.
build is actually a file not a directory.
NXP dropped X11 support for i.MX8 and i.MX8X.
Thus build our images with the tdx-xwayland distro configuration.
Thud next, new features, drop colibri-vf
See merge request rd/linux-bsp/meta-toradex-distro!2
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
There is a resonable default in bitbake.conf. For all our machines it is also
set explicitely so there is no need to carry this in local.conf.
